charging ipad and phones - Fiberglass RV
Old 02-07-2015, 04:50 AM   #1
kbingel's Avatar
Trailer: 2008 17' Oliver Elite
Hi,
We are planning to camp off grid a lot and use our solar panels to run lights, fan, etc...BUT, I didn't realize our AC plugs would not work on solar. ha ha ha...because I am NEW to this. Anyways, I love my ipad as a kindle reader so I can read at night without using lights, that wake the other person. But the battery wouldn't last a full week without some help. How so you charge phones and ipads while boondocking?
2008 17' Oliver legacy
kbingel is offline   Reply With Quote
Old 02-07-2015, 05:30 AM   #2
honda03842's Avatar
Name: Norm and Ginny
Karen,
Any reasonable solar panel should allow you to keep all the typical electronic devices powered. We have 80 watts of Solar and it is adequate for us.
We have multiple ways to charge our phones, e books, pad and computer.
Car Charging. All our devices can be charged while driving plugged into our car's DC outlet. We use the DC outlet in two different fashions. First we have chargers that can plug directly into the 12 volt outlets of the car (2) and charge our devices directly. Generally we have our phones plugged in while driving. Second, we have a 12 volt to 110 VAC convertor that we can plug into the 12 volt outlet. This allows us to plug traditional ac chargers in while traveling.
Trailer Charging. The techniques used in the car can be used in the trailer. In our trailer we have two 12 volt outlets. The same 12 volt chargers available for all these devices can be used in the trailer that one would use in the car.
We also have small 12 Volt DC to 110 VAC convertors for use in the trailer. We generally use these small convertors for running the Television at night but could also be used for charging.
Lastly we have a number of 110 VAC outlets that contain built-in USB charging ports (6). When the trailer's plugged into AC we use them for charging our Cell Phones, e-books and pads.
The Ebooks, Pad and computer all have substantial battery life and can typically go for a day or longer without charging, particularly the ebooks and pad. Phones need to be charged every day and likewise the computer if used heavily. As well as these devices we carry a wi-fi hotspot that runs all the time.
Of course it is possible to run all your AC plugs while boondocking. We also have, a rarely used, 1200 watt DC to AC Convertor that can power all our AC outlets. We would not use this to run high wattage devices like the microwave. Generally we use small 100 watt DC to AC convertors to run devices that only run on AC.
Over the years I've stopped using the ebooks, finding it easier and more convenient to read books on my phone, particularly because I always have my phone and it's easier to hold. Our computer is a Chromebook that weighs little and has great battery life.
To extend the battery life every bulb in our trailer is an LED, probably the case in the OLiver.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-07-2015, 06:46 AM   #3
We do it in the car. One vehicle has to have key in and on ACC position, newest vehicle has one power port live all the time so no key in ignition required. Simple, easy, inexpensive.
Old 02-07-2015, 07:21 AM   #4
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Two hints- one, a real Kindle such as a backlit Paperwhite will hold charge much longer than an iPad. Worth considering.
Second- the iPad charge will last longer if you turn off location services and turn off connectivity when not trying to connect.
Old 02-07-2015, 07:31 AM   #5
Raz
Raz's Avatar
Vermont
I charge my tablet using a generic cigarette lighter to USB charger. My iPad says "not charging". It lies. While it is not charging at the rate an Apple charger would charge, it is charging. It just takes a little longer. Raz
Old 02-07-2015, 07:51 AM   #6
There are any number of USB charging ports/adapters out there. Many are dual and have both a high (2.1a) and a low (1.0a) plug. I installed this one in a pop-up:
Old 02-07-2015, 08:04 AM   #7
http://tinyurl.com/pm4rvtc
20000mAh will recharge an iPad or phone several times.
Daniel E is offline   Reply With Quote
Old 02-07-2015, 03:55 PM   #8
Trailer: Escape 19 ft (sold) Escape 21 May 2014
Wisconsin
Since we travel with three IPads and two iPhones I spent some time researching the best 12 volt charger. The winner was a product available on Amazon called the PowerGen White Dual USB 4.2A (20W) Car charger Designed for Apple and Android Devices. The advantage of this device is it is intelligent and will determine if you are plugging in an iPad or iPhone and then adjust the charge rate. The iPad charges at a higher amperage. Another advantage is both ports, the Apple and the Non Apple are fully powered, using one will not diminish the power of the other. With a summer of testing in the fiberglass trailer and in the car we have been very pleased with the results.
Paul Braun is offline   Reply With Quote
Old 02-07-2015, 06:52 PM   #9
Trailer: 1997 16' Scamp
AC power in the rough
Hi,
I try to find sites with power but National, Forestry and Corps of Engineers Parks are often without. I am presently on a National Parks tour and have found a few tricks that work for us.
We have a small 20 watt solar panel that stores easily and is some help. Keep in mind that a 1,000 watt generator is often considered minimal. We have about half our lights switched over to LEDs and use only these when without AC. We have a Black and Decker 500 watt - 100 watt inverter to get AC from a battery. The 100 watt feature is a cigarette plug for the car that provides 100 watts to USB and regular receptacles. I think the inverter was $40 - $50.
I purchased a 230 cranking amp garden tractor battery to supplement my house battery. I got a small plastic tub at a dollar store and keep the little battery in the back of the car we tow with. I have a 20 amp fused supply that I ran for my trailer plug. I have a small fused line with battery clamps that keep the small battery charged while we drive. I can set the small battery on the tongue of the trailer and clamp the 500 watt inverter to it. We have power for the TV, DVD and computer without worrying about running down the house battery.
Heat is another matter for those 40 degree nights. We have a 1500 BTU portable catalytic propane heater. We run it until bedtime. We seem to get through the night fine without it. First thing in the morning we fire it up again. It gets us by but we prefer heating with AC.
Camping and travelling with a 16' Scamp is an exercise in the "less is more" philosophy.
varmint is offline   Reply With Quote
Old 02-08-2015, 01:34 PM   #10
LanceRinFla's Avatar
Trailer: Scamp 13 ft
I am getting from the OP he is using the solar panel to directly run equipment, not via a charged house battery? Maybe I just didn't get it.
A small Honda generator could charge a house battery pretty well. Use the solar when the sun is good, the genset when cloudy.
I also have a 400W inverter with a USB port, that charges my SIII phone well, and a pocket-sized charger pack, to give about three good rechargings.
Keeping the laptop recharged is a bit more taxing of course.
LanceRinFla is offline   Reply With Quote
Old 02-08-2015, 02:10 PM   #11
In FGRV's solar panels are always used to charge batteries due to the time/energy continuum (?) This means that it might take 4 hours to charge up a battery to run a microwave for 10 minutes, my figures may not be accurate, but you get the idea. (Continuum... that's a neat word, sorts like Penny's "Peppermint Schnapps".
Packing a generator is yet another task to take care of and isn't all that favored, and with a Honda 1000EU starting at about $850, it's bit expensive.
And the battery that powers your inverter is using more current for the the inverter part at idle than you need to run the USB port. You could save battery power with a connection to 12VDC source with one of the 12VDC to USB devices shown above.
Old 02-08-2015, 02:49 PM   #12
I do indeed have the 12V auto charger for all my devices. But when boondocking, it's more convenient, quieter and uses less fuel to recharge from the house battery. I do use the 12V charger cables directly off the battery, via cigarette sockets too. I have a variety of methods, depending on what works best at the moment.
Choice is a good thing...... :-)
Old 02-08-2015, 04:58 PM   #13
kbingel's Avatar
Well, I have to say....this is all informative...and overwhelming...ha ha ha.. We will not have a generator....don't like them...but not being judmental...just us...and of course, if we drive, I will plug in the devices but we will not be driving everyday..so I know this will sound stupid...but if we use solar...for powering our camper, will our ac plugs in the camper work? as in putting our usb plugs in the sockets? or in another question? does anything work in those? as in can I plug in a crock pot? I just dont' understand how solar works I guess..We put in a 100 watt solar and used it only once...and I know our microwave and AC doesnt work....but do the ac plugs work? Dont hate me for being stupid...ha ha...I think as we go on our FIRST long term trip, we will learn a lot..
Old 02-08-2015, 05:07 PM   #14
For Karen Bingel
Basically a solar system is a battery charging system, It charges up 1 or more batteries in your coach to store energy for when you need it, like when turning on the lights, the water pump, TV etc. If you want to power an ac appliance like an ac crock pot, you need another box called an Inverter. they convert the 12 volts DC of the battery to 120 volts AC and usually have their own dedicated outlets to connect into.
The good news..... solar energy is free and it can be charging your battery(s) any time sun is on the panels. The bad news, you are still depending on a battery to store energy and AC appliances use a lot. A single Group 24 battery might be able to run a microwave for 5-6 minutes before the battery is in need of a charge.
Hows that for starters? Keep asking questions and read, read, read.....
Older cell phones dying Nancy General Chat 9 07-03-2013 06:05 PM
Shipment of latest i-phones in route. Bruce H Jokes, Stories & Tall Tales 3 06-17-2013 08:16 AM
Pumping Gas and Cell Phones Legacy Posts General Chat 11 05-19-2003 07:16 PM
