Emptying the Porta Potti - Page 3 - Fiberglass RV
Old 07-25-2011, 03:50 PM   #29
Here is what I use and it work's just fine.
www.happybowl.com
Bill K
Originally Posted by reeves99 View Post
When we used the porta-potti with our camper a few years back I had a strict "liquid only" rule because I had to do some very unpleasant clean up the first time it was used for other purposes. As we are contemplating a porta-potti again, and we are older, and may need to use it for emergency solid waste, I was wondering if any of you have tried using a spray-on soap solution on the bowl sides before use to stop things from sticking around and *hopefully* flush a bit more thoroughly.
Sorry this is a bit of an icky question, but it's better to ask it here when you can't see my blushing face.
Thanks
Old 07-25-2011, 03:58 PM   #30
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thanks
Hi Phil
I have a strict rule about my porta-potty, too- Other than a little flushing water when needed, nothing goes in it that didn't pass through a human first!
I've found that paper is the biggest nuisance- it doesn't want to "flush", and it doesn't want to come out.
All paper is disposed of separately.
And other-er-solids are "deposited" ONLY when there's enough liquid in the bowl to carry them down. I don't usually have a "sticky" problem that way...
I also use powdered borax for odor control, and it helps a lot!
Hope this helps
Francesca
Old 07-25-2011, 04:27 PM   #31
Sharon G's Avatar
Trailer: 2005 Casita Spirit Deluxe
Phil, you can put toilet paper in an X around the bottom of the bowl before using the porta potty which makes flushing easier. And you can use a dish soap bottle with a little dish soap filled with water to squirt a strong stream of water to remove any residue on the side of the bowl.
Roger, as environmentally unfriendly as it is, the ONLY product that I have found that keeps the odor down for 3 days is the Thetford blue toilet chemical with formaldehyde. Especially in hot weather. Otherwise the stench is unbearable.
Sharon G is offline   Reply With Quote
Old 07-26-2011, 07:17 AM   #32
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Originally Posted by Roger C H View Post
l empty every morning. The one time I left it go a day because of little use, it stank! even with the green stuff.
Rest stops have toilets that can be used. I am always careful to pour carefully so as to not make a mess.
As stated above, I much prefer dealing with a Porta-Potty than the camper Toilet. Well....I did!
After a couple of camping trips I wanted to remove our factory toilet and replace it with the Porta-Potty but the wife said NO! She was afraid something would go wrong and the toilet might not go back properly at resale time or whatever. So the first camping trips we had the P-P sitting in the shower floor. The door will close and the space is usable, but tight. So we decided to use the factory toilet for summer and the P-P for winter, when the camper is winterized. Still didn't want to deal with solids whether in the P-P or the Camper toilet.
Here is what we have found that works for the two of us! And I'm really having fun writing this!
This works with our P-P and the camper toilet. When a "solid" deposit is in order, Place 3 grocery bags inside one another, or use a good strong and thick trash bag. Place them in the toilet with the carry handles hanging over the rim, on the sides. The toilet "seat" sitting on the handles will keep the bags from collapsing into the toilet. Make the deposit including the paper. Tie off the top of the bags and drop them in the trash or empty the bag into a campground toilet at your convience.
Tips:
1. Deposit only solids in the bags.
2. Use a flat lid from a Cream cheese container, cool whip container or most any of those throw away things. Place it in the bowl before inserting the bag. This will keep the bag from getting in any standing water.Be sure to remove it for "wet" activities.
3. Turn on the bathroom fan before the performance begins! Our bathroom door doesn't fit air tight on the hinge side so the fan drawns air through there. And the bath window cracked a half inch or so is helpful. Our BR fan is small but works great with this setup. Doesn't work so good, to control odor, if the door is left open. With the door closed, fast moving air coming across the front and from behind seems to work best for us. Once the bag is sealed any odor that may be remaining is instantly gone. Nothing noticabe goes into the camper when the door is opened.
So a water hose works great to drain both camper tanks, as there are no solids to deal with. When done draining just unscrewing the hose from the camper and lifting that end empties it. No hateful slinky hose to deal with. I have a couple lengths of garden hose that can be connected if necessary. Liquids only, in a P-P make that chore a lot less painful too!
4. Installed a shut off valve in the toilet's supply line so the flush water can be adjusted for the bare amount of water needed to flush liquids.
5. If our camp site doen't have a sewer connection and the tanks need to stay shut off, a couple of ounces of Clorox deal with urine odor in the black tank pretty well.
We don't shower in the camper so we don't have much gray water. We do take along a wheeless 5 gallon blue tank just in case something needs draining, but haven't had to use it yet.
Have fun!
KIp
Kip in Ga. is offline   Reply With Quote
Old 07-26-2011, 08:44 AM   #33
Hi, Kip
Wow!
But why no #2?
Without paper in the potty, everything that comes out when I dump mine is liquified...
Francesca
Old 07-26-2011, 09:52 AM   #34
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
Happy Bowl
Bill & Sharon
Excellent suggestions! Just what I was looking for. I think either idea is much better than the Wag Bag solution.
Thanks!
Phil
reeves99 is offline   Reply With Quote
Old 07-26-2011, 10:12 AM   #35
Trailer: 13 ft Scamp
To eliminate porta-potty odor we put a bit of Mr. Clean (liquid cleaner) in with the first "flush". Tried other options that failed miserably then got this tip from a friend. We use our porta-potty only for liquids and even then only at night; since there's so little in the tank and the Mr. Clean keeps things odorless we don't have to dump until we leave a campground after 2-3 days! Never an odor! Even dumping is painless! Will learn how well this still works after 2-year-old gets out of diapers.
Darnelle is offline   Reply With Quote
Old 07-26-2011, 10:19 AM   #36
Oh, we do flush the tp. Use a fair amount of flushing water to keep the bowl clean (3-4 "pumps").
Old 07-26-2011, 10:21 AM   #37
Anybody have any special technique for shaving seconds off what we call "The Porta Potty Dash"?
I've got my emptying sprint down to about 45 seconds, I think.
That's from the door of the "dumpsite" to capped and back outside...
Francesca
Old 07-26-2011, 10:28 AM   #38
Sharon G's Avatar
Just a question about adding bleach to black tanks or porta potties.
I've read several posts on different boards where people say they add bleach to black tanks or porta potties.
I was taught that ammonia and bleach combined to create deadly chlorine gas. Since urine turns to ammonia, wouldn't adding bleach create a dangerous combination?
During hurricane seasons, I've also read articles that say not to add bleach to toilet bowls when there is no water to flush for the same reason.
Old 07-27-2011, 05:05 AM   #39
Kip in Ga.'s Avatar
Hi, Kip
Wow!
But why no #2?
Francesca
Hi Francesca,
Possibly it is because we have gotten older, that the apperance of liquified "solids" dumping from a P-P tends to unsettle the stomach a bit!
Then the washing and rinsing at the end of the trip to get it clean and sanitized just "seem" to kind of take some of the fun out of the memories.
You are right about the paper! Like most folks, we used the toilet like we were at home, when we were camping at commercial parks and were on sewer. And the trailers were a lot higher off the ground than these FG jobs. So we had good drainage and plenty of time to flush and rise the Black tank before leaving the camp ground. The kids grew up and lost interest in camping and so did we. So 20+ years later we tried camping again out of our long G20 Chevy van and got a Porta-Pottie. Quickly found that we needed to "conserve" usage, or fool with the thing every day.
Got our 03 Casita and found it real close to the ground offering problems when not being on a sewer line and having to use the state park's only dump station. And honestly the "Slinky" was getting on my last nerve! So back to the P-P. We could dump it there and clean it good when we got home.
Actually we went through the thought process of using the toilet for both liquids and solids but not putting paper in there. "Dabbing" paper was already being put into a bag just to save space in the P-P. However, "wiping" paper can have a lingering ordor. So it needs to be taken outside and put in the trash or to the camp restroom at first opportunity.
It made sense to put the solids and "that" paper in the same bag and dispose of it. Made the dumping of the P-P a lot less "painful".
As stated above we have gone back to the camper toilet for summer use as it can drain through a water hose, with no solids and no SLINKY to contend with.
Kip
Old 07-27-2011, 05:29 AM   #40
Kip in Ga.'s Avatar
Hi Sharon,
I've never considered that! It makes sense. Thanks for the tip.
Think we will try Darnelle's idea of Mr. Clean. That would be a cleaning agent as well as odor control.
Kip
Old 07-27-2011, 05:39 AM   #41
Kip in Ga.'s Avatar
Disclaimer
A tip from Sharon: Very possible that Using Clorox or other types of bleach in a Porta Potty or Camper toilet's holding tanks, for odor control, could result in harmful vapors when mixed with Urine.
A tip from Darnelle to try Mr. Clean seems like a much better choice. Or just stick with the Blue Stuff.
Kip
Old 07-27-2011, 08:57 AM   #42
Do try the Mr. Clean -- we love it. Have used some blue stuff in pre-measured packets and even then the PP starts stinking.
It will be interesting to see if Mr. Clean works in tanks and how much is needed. We use a "splash" -- maybe 1/4 cup at first use.
Scamp porta potti jamessue Plumbing | Systems and Fixtures 3 09-07-2008 09:24 PM
Porta-potti stuff (the liquid) Bobbie Mayer Problem Solving | Owners Helping Owners 3 07-18-2008 11:16 PM
Porta Potti Mods Pamela S. Modifications, Alterations and Updates 6 06-26-2008 09:15 PM
Porta Potti for Trillium 1300 Lenna F Problem Solving | Owners Helping Owners 5 05-20-2008 04:41 AM
Porta Potti LEAK mikecontos Plumbing | Systems and Fixtures 11 03-29-2008 12:56 PM
