Difference between Bigfoot 17/17.5 - Fiberglass RV
Old 02-19-2015, 08:40 AM   #1
Tony Nowak's Avatar
Trailer: 2003 Bigfoot 17 (15B17CB), 2017 Escape 17B
Wisconsin
I was going to link to the BF owners group, but looks like one needs to be a member to access. I will summarize the post. BF changed their 17 foot trailer in 2005 to the 17.5. OP thinks it was updated to be better equipped for winter with enclosed tanks and double pane windows. There were small changes in the interior and floor plans up to 2005 but mostly cosmetic.
In 2005 the 17.5 CB front dinette changed to a narrower seat on the door side compared to the bath side. They also lengthened the kitchen cabinet to give more counter room and create taller cabinets above the counters.
The closet also grew by about 6 inches in length. The bath remained the same. The fresh water tank was moved into the trailer under the rear couch (likely done also in the few years pre 2005 to allow winter camping.
The walls are 1/2 thicker in 2005 and newer to give better weather insulating . Also the dinette windows were made taller, and narrower to accommodate the narrower dinette. Gone also is the overhead cabinet joining the front overhead to the bath wall. Tank sizes were in creased slightly with the 2005 and newer 17.5s as well. Trailer coupler went from 2' to 2 5/16" for the extra weight.
We saw a 17.5 center bath only once and thought the rear couch/bed wasn't any wider than our 17, only 42 or 43 inches. We make due for sleeping but assumed the 17.5 would have a wider rear bed in the center bath configuration. Can someone with a 2005 or later verify this bed size? The winter package was available on our 2003 but our water tank is under the trailer, perhaps because it isn't a 4 season trailer? Wondering when the winter package was first available. The BF thread also had pictures of the 17 and 17.5 and the top shell is noticeably taller on the 17.5 than the bottom, allowing for taller windows. The pre 2005s (17 footer) halves are about 50/50.
Tony Nowak is offline   Reply With Quote
Old 02-19-2015, 09:36 AM   #2
I assumed too...
I assumed the extra six inches was in the reach...
anyway, if an extra six inches of width is desirable/worth it...I'm thinking a simple six inch extension would not be to complicated to fabricate and incorporate in your existing trailer (deployed bed edge to edge of fridge)....heck, you could make this extra piece go past the fridge edge.....after all you only need the extra width at the head end of the bed...
1997 15B17CB.....with another take on the rear bed
Old 02-19-2015, 02:36 PM   #3
Tony Nowak's Avatar
Wisconsin
I should of added that our 2003 17 footer is 6 feet and 7 inches in length, I believe the 17.5 is actually 17 feet 5 inches. Please feel free to contradict any of this.
Old 02-19-2015, 06:06 PM   #4
Trailer: 1999 Bigfoot 21RB 2500
Hi actually in 2005 Bigfoot brought in there new mold . The old mold was from 1978 to 2004. That is where the 17.5 Models came from.
Rick M is offline   Reply With Quote
Old 02-19-2015, 08:46 PM   #5
yep....
new molds...."belly band" or seam much lower.... and the reach looks longer
bigfoot
Difference between 17' Bigfoot and Boler Ewesful Wanted: Molded Fiberglass Travel Trailers 5 06-10-2013 10:11 PM
Difference Between Drinking Water and Waste Tanks? Don A Problem Solving | Owners Helping Owners 4 10-27-2010 06:21 PM
Difference between men & women Riley Jokes, Stories & Tall Tales 0 08-31-2010 04:26 AM
Difference between built in stoves and portable? melissab General Chat 21 08-22-2010 07:05 AM
weight difference between scamp and casita al gilliland Care and Feeding of Molded Fiberglass Trailers 10 05-29-2007 08:27 PM
