Escape Insulation Package vs Bigfoot 4-Seasons Insulation - Fiberglass RV
Old 05-19-2018, 05:02 PM   #1
Jane P.'s Avatar
Trailer: Bigfoot 19 ft
I'm reallly, really ... really ... curious about how the Escape Insulation Package - including form on the underside - compares with the Bigfoot's 4-season's insulation. I see that several FGRV'ers have bought Escapes.
I do a lot of winter camping in Northern California and Spring camping in the Pacific Northwest and Rockies. Not knowing much about Fiberglass trailers, I went to my first FG rally wanting to see which Casita I should buy. A Bigfoot 21 lady convinced me that I really needed the 4-seasons for the type of camping I was planning. My first big trip with my new-to-me-trailer was into Utah by way of Colorado, then onward to Montana and Washington. It was April, I woke of several monings in the snow & never regreted the extra insulation.
Now that my husband in joining me on trips the Escape Queensize beds look really good to me. But what about that insulation?
'92 Bigfoot 19' | '07 Chevy Tahoe
Jane P. is offline   Reply With Quote
Old 05-19-2018, 05:15 PM   #2
Trailer: Casita 17 ft DLX SD
An Escape is not designed , built or advertised to be a true 4 season trailer .
I would stick with your Bigfoot !
Old 05-20-2018, 02:34 PM   #3
Trailer: Shopping
Ohio
I would say more like 3-1/2 season. I have a 21 with foam, extra insulation , and double pane.
CarlN is offline   Reply With Quote
Old 05-20-2018, 04:28 PM   #4
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
True 4 season trailer
Jane P.,
If you have a 1992 19 ft. Bigfoot you don't own a true 4 season Bigfoot trailer because they didn't come out or build those until about 2006. I see a lot of mis-advertising with people thinking because it is a Bigfoot it is a 4 season trailer- wrong. We have owned 8 Bigfoot's and only one of them ( 2007) was a true 4 season trailer. But we have also camping in -4F ( snowing) and 100+F and been totally comfortable with the standard and pre-2006 Bigfoot insulation core system. Watch the recent "How it's made video from Escape Trailer Industries on You tube to see the new insulation process they offer. With their new body style ( new molds) they are looking more and more like a Bigfoot.
Deb
Deb & Chuck is offline   Reply With Quote
Old 05-20-2018, 04:33 PM   #5
I would think that a lot depends on where you live and camp
Here in Northern Wisconsin and the UP of Michigan it is probably a 2 1/2 season trailer in middle America probably 3+
We had snow on the ground and ice on the lakes past May 1st this year in our area We had 38 degrees the other morning and they had frost on Minnesota’s Iron Range .
I realize that if you pump enough heat and have enough money you can heat anything
Old 05-20-2018, 04:55 PM   #6
rbryan's Avatar
Arkansas
Originally Posted by Deb & Chuck View Post
Jane P.,
Deb
No doubt the insulation has gotten better over the years Deb. I wish my 19 had the closed cell foam insulation instead of the reflectix they used in 2015. But, the issue isn't really the insulation in the walls, but the exposed plumbing and tanks. For a true 4 season trailer that all needs to be enclosed.
For us, an Escape "is" a 4 season trailer, but only because we live in South Texas, and we don't winter camp up north.
Old 05-20-2018, 06:09 PM   #7
Trailer: 2015 Escape 19'
Wisconsin
We have a 2015 Escape 19 and have been in 19 degree (Fahrenheit) weather in the Rocky MTS with no serious issues. The heater was very effective and we were very comfortable. We did open the doors under the bed to ensure that heat was able to get to the water supply, and that was fine.
bjsmitty is offline   Reply With Quote
Old 05-20-2018, 08:01 PM   #8
rbryan's Avatar
Arkansas
We've done the same BJ, with the same trailer. Camped all over the rockies when the nighttime temps dipped into the upper teens without any issues. Just remember to disconnect your water hose or you'll have a popsicle in the morning. Temps that dip below freezing overnight aren't an issue. It's sustained camping below freezing where you soon realize exposed tanks and lines aren't going to cut it.
Old 05-21-2018, 12:29 AM   #9
Jane P.'s Avatar
Jane P.,
Deb
Hi Deb,
Wow, that is a surprise to me: The underside of my trailer is completely covered - pipes, etc are protected from elements. Windows must be double payned as there is no condensation. What do I have if it is not a 4-season Bigfoot?
Old 05-21-2018, 08:19 AM   #10
Originally Posted by Jane P. View Post
Hi Deb,
You can tell pretty easily if the windows are thermal- a careful look at a pane should reveal two pieces of glass with a black seal between. The issue with holding tanks is whether the furnace is ducted to provide heat to the tank area. Just being covered is not enough.
I know that newer Bigfoot 1500-series models (designated 15BXX) do not have the full 4-season upgrades, while the 2500-series (25BXX) models do. I'm not sure how cold-weather upgrades were packaged on older units. I would be curious what you have.
Old 05-21-2018, 01:19 PM   #11
Name: Josh & Sonya
Trailer: '97 Casita SD 17; 03 Bigfoot 25RQ
Bigfoot four season insulation package
Hi Deb,
We have a 2003 Bigfoot 25RQ that we bought used in 2015. It definitely has the four-season package, which was offered as an option. I think the extra package might have been offered on models from early on; not sure about that.
As indicated by one of the other posters, if you have a model 2500, you have the package, which includes the higher density insulation, double pane windows, as well as covering for the tanks underneath the trailer.
Though the "new" Bigfoot (from 2010 forward, after the bankruptcy) doesn't seem to have access to prior sales records, you might be able to get the answer to the question about the insulation on your current unit if you contact Bigfoot with your VIN number.
Josh and Sonya W is offline   Reply With Quote
Old 05-21-2018, 07:47 PM   #12
Trailer: 2017 19' Escape
Not sure about Bigfoot, but a 19' Escape with all the insulation options can handle multiple overnight lows in the 4-8F range. It burns through a tank of propane every 2-3 days though, and any lower would definitely be a problem in terms of condensation and freezing pipes.
Old 05-22-2018, 10:40 AM   #13
Jane P.'s Avatar
Hey Jon, I am now curious to see what I have. What do they say about the word "assume"?). To answer your first point, I definitely have thermal windows.
Deb & Chuck are the acknowledged Bigfoot experts, and she seems to be stating that thle term "4-season trailer" did not come into being before 2006.
So, perhaps the fiberglass community began to interchange insulation upgrades with 4 seasoned trailer - like referring to "Xerox" instead of "copy machine". Per Deb, maybe we should be more precise with our terminology and reference pre 2006 Bigfoots as having "cold-weather upgrade package" or "insulation core systems" - which I am confident I have, given the cold, stormy weather conditions I have encountered. By the way, I am also comfortable in warm weather (though I still want a rear ceiling fan).
Now, when I began looking at older Bigfoots I did contact Bigfoot owners on this forum for information. Among other things, I was advised that it's important to look at the underside of the trailer to see if it is covered. It was my understanding that if unless the underside was covered, it was not a 4 seasoned trailer.
I also read that, in the Bigfoot 4 seasoned trailers, the furnace worked in conjunction with the plumping and tank to provide protection. But I never found any written information on how that worked. Given Deb's post, I now wonder if that integration referred to the newer models manufactured after my 2006.
I have the heater on a thermostate which I lower to 63 degrees at bedtime. I am able to sleep comfortably in 30 degree weather without it kicking in more than once or twice during the night. So, the heat doesn't escape through the trailer walls. I have traveled throughout the rockies and the pipes & water tank remain clear in freezing weather. I camped a lot of rainy days in Northern California & the Pacific NW, with no condensation. So, if the trailers manufactured in the 90's were not "true" 4 seasoned, they did have effective insulation.
And, hey, maybe the Escape installation package is closer to my Bigfoot than those post 2006 models.
I'm looking forward to hearing from owners of older Bigfoots who have moved onto Escapes.
Old 06-02-2018, 10:56 AM   #14
Trailer: Escape 17B
Vermont
Escapes problem is that the gray and black water tanks and discharge lines are outside the heated space. Even with several gallons of pink stuff, the resulting slurry won't flow so you can't dump. Look at Lance or Oliver Trailers for more robust winter capability. Oliver is very capable but SO expensive.
yardsale is offline   Reply With Quote
bigfoot, escape
MERRY CHRISTMAS--SEASONS GREETINGS Marg General Chat 14 12-26-2008 01:17 AM
Seasons Greetings Ken James General Chat 22 12-24-2006 06:51 PM
Seasons' Greetings Ken James General Chat 23 12-27-2005 02:33 PM
Our EGG at 4 Seasons Legacy Posts General Chat 0 05-14-2003 09:24 PM
