Electric Blanket - Fiberglass RV
Old 09-19-2011, 01:54 PM   #1
honda03842's Avatar
Name: Norm and Ginny
Electric Blanket
Many of us are looking for night time heating solutions. As I previously stated if we have hookups we usually only turn on our electric blanket, using other heat sources only when we're awake.
In the past when boondocking we just threw an extra blanket on the bed.
I have been wondering if it would be prudent to run our electric blanket off of our Inverter over night in terms of battery usage
Our blanket is a twin size with a single controller, wide enough for our Scamp bed. It appears to draw 100 watts maximum.
Other than turning it to high before we get into bed, we usually run it on 3-5, about half power. At this temperature it seems to have a 50% duty cycle.
I've been running a simple test. After four hours it's hardly made a dent in the battery.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-19-2011, 02:11 PM   #2
cpaharley2008's Avatar
I have a 12v version, yet to be used, so I'm curious of your test results with 120v version. Keep us posted.
Old 09-19-2011, 03:01 PM   #3
LSChilders's Avatar
Trailer: Casita 17 ft Liberty Deluxe
Just buy two "cold Weather" sleeping bags that can be zipped together, for a warm toasty bed in any weather.
Or, ... buy one "0 degree" rated bag that can unzipped to create a full sized cold weather comforter.
LSChilders is offline   Reply With Quote
Old 09-19-2011, 03:09 PM   #4
honda03842's Avatar
Heat
We own bags but prefer the e-blanket.
We like getting into a warm bed, aging bones I guess. One thing that's nice about an e-blanket is that it's virtually a variable thickness blanket and very easy to store.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-19-2011, 05:59 PM   #5
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
One thing to consider - many electric blanket controllers do not work on modified square wave inverters. Either use a sine wave inverter or try it before you need to depend on it...
Old 09-19-2011, 06:14 PM   #6
honda03842's Avatar
Inverters and Batteries
I'm not an expert in this area but I have yet to see anything that doesn't work on our non-sinewave inverters.
So far we've charged our phones, computers, run our TV and Satellite Receiver, run our coffee pot, run our AC refrigerator, run a stereo amplifier, and now we've run an electric blanket for 8 hours.
So far it seems to work on everything without producing any interference. Our 1200 watt Inverter's biggest load was starting the compressors fridge. We also carry two $19 100 watt Inverters for charging phones and the computer in the car. We also use these to run our LCD TV.
We probably use the small ones more frequently than the large one.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-19-2011, 06:41 PM   #7
Mike Magee's Avatar
Trailer: Li'l Hauley
Sounds like you might be drawing about 4 to 5 amps. Look at the amp-hour rating on your battery, and figure how low you are willing to draw it down without damaging it. I bet you could usually get a couple of nights before recharging, but of course battery condition and how cold it gets will be factors too. Oh, and does the inverter use any of the juice to keep itself operating?
I just bought an ElectroWarmth 12v bed warmer. No inverter needed. It goes under the sleepers, not overtop, so the mattress feels warm faster. And it's probably somewhat more efficient since the blankets and people above it all help to conserve the heat, versus the electric blanket radiating much of its heat up and away.
How to prepare Tofu
Step 2: grill some meat
Old 09-19-2011, 06:48 PM   #8
Greg H's Avatar
Trailer: 72 Boler American
Indiana
We used to use those mattress warmer pads in the semi's, they do a pretty good job.
Old 09-19-2011, 06:54 PM   #9
honda03842's Avatar
Conclusions
Mike,
I think your conclusion are correct. Definitely a 12 volt blanket or pad starts off with an efficiency advantage, not requiring the Inverter.
As to my test, it ran for eight hours. I simply left the blanket spread out over the couch, where normally we have a comforter on top. Definitely the comforter would have improved the efficiency.
We ran it for 8 hours and the battery voltage dropped from 12.5 volts to 12.2 volts. This represents about 20-30% of battery capacity.
I will repeat the test sometime this week using a comforter over the e-blanket to get a more accurate reading but as a first order test running the electric blanket off the inverter looks good.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-20-2011, 04:31 AM   #10
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: All... One of the great features of our 5.0 Escape is the permenant queen size bed. We use a quilt my Mom n law made us for the warmer months and then a down filled duvet for early spring/late fall. It certainly won't preheat the bed...but gets quite warm quickly!!!
Old 09-20-2011, 05:01 AM   #11
Alf S.'s Avatar
Hi: All... Here's a couple more pic's of the 5.0 interior...but still no electric blanket. There are two 120 V. recpt. at the foot of the bed for a power blanky tho!!!
Old 09-20-2011, 05:02 AM   #12
Alf, where's your feet? The prior bunch had them!!!
Old 09-20-2011, 10:03 AM   #13
Lizbeth's Avatar
I love the electric blanket idea. When my feet and behind get cold out by the campfire, or in the house for that matter, no amount of blankets warms me up sufficiently to get to sleep. Often times it takes hours of lying very still in the same place in bed to get comfortable. That is why I've always insisted on having a heater which helps but does not solve the problem.
We do have a E blanket for when we use hook ups. I am interested in the end results of this experiment!
Old 09-22-2011, 01:12 PM   #14
honda03842's Avatar
Small Inverters
I attempted to re-run my test using a smaller Inverter, a 400 watt inverter.
The electric blanket reported an error when I plugged into the 400 watt inverter though it works perfectly fine on the 1200 watt Inverter. Both Inverters are non sine wave Inverters.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
electric h.mike Problem Solving | Owners Helping Owners 4 07-25-2011 07:28 AM
Has anyone used an electric blanket to stay warm at night? Donna D. Care and Feeding of Molded Fiberglass Trailers 20 10-08-2008 09:12 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
Electric stovetop? Filbert V. Modifications, Alterations and Updates 6 04-13-2007 11:58 PM
Electric brakes Greg Janke Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
