Costco AC / DC Fridge - Fiberglass RV
Old 02-18-2015, 11:12 AM   #1
A new fridg at Costco. AC / DC
http://www.costco.com/.product.10013...oks_appliances
Old 02-18-2015, 01:43 PM   #2
cpaharley2008's Avatar
can not find the specs, wondering if it is low amp draw?
Jim
Never in doubt, often wrong
Old 02-18-2015, 03:24 PM   #3
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Grape's Instruction manual PDF states it draws 45 watts on DC, which works out to a nominal 3.75 amps @ 12V, although another part of the PDF states it requires a 120 watt DC outlet.
From their description: "The Grape Solar Glacier 5.0 is a solar compatible, 12V DC or 120V AC powered, refrigerator/freezer for disaster preparedness or vehicle based applications.
The Glacier 5.0 has a high efficiency DC compressor for reliable, worry-free performance when coupled with a Grape Solar 12V PV solar kit. With a separate freezer compartment, that cools down to 5 degrees F (-10 degrees C), and crisper compartment, you can store all of your perishables in ideal conditions.
Dimensions: Depth 23.25" x Height 41.5" x Width 20.25" Weight: 89.0 lb"
Jon Vermilye is online now   Reply With Quote
Old 02-20-2015, 11:19 AM   #4
David Tilston's Avatar
Costco's price is ~$100 less then the manufactures price.
Refrigerators
It should be noted that Grape Solar also have 3.7 ft model for $689.99. The power consumption is 15W more. Ironic.
Model: DC-110
Efficient volume:110L
Input power C 60W
Temperature of freezing:-12C
Temperature of refrigerating:0 ~10C
Dimension(WxDxHmm): 473*498*815 (Width 18.5" Depth 21" Height 32.1")
Old 02-20-2015, 12:15 PM   #5
Oswego, NY
After a bit of "discussion" on this refrigerator at the Escape forum, some points worth considering:
1. Unknown Chinese compressor (not a Danfoss) so there may be questions about the quality.
2. No latch on the door.
3. The need for 6" open space around the freezer.
4. The compressor reaches temperatures of 160F -195F while running.
Again, this may be a great product, but there are some limitations to consider.
Old 02-20-2015, 09:16 PM   #6
Perry J's Avatar
Trailer: 16' Casita
One thing to remember, one of the reasons Costco is so successful is because it refuses to anything but the best.
fridge
100 w solar at costco jwcolby54 Modifications, Alterations and Updates 5 09-15-2013 03:04 PM
LED desk lamp in Costco. GeorgeR Care and Feeding of Molded Fiberglass Trailers 2 02-06-2011 02:11 PM
Costco shopping FRED SMAILES Jokes, Stories & Tall Tales 0 05-11-2010 11:10 PM
solar setup at costco. Good buy colin k Problem Solving | Owners Helping Owners 98 06-26-2008 07:03 PM
Small Daewoo AC at Costco $50 after rebates (PGE) Bobbie Mayer Problem Solving | Owners Helping Owners 0 03-29-2008 07:47 PM
Copyright ©2000 - 2018, vBulletin Solutions Inc.
