Escape 5.0TA storage question - Page 2 - Fiberglass RV
Old 10-30-2014, 11:26 PM   #15
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Originally Posted by Bob and Julie View Post
So I was looking in my tow vehicle owners manual and it says that it was not intended or designed to haul a 5th wheel. My vehicle is a "heavy half" 1500 Sierra so it is more than capable. My concern would be insurance in case of an accident. It may be an excuse to not to cover or drop our policy. I guess a call to USAA will be required.
Hi: Bob and Julie... The Nissan Frontier manual gives the same "Not intended" etc!!! I don't think they're acquainted with Escape Trailers. With a 6100# tow capacity I have no problem towing a 3700# 5th. wh.
Old 10-31-2014, 06:23 AM   #16
Trailer: small
State
Just curious about these trucks that are not rated for towing 5th wheels -- is it possible that they have composite, plastic or aluminum floors on the truck bed, rather than steel? Clearly, the drivetrain is suitable for towing, but is there a possible question of whether the mounting point can handle the stress?
Mr. W. is offline   Reply With Quote
Old 10-31-2014, 06:37 AM   #17
cpaharley2008's Avatar
Only your mechanic or dealer can answer that or even a hitch installer.
Jim
Never in doubt, often wrong
Old 10-31-2014, 07:11 AM   #18
Trailer: 2011 Chev Silverado
Halifax, Nova Scotia
I spoke to the dealer before I went forward with buying one. They sort of chuckled at the weight and said there would be absolutely no problem.
Min D is offline   Reply With Quote
Old 10-31-2014, 07:23 AM   #19
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
The 5th wheel hitch attaches to the frame of the truck, not the bed floor. They actually drill thru the floor to get to the frame rails.
The only truck I'd think might be problematic would be a Honda Ridgeline. I'm not sure they have a frame to attach to - aren't they unibody like cars, vans, etc.?
Follow my blog - http://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 10-31-2014, 10:12 AM   #20
Trailer: Escape
We are skirting the salient aspect of this discussion. What would the Insurance Company say or do in the event of an accident? We all know that these vehicles can physically handle the Escape 5th wheel trailers.
GerriJ is offline   Reply With Quote
Old 10-31-2014, 10:27 AM   #21
Alf S.'s Avatar
Hi: GerriJ... I think we all know the answer. Any liability insurer will try to deny liability!!! Specially those owned by "Shareholders". That's why I switched to a Mutual insurer. Owned by the policy holders.
Old 10-31-2014, 11:19 AM   #22
Trailer: Escape
Alf, I agree, my parents were both Auto Insurance agents in B.C., both before and after ICBC. My remark was somewhat rhetorical. Its just that if your vehicle owners manual says your vehicle is not suitable for towing a 5th wheel trailer, but you do anyway, and you are involved in an accident, and as in my case, have no choice in the insurer I use you may be in trouble. Like you it may be prudent to eliminate one or more of these if's.
Mark
Old 10-31-2014, 01:05 PM   #23
Trailer: small
State
This is true, but the bed generally does not sit directly on the frame rails. It sits on rubber spacers, so when bolting the 5th wheel in, they have to put in spacers. I was just curious if the stresses of accelerating a larger trailer from a stop might cause issues to a non-steel truck bed between the spacers, or more to the point, at the edge of the spacers. Dunno. Might have nothing to do with it.
Agreed, first of all, that when they "forbade" 5th wheeling, the Escape 5.0 probably isn't what they were picturing. Agreed, second of all, that in the case of accident, the only thing the insurance company will care about is whether the Escape 5.0 is a fifth wheel or not.
Old 10-31-2014, 01:10 PM   #24
Bob and Julie's Avatar
Trailer: 2015 Escape 5.0TA
Send a message via AIM to Bob and Julie Send a message via MSN to Bob and Julie Send a message via Yahoo to Bob and Julie
I have sent an email to GMC asking for an explanation. My guess is that since my vehicle is a short bed at 5 ft. 8 in., they are concerned about be contact. Maybe They haven't heard of slider hitches. Even with my short bed, I believe the 5.0TA is designed to accommodate with no need for a slider. I will also contact my insurance company.
2015 Escape 5.0TA
2013 GMC Sierra Crew Cab max tow, 6.2 ltr, 3.73
Bob and Julie is offline   Reply With Quote
Old 10-31-2014, 01:19 PM   #25
Reace posted pictures when the 5.0TA was first put into production. He owns an F-150, short box. Here's what he said and the pictures he posted.
"Center of hitch is approx. 30" back from cab. Box length is 5'-6".
Keep in mind, this unit was raised for a taller truck!
I turned the trailer almost 90 degrees, and still have approximately 1" space before the trailer would hit the cab of the truck.
Also a photo hitched up with tailgate down.
I love it when a plan comes together!"
Old 10-31-2014, 01:31 PM   #26
honda03842's Avatar
Name: Norm and Ginny
It's obvious that GM is not even aware of small fifth wheels.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-31-2014, 01:56 PM   #27
In the 2011 GM/Chev manual for my 1/2 ton this is what it says:
5.3LV8 K5L HD Cooling Pkg
Conventional Trailer 3.42 4 218 kg (9,300 lbs)
Fifth-Wheel Trailer 3.42 3 629 kg (8,000 lbs)
1500 Fifth-Wheel Gooseneck 680 kg (1,500 lbs) max tongue weight
That is what I went by, unless something has changed between the years? you might want to ask that question.
escape
Boler front storage question DannyH General Chat 7 04-18-2009 04:53 PM
RonSmith100's question about image storage and bandwidth ronsmith100 Forum Admin, News & Announcements 3 05-30-2008 11:57 PM
Escape Trailer Storage Boxes Thane Modifications, Alterations and Updates 5 03-27-2007 06:53 PM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 09:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
