Dumb Question on Metric Bolts - Page 2 - Fiberglass RV
Old 04-03-2013, 01:30 PM   #15
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by steve dunham View Post
Several years ago in the final exam of a class I taught at the local Vo Tech, I added 2 Bonus Questions
Question #1 How many degrees are in a metric circle
Question #2 How many degrees are in a metric triangle
Less than half the class answered the questions correctly !!
Makes you wonder what they learned in High School
Well, you didn't specify degrees Fahrenheit or degrees Centigrade.
Old 04-03-2013, 01:36 PM   #16
Joe MacDonald's Avatar
As far as tool sets: Mastercraft 184-piece Socket Set | Canadian Tire
something like this should cover just about anything you could need in imperial or metric and its guaranteed for life.
Joe
Old 04-03-2013, 02:03 PM   #17
Trailer: 1980Trillium 1300
...Here is for Mister.." Michigan". As the poster related, he mentioned about angle unit measurement, not temperature...
http://en.wikipedia.org/wiki/Degree_(angle)
Old 04-03-2013, 02:17 PM   #18
Originally Posted by David Tilston View Post
It has been a difficult transition. The Trillium model numbers are a reflection of Canada's metric journey. 1300 for the 13' trailers, (before metric) and 4500 for the 4500mm trailers.
It is a bit supprising that Trillium had conversion problems as well. Below is the bottom of the data sheet on one of my 4500's. Please note that 4410 Kg = 9943 lbs. So, as long as I travel only in Canada, I can carry 4.5 tons.
Hi, David, that woman at your office of...registra whatever must be an....old GrandMa came to Canada from.....England...
Old 04-03-2013, 02:40 PM   #19
Thomas G.'s Avatar
Originally Posted by Thinh View Post
Humour - Wikipedia, the free encyclopedia
Old 04-03-2013, 08:15 PM   #20
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Ever heard of "ESL", Tom?
Irony doesn't cross over so easily...
Francesca
Old 04-03-2013, 09:48 PM   #21
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Its amazing to me how we in North America laugh a countries that have the weirdest
monetary systems but base their measuring system on multiples of 10.
We base our monetary system on multiples of 10 and have the weirdest measuring system. Wonder who laughs at us.
I work with wood but would never call myself a carpenter. Lol Every time I need. Tape measure I always look for one that is metric or imperial only as the dual ones always cause me a problem when working.
As a senior Canadian I grew up Imperial, was introduced to metric in grade 9 high school chemistry and embraced it.
Where I live metric fasteners are still hard to get and I will stock up when I cross border shop in Idaho,,go figer? Ive never needed enough volume to worry about price.
Fred
FRED SMAILES is offline   Reply With Quote
Old 04-04-2013, 07:16 AM   #22
Thomas G.'s Avatar
Originally Posted by FRED SMAILES View Post
.............I work with wood but would never call myself a carpenter. Lol Every time I need. Tape measure I always look for one that is metric or imperial only as the dual ones always cause me a problem when working...................Fred
OK, now I just gotta ask. In the US we commonly build walls with a stud that measures 1.5" x 3.5", but is commonly referred to as a 2x4. If I go into a Canadian lumberyard and ask for a wall stud, what will the dimensions be?
I know it will not be 3.5" x 1.5" because Canada is a metric country.
Old 04-04-2013, 07:26 AM   #23
Ian G.'s Avatar
Our dimensioned lumber uses imperial (i.e. 2x4 but actually 1.5x3.5) but our plywood sheets are metric, specifically in thickness. We frame using imperial stud spacing (either 16" or 24" on center).
.... but we can only buy metric hammers
Old 04-04-2013, 07:31 AM   #24
Ice-breaker's Avatar
Wood frame construction industry in Canada operates primarily in imperial units. Still use 2x4's and other old standard imperial sizes, and when spacing studs or joists in a building they are typically at 16" or 24" centers, primarily to allow use of 4'x8' plywood or drywall that comes in 2' length increments.
I remember working for my dad's home building company when metric lumber arrived in Canada. After a few unsuccessful attempts to space studs, joists, etc at metric distances, we went back to the old imperial system and just cut the metric plywood down to imperial lengths before using. It was not long before the industry switched back to imperial sizes only.
Ice-breaker is offline   Reply With Quote
Old 04-04-2013, 07:33 AM   #25
cpaharley2008's Avatar
".... but we can only buy metric hammers "
now that is funny, I guess your dozen eggs are only 10?
ps- my house has real, actual 2x4's- I believe "true 2x4" is the name
Old 04-04-2013, 07:51 AM   #26
Thomas G.'s Avatar
Originally Posted by Ice-breaker View Post
....... After a few unsuccessful attempts to space studs, joists, etc at metric distances, we went back to the old imperial system and just cut the metric plywood down to imperial lengths before using...........
Old 04-04-2013, 09:48 AM   #27
james kent's Avatar
Trailer: Boler 1984
Sae or metric is not that difficult. You pick up your sae wrenches and try to find the right size. Then you go through all your metric wrenches to no avail. Then you pick up an adjustable and quickly round over the corners before grabbing your locking wrench. Ahhh!
Old 04-04-2013, 10:09 AM   #28
Canadian lumber....jack!
...As we know, Canadian lumbers are mentioned mostly in Imperial measurements. Here is my perception: Can. population is way smaller than that of USA and Can. lumber industry relies mostly on...exports. BTW, Can. system is used to Imperial...they even train their students with both units in schools. So why not making lumbers in Imperial system for.....easier...MILKING Uncle Sam???
Dumb question about taillights Chita Problem Solving | Owners Helping Owners 24 02-18-2013 02:08 PM
Dumb Electrical Question GerthT Care and Feeding of Molded Fiberglass Trailers 13 07-04-2012 09:01 PM
a dumb question rox Problem Solving | Owners Helping Owners 2 07-09-2011 08:41 AM
Dumb question re: fiberglass Daisy Problem Solving | Owners Helping Owners 7 05-19-2006 08:32 AM
Dumb Question Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 10-05-2002 09:08 AM
