Elbert - Page 5 - Fiberglass RV
Old 04-08-2013, 02:55 PM   #57
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Chris Jones View Post
Attachment 57263
Got the Solar panel off today.
Looks like the grommet has had it. I have a plan to superglue 1/4 inch piece of pipe around the thing to keep out the water.
And there are some gaps here around the Fantastic Fan.
After you clean it up real good with TSP, I'd invest in a roll of butyl caulk. It is what you need to seal both the vent and the wire going into the roof.
Old 04-08-2013, 03:02 PM   #58
Chris Jones's Avatar
Trailer: U-Haul
TSP ? And how about this set up? I have to get this goop out from around the vent before I can start any repairs there.
Chris Jones is offline   Reply With Quote
Old 04-08-2013, 03:24 PM   #59
Thomas G.'s Avatar
Yea, the tri-sodium phosphate really makes short work of algae and dirt.
ToolKing.com: Savogran Co 10622 Heavy-Duty TSP All-Purpose Cleaner - 4-1/2 lb.
Old 04-08-2013, 05:03 PM   #60
Trailer: U-Haul
Carpet is down to check where it is leaking.
Looks like a good place to start looking.
Looks like the wire has had water coming in around it too. I bet there is water coming in around the fan and running back looking like the panel bolts. I hope they are ok so I don't have to replace them.
Old 04-08-2013, 07:07 PM   #61
Trailer: '77 Scamp
Wow Chris,you've got a big project going there. You're doing a great job and I know it will be beautiful when you're finished. You'll make many great memories in your Uhaul. Getting a travel trailer that needs a lot of TLC like you have, will make you appreciate it all the more and give you a lot of personal satisfaction. Keep those pix coming.
Otters is offline   Reply With Quote
Old 04-09-2013, 11:09 PM   #62
Trailer: U-Haul
Yep! Here is one of the leaks! But with the pipe and super glue there is no leak at the wire!
Old 04-10-2013, 05:45 AM   #63
Is that a water drop at the screw head? I had to remove one of the solar panel rails to get the panel off, then put the rail back on with butyl tape. That was easier than filling all the screw holes. Covered the wire hole with fiberglass cloth and resin. No more solar panel for us.
Old 04-10-2013, 06:14 AM   #64
Trailer: U-Haul
Yep thats water. i took about a cup up on top and poured it around and this is what i got! Gonna put my solar panel back on, so I will have to get the holes sealed up. Shouldn't be too hard.
Old 04-10-2013, 07:25 AM   #65
Thomas G.'s Avatar
I put butyl putty around the hole, under the head of the elevator bolt and over the top of the exposed, threaded end of the bolt. No more leak.
Old 04-10-2013, 07:34 AM   #66
Trailer: U-Haul
So what about lighting the mounts up just a bit to allow for any water trapped under the panel to drain and not stand under it? Water running off has a less chance to find a way in. Or at least I think so. Or do you think that will put too much stress on the points of contact. That might be why there is the foam mount between the mounting rail and the roof, to kind of spread the load.
Old 04-10-2013, 07:39 AM   #67
Thomas G.'s Avatar
My experience is that the hole needs to be sealed. If there is water present, it will wick through the smallest hole, whether it is from a standing pool of water or a steady mist. Leaving good contact between the roof and bracket will make it stronger, especially if you decide, like me, to use it to mount a larger panel.
Old 04-10-2013, 07:52 AM   #68
Trailer: U-Haul
Plan is to stay with the stock panel. Not sure the stock controller will run a larger one. I do like the board you put under your seat with the volt/amp meters. Is that something you would consider building for others to install in their units? If so you could PM me with your price. I can't find your post where you described it, but I remember thinking to myself "self, you need to get with him on that one there!"
Old 04-10-2013, 08:02 AM   #69
Thomas G.'s Avatar
The stock controller is a dinosaur in terms of electronics, but you can buy a new one fairly cheaply, if you go Chinese. Or get a brand name for about $50. http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Thanks for the kind words on the control panel, but I really am not interested in making or selling anything. Too much like work for an old retired guy.
I would be glad to give you a parts / source list and help with any questions.
Old 04-16-2013, 10:16 PM   #70
Trailer: U-Haul
New carpet is in. Windows do not leak. Solar is on and does not leak. Electrical now has two brakers and the 12 and 110 are no longer on the same switch. Screens are riveted back on. Got to finish scrubbing the outside because my first weekend in it will be this one! There is a large VW show in Chattanooga and ELBERT will be my accommodations.
