Did 13' or 14' Burro's come with a toilet/shower? - Fiberglass RV
Old 09-09-2007, 02:55 AM   #1
I see that 16' and 17' fiberglass trailers that have a toilet and shower are common. Did 13' and 14' Burro's ever have those options??? I am interested in something like that? Something small, lightweight, with a toilet, and a shower. Thoughts? Suggestions? Thanks everybody.....
AL
AL York is offline   Reply With Quote
Old 09-09-2007, 08:35 AM   #2
Trailer: Airstream 16 ft OB
Scamp has a 13 ft. with a shower/toilet but available only in the Deluxe model. They may provide it as an option in the Standard or Package.
Steve R is offline   Reply With Quote
Old 09-09-2007, 08:46 AM   #3
I haven't seen or heard of a 13-14' Burro with toilet/shower, doesn't mean they aren't out there. But since Burro is long out of business, the chances of finding one for sale... even if they did exist here and there, is pretty dang slim.
The Casita Patriot and Scamp Deluxe can both be ordered with toilet/showers. Finding ANY 13 footer used, with a full bathroom is pretty uncommon. Space is at a premium in the little trailers, most don't want to sacrifice nearly 1/4 of the entire trailer for those options.
Old 09-09-2007, 09:57 AM   #4
CindyL's Avatar
Illinois
Or add your own bathroom to the Burro.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 09-09-2007, 12:04 PM   #5
CindyL
Excuse my ignorance but how do you add your own bathroom? Also did small U haul travel trailers come with shower/ toilets?
Old 09-09-2007, 12:42 PM   #6
Jim Hovind's Avatar
Trailer: 1997 Casita 17' SD, 1981 13' Burro, 2014 Tacoma Crewcab 4x4
I doubt if you haul did either.
I own a 1981 Burro and next year I plan on adding a bath in the front left and a pantry in the front right.
The first step is to find some large political signs to lay up the fiberglass sheets on. I have used smaller signs in the past for inner panels. The smooth surface woods well the spray glass upon to build up from.
I will do a photo essay on the build. First I have to finnish my 54F100 project.
Jim H
Jim Hovind is offline   Reply With Quote
Old 09-09-2007, 12:55 PM   #7
Brian B-P's Avatar
The 16' U-Haul VT (Vacation Trailer, or Vacationeer) does have a bathroom (don't remember if it has a shower), but I don't think the 13' CT (Camper Trailer) did... someone might know of an exception.
Some 13' Trilliums had a front bathroom, and the 13' Outback from Team Trillium is currently available with one. I don't know if TrilliumRV is planning to offer a bathroom on their new Trillium 1300.
I think any 13' Boler with a front bath is most likely an owner modification, although there were so many companies building Bolers that there may well have been some factory equipped this way.
Some of the rear-door designs (Compact, et al) may have a bathroom in some versions... these are usually about 13' long and some are even shorter (in height), narrower, and lighter than a typical 13' Boler/Trillium type design (the Scamp and Casita are derived from the Boler).
Old 09-09-2007, 01:48 PM   #8
Trailer: 1985 17 ft Burro
We have a 17" widebody Burro and did just that...added a bathroom to ours. We cut the kitchen area in half and made the bathroom directly across from the entrance door. I know widebodys have a space for the bathroom to the left of the entrance door but they appear to cut the trailer in half. Not allowing you to see the large dinette or bedroom area. Since the pantry is on the other side, we thought, "keep all tall things on one side." The shift really makes an open appearance inside the trailer.
To accomplish this we bought a corner fiberglass shower enclosure, cut it down to fit , expanded one panel and fiberglassed it in. The sink area was reduced to a small one bay sink but all is very comfortable. The bathroom is perfect...our marine toilet fits into it perfectly with plenty of room to stand and shower. We also added a covered TP roll holder, a small medicine cabinet that opens into the cabinet over the sink. So that there is plenty of shelf room for shampoos, soaps, etc.
Added the shower last year. Plumbing, TP holder, medicine cabinet were all added this year before our annual family camp vacation. Took a nice shower in it this year, yeah! I will add pics to explain shortly.
D Shubel is offline   Reply With Quote
Old 09-09-2007, 01:49 PM   #9
CindyL's Avatar
Illinois
No shower in the VT. It is a privacy room. Some previous owner of ours put in a shower, by connecting a hand-held to the faucet and putting a drain in the floor. The problem is that the drain is higher than the floor and the water drains into the space for the portapotty. They must have used it though. When we bought the trailer, it had a large water tank below the bed which was permanently set up.
Anyway, something similar could be added to the 13', similar to those 13' with the scamps up front. Or something like we did to our 13' Burro. We bought 2 shower curtains, put them on a string with eye hooks connecting the closet with the cupboards over the stove. Then the shower was one of those that could use water from the sink and stand in a plastic tub to collect it.
You could check others' ideas for a portapotty. We just moved ours out on the floor at night.
There's a 13' UHaul on ebay right now, as well as a 16' UHaul.
Cindy
Old 09-09-2007, 05:07 PM   #10
Jim Hovind's Avatar
1. remove all windows doors etc from Burro
2. move all of the electrics out from the left front space.
3. Then cut the tops off both benches.
4. Install sewer tank on floot with toilet on top in left front.
5. Make tagboard patterns of both sides and lay up panels extending both sides to the roof.
6. make inside pieces for the above and laminate to the inside.
7. Blend in all panels.
8. Re-gelcoat the entire interior.
9. Re-gelcoat the exterior - IT needs it.
10. finish the restoration.
OR
Sell the Burro and buy a 16' with a bath ?????
the material cost for the remodel would be about $500 plus 100 hours of time.
we will see what I feel like after my 54 F100 project
Old 09-09-2007, 07:11 PM   #11
OR
This is such a great website! All of the members are EXTREMELY..... HELPFUL. Thanks EVERYBODY!!!!!!!!
AL York
Old 09-09-2007, 07:20 PM   #12
Just posted pictures of our bathroom install, along with a few other pics of our restoration...complete floor replacement, frame check, axle replacement. They are located at Shubel 17' Burro Custom Resto
Old 09-09-2007, 08:10 PM   #13
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Amazing, Donna... just amazing! You have taken a junker and made a custom jewell. Well done!
Roger
Old 09-09-2007, 09:03 PM   #14
I owe all my bravery and inspiration to this forum and its members!
Roger, I never would have purchased that broken egg 3 years ago without your personal encouragement and advice. Thank you a thousand times over!
This egg is exactly what our family needed.
burro
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 01:46 PM
16 foot Luxury Traveler with bunk-beds, shower, and toilet. LWEBB Classified Archives 3 05-24-2010 04:13 PM
Toilet and shower install in uhaul mszabo Plumbing | Systems and Fixtures 7 10-14-2009 08:04 AM
Shower and toilet install in uhaul mszabo Modifications, Alterations and Updates 0 10-07-2009 10:15 PM
Wanted: newer 13' Scamp trailer with toilet/shower Paul Kaplan Wanted: Molded Fiberglass Travel Trailers 0 06-30-2008 09:14 AM
» Virginia Campgrounds
