Egg Construction - Fiberglass RV
Old 12-22-2016, 09:40 AM   #1
Trailer: Starcraft
Vermont
Egg Construction
Does anyone know if any of the egg manufacturers vacuum-bag their fiberglass layups to save weight?
kpinvt is offline   Reply With Quote
Old 12-22-2016, 09:49 AM   #2
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: kpinvt... Not sure about that system but I do know that Escape Trailer Ind. puts theirs on a rotisserie.
Old 12-22-2016, 10:02 AM   #3
IllAnnoy
LiL Snoozy uses that method, it is not just conventional molded fiberglass bagged, but a different process all together using different material between layers. not necessarily lighter though.
Old 12-22-2016, 10:38 AM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
[QUOTE=floyd;620702]LiL Snoozy uses that method, it is not just conventional molded fiberglass bagged, but a different process all together using different material between layers. not necessarily lighter. You're right Floyd. Our 2014 Lil Snoozy weighs 2500 lbs., but it is much more ridged than a comparable in weight Casita, as the Lil Snoozy does not require any internal structures to support the roof and walls (perhaps that is why the isle is wider and interior feels more open). It is a lot like a fiberglass speedboat in strength. I climb onto the roof all the time to clean & wax without any perceivable flexing, and I weigh 215 lbs.
Dave & Paula
Old 12-22-2016, 11:13 AM   #5
IllAnnoy
Dave & Paula
You seem to think that it is a superior material/method and you have cited justification for that position.
I personally don't see it as such, and much prefer the conventional method used by virtually everyone else.
The Lil' Snoozy is, however, a fine trailer... far superior to a stickbuilt. (even those which can take standing on the roof.)
I suggest not standing on your roof though, micro cracks in the outer layer can result in spalling, especially when over a void.
Old 12-22-2016, 01:46 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
I don't believe it is a layup method at all. You're thinking of layers upon layers of resin-impregnated fiberglass cloth, correct? But most of the egg trailers' bodies come out of a mold; I could be wrong, but I don't think it is a layering process.
How much time do we have left? 2 Chr. 7:14
Old 12-22-2016, 04:38 PM   #7
Ian G.'s Avatar
Also check out the Nest Caravan, which was recently bought by Airstream. They probably use the most advanced composite construction. The floor is structural with the axle just being bolted to the floor pan. There is a very good thread on this forum which documents their construction.
Old 12-23-2016, 08:00 AM   #8
Sid
Sid's Avatar
Trailer: Parkliner 2014 V6 Jeep Cherokee
Are we talking about vacuume bagging or vacuume infusing?
This web page contains a nice video explaining vacuume bagging...
Vacuum Bagging Equip and Supplies for Composites | Fibre Glast
And this is a link to one that covers vacuume infusion...
https://youtu.be/vXRfVJ_F9UQ
Don't quit your daydream.
Sid is offline   Reply With Quote
Old 12-23-2016, 09:33 AM   #9
Raz
Raz's Avatar
Vermont
Space bags?.
Raz is online now   Reply With Quote
Old 12-23-2016, 09:44 AM   #10
Raz
Raz's Avatar
Vermont
Some pictures courtesy of Scamp
Old 12-23-2016, 09:55 AM   #11
Trailer: 2008 Casita 17 SD
Like most trailers, RV's, and boats, made from fiberglass, welcome to the world of the "chopper gun," as shown in the post above. Only the highest end production companies use vacuum bagging and composites (like the airplane manufacturers) or even use hand laid woven fiberglass matting and hand applied resins, due to the increased expenses and time involved during production. If they do some hand laid applications, they generally are only used in high stress areas that need to be reinforced for added strength.
Old 12-23-2016, 12:28 PM   #12
David B.'s Avatar
Trailer: Lil Snoozy
Sid, the Lil Snoozy is sandwich core vacuum infusion.
Dave & Paula
Old 12-23-2016, 06:34 PM   #13
Alf S.'s Avatar
Hi: Casita Greg... Escape's are hand laid woven fiberglass matt. Reace told me that to use a chopper gun he would need to install air handling systems for employee protection. He's not that into speeding up production.
Old 12-23-2016, 09:08 PM   #14
Mike Magee's Avatar
In other words, Escapes are "high end" trailers at a mid range price!
Interesting fiberglass over foam construction site Ken Dale General Chat 2 05-08-2008 10:18 PM
Scamp Construction Thane K Modifications, Alterations and Updates 2 05-04-2008 01:33 AM
Insulation/Double wall construction Ami P Problem Solving | Owners Helping Owners 4 05-03-2008 07:32 PM
Which eggs have double wall construction? ScottK Care and Feeding of Molded Fiberglass Trailers 21 03-07-2008 08:39 PM
Wondering about Bigfoot Construction Byron Kinnaman General Chat 17 01-18-2008 07:56 AM
» Virginia Campgrounds
