Eliminate the blind spot - Fiberglass RV
Old 12-05-2007, 09:26 AM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Very good article on setting up you mirrors to eliminate the blind spot.
http://www.popularmechanics.com/automotive...to/4234574.html
Adjust the driverís seat to the correct position. Lean your head and torso over to the left until your head contacts the window glass. I know, that seems too far. But trust me. Now, adjust the left-side mirror outward until you can barely see your own fender in it. Next, lean over to the right a similar distance, and adjust the right-side mirror so you can just see your own rear fender. Sit up straight. Your mirrors are now set to allow you to see other cars in your blind spot. You wonít need to swivel your neck around to be aware of traffic hiding at 60 mph right beside you. And the interior mirror will still let you see the traffic directly behind.
Old 12-05-2007, 09:45 AM   #2
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
To adjust the driverís seat to the correct position. Lean your head and torso over to the left until your head contacts the window glass. I know, that seems too far. But trust me. Now, adjust the left-side mirror outward until you can barely see your own fender in it. Next, lean over to the right a similar distance, and adjust the right-side mirror so you can just see your own rear fender. Sit up straight. Your mirrors are now set to allow you to see other cars in your blind spot. You wonít need to swivel your neck around to be aware of traffic hiding at 60 mph right beside you. And the interior mirror will still let you see the traffic directly behind.
If have been adjusting my side mirrors like this for 20+ years, it works great. I don't use the leaning my head method, but my mirrors are set so when I am sitting normal, I can't see the side of the vehicle, I can see the lane beside me, if I need to see the side of my vehicle, I just move my head to one side or the other. Someone a long time ago mentioned "Why do you need to see the side of your car? Are you worried it is going somewhere without you?", it was strange at first, but now I find it strange to see the side of my truck when I drive.
This works great, as a vehicle is coming up behind you in the other lane, you can see them in the rear view mirror, then as they start disappearing out of that mirror you can see them in the side mirror, then as they start disappearing out of the side mirror, you can see them beside you.
I have been driving this whole time without a "blind spot", I can see very well with this type of setup.
Old 12-05-2007, 10:38 AM   #3
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 2004 Airstream Interstate 22' B-van
Iowa
Just recognize that while towing, most states' mirror laws require that your mirrors be adjusted so you can see some distance (usually 200') immediately behind the trailer. Your inside rear-view mirror is obstructed by the trailer, so you must adjust your outside mirrors appropriately. When towing, mirrors adjusted out to cover your "blind spot" may not be adjusted so you are in compliance. I have found that the small 2" stick-on convex mirrors set in the outer lower corner of the mirrors work well to allow for both covering the "blind spot" and being able to have the mirrors adjusted to comply with the requirements set out by law.
Roger
Old 12-05-2007, 01:36 PM   #4
james kent's Avatar
Trailer: Boler 1984
That guy following STILL is so close that I can only see his shadow on the pavement. I want a bumper sticker that disclaims his use of me as a personal hood ornament.
Same camp spot, different coach shane n General Chat 4 07-14-2009 08:37 AM
Blind Sales Clerk Roy in TO Jokes, Stories & Tall Tales 2 02-12-2009 12:53 AM
our secret spot CharlynnT Camping, Campout Reports 2 05-16-2008 08:31 PM
Tight spot Greg Yother Care and Feeding of Molded Fiberglass Trailers 17 04-16-2007 06:30 AM
bright spot Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 3 06-16-2003 09:34 AM
» Trailer Showcase
Scamp
Gilda
trillium
seaway10
