Double hull trailers - Fiberglass RV
Old 07-27-2016, 11:30 AM   #1
Trailer: Looking
Hello, recently retired and we are looking for a durable, easy to maintain trailer. Can some of the experienced hands out there tell me what manufacturers offer a double wall/hull insulated trailer?
Which manufacturers offer exposed fiberglass cabinets/walls vs. those that are lining them?
Is condensation a problem with exposed fiberglass in single and/or double hull trailers?
Thanks in advance for any help you can give me in this pursuit.
firebasebob is offline   Reply With Quote
Old 07-27-2016, 11:44 AM   #2
With good wall coverings, condensation on the walls isn't much of a problem. Sometimes the cupboards will have issues during cool shoulder seasons and winter camping. You'll find single-pane windows to be a bigger problem with condensation. I believe Escape and Oliver are the only two current manufacturers offering dual-pane windows.
Old 07-27-2016, 12:16 PM   #3
Carol and Mike's Avatar
Trailer: Oliver Elite II
Boerne, Texas
Olivers are double hull, exposed fiberglass inside, no linings. We've had no issues with condensation.
The Lonestar Oliver #135 | Ram 1500 5.7L
Carol and Mike is offline   Reply With Quote
Old 07-27-2016, 02:44 PM   #4
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
The 1500 series Bigfoot models (1978-2005) are constructed with outer fiberglass shell, 1" Styrofoam, and inner covering of plywood. The 2500 series (2005 to present) has 3" of Styrofoam between layers. This insulation is in the walls, ceiling and floor and is glued into a sandwich. Some models have double pane windows and some don't.
Tom Trostel is online now   Reply With Quote
Old 07-28-2016, 10:48 AM   #5
Double hull
The HCI is also double hulled with a tihin layer of insulation between . Upper cabinets are part of the interior mold
Mikmay is offline   Reply With Quote
Old 07-28-2016, 11:01 AM   #6
Trailer: '00 Burro 17' WB
Seattle, WA
Burros are also double hull, including the cabinets which are of the inner hull. We've had zero condensation issues with the walls. Only problem has been with the single pane windows which arevery common.
mglyons is offline   Reply With Quote
Old 07-28-2016, 11:07 AM   #7
Trailer: Looking
Thanks for the informative replies. It was the HC1 that got us interested in "glass" campers. The double hull design just has to be so much more durable than a stick built, or even single wall glass construction. Ease of maintenance must be improved as well.
Old 07-28-2016, 11:42 AM   #8
Not sure I agree with that. Single wall fiberglass has the advantage of simplicity. It's easier to track down leaks, easier to make modifications, easier to make fiberglass repairs, since the structural part of the repair is made from the inside. By maintenance, I assume perhaps you mean rivets. To me the additional maintenance required is negligible- under an hour every 4 or 5 years to replace the caps. Rivets simplify the build process, keeping costs down.
Some double hull designs are fabricated of separate inner and outer molds and assembled after curing: Burro, U-Haul, EggCamper, and Oliver. These have the disadvantage of less flexibility in layout, since entirely new inside molds have to be created for each floor plan variation. The approach provides space for insulation between the layers, though not all do. I believe I read that insulation was optional on Burros, for example.
Others are molded and bonded together in the fabrication stage: Lil Snoozy and the HC1. I've never read a really clear description of the manufacturing process for either, so I hope I'm not misrepresenting here. This is a relative new approach for RVs, so its long-term durability hasn't been proven in this application. It is more structurally rigid- perhaps that what you meant- so there is more flexibility in how the interior is finished out.
Old 07-28-2016, 12:23 PM   #9
Not sure I agree with that. Single wall fiberglass has the advantage of simplicity. It's easier to track down leaks, easier to make modifications, easier to make fiberglass repairs, since the structural part of the repair is made from the inside. By maintenance, I assume you mean rivets. To me the additional maintenance required is negligible- under an hour every 4 or 5 years to replace the caps. Rivets simplify the build process, keeping costs down.
Others are molded and bonded together in the fabrication stage: Lil Snoozy and the HC1. I've never read a really clear description of the manufacturing process, so I hope I'm not misrepresenting here. This is a relative new approach for RVs, so its long-term durability hasn't been proven in this application. It is more structurally rigid- perhaps that what you meant- so there is more flexibility in how the interior is finished out.
All you have to do is read on many threads here how many have issues redoing there ensolite,carpet,rat fur to see how much more durable a double hull can be ,but of course that comes at a higher cost which is why you will see a higher cost on a double hulled trailer
Old 07-28-2016, 01:05 PM   #10
Most lining failures I have seen involve trailers approaching their 40th birthday and typically showing evidence of neglect somewhere along the way. Hardly an indictment of the design. Single hull trailers are simple, economical, and time-tested.
On the other hand, there is no doubt the HC1 is a beautiful, innovative trailer. I'd love to visit the facility in Los Angeles some day and see how they are made. I wish Happier Camper every success!
Old 07-28-2016, 01:31 PM   #11
Here's an interesting factual read from a member who purchased a double-hull trailer: Go Slow When Falling in Love with Cute Trailers!
I have no dog in this fight, just trying to provide some information that some may find of value during their "perfect" egg hunt.
Which Trailers Have A Double Shell? Cathy P. General Chat 72 08-28-2013 12:44 PM
Marine hull cleaner Barrett family Care and Feeding of Molded Fiberglass Trailers 3 08-15-2012 12:29 PM
Uhaul roof leak and hull question Lynne VDK Problem Solving | Owners Helping Owners 8 12-31-2010 09:39 PM
6X10 piece of "Rat Fur" (aka marine hull liner) GrahamD Classified Archives 0 10-09-2007 09:00 PM
Which have double hull AND fiberglass floor? Leslie L. Problem Solving | Owners Helping Owners 7 05-27-2006 11:14 PM
