Dexter Predator DX-2 Brake Controller - Fiberglass RV
Old 06-30-2007, 04:28 PM   #1
Some time ago I posted a question about Dexter's brake controller, and got not a single response here or on the several other forums on which I asked. I bought one because I figured Dexter ought to make a controller that works well w/ their other components.
Dexter sells a LOT of axles and brakes, but nary a single brake controller (other the one they sold me) it would seem.
I was hoping to delay until Jordan's new one came out*, but I am going ahead and installing the Dexter in both my TVs (Brake Controller slides into either TV). If I stay with an electronic unit, it will need the same wires to connect to anyway.
In the meantime, has ANYONE ever used one of these things?
OK, I know, everyone uses a Prodigy....
Bob
*Still no word on Jordan Ultimate Controller replacement
(Mercedes Sprinter and Jeep Cherokee towing Casita 17)
bobinyelm is offline   Reply With Quote
Old 06-30-2007, 09:25 PM   #2
OK My 2 cents worth.
Jordan appears to be mechanical coupled brake controller. There's a cable going from the controller to the brake pedal. I would think that because it's a mechanical adjustment that it would be constantly requiring adjustment. Brake travel changes over time.
I tried to find some professional reviews, but alas there weren't any.
Old 07-01-2007, 07:24 AM   #3
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
I took a look at it on the Dexter website. It sure doesn't say much about it there other than it's inertia controlled and for up to two axles. My guess is it's probably a rebadged Cequent product, but unless either Dexter or Cequent 'fesses up, you'll never know.
Roger
Old 07-01-2007, 10:15 AM   #4
Greg A's Avatar
Trailer: 2015 Escape 19
I think the $20 rebate on the Prodigy runs until August.
I got mine for $89 incl shipping with the rebate.
Awesome deal and seems to be an awesome controller.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 07-01-2007, 08:51 PM   #5
I have used a Dexter DX-2 on my Cadillac DeVille and then transfered it to the Escalade. On the DeVille I had to add all the wiring - took all day. On the Escalade I just used the harness that came with the Escalade. The process was: 1) crimp 4 splices - harness to controller according to the instructions that came with the harness, 2) plug in DX-2, 3) mount DX-2 under dash using pre-drilled holes, 4) go on test drive to calibrate the controller, and 5) you done. Total time 40 minutes including hooking up the Casita and taking a test drive.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 07-02-2007, 06:58 PM   #6
Brian B-P's Avatar
I wouldn't favour Dexter because they make the brakes. All electric brakes behave essentially the same, and the ability to punch out axles for a few decades doesn't indicate any electronic talents to me. I would rather go to a brake controller specialist (the Tekonsha division of Cequent, for example) than an axle specialist for this type of equipment.
Since trailer axles have not changed in any meaningful way for decades, axle companies may not be the best source for products which should take advantage of current technology.
I'm guessing Roger may be right about the real source of the Dexter controller, but if it's not really by Dexter it could also be from Valley, who like to sell their stuff under private label brands.
Brake Controllers - Prodigy vs P3 Predator Pete Dumbleton Towing, Hitching, Axles and Running Gear 3 03-09-2009 10:52 PM
Brake Controller Gary Seronik Towing, Hitching, Axles and Running Gear 10 05-06-2008 03:13 PM
Brake Controller JOHN PAUL EVANS General Chat 0 05-03-2006 11:52 AM
Pod Brake Controller Gina D. Classified Archives 3 11-24-2005 04:34 PM
