Fantastic Fan and Battery Drain - Page 2 - Fiberglass RV
Old 03-16-2011, 10:28 PM   #15
Mike Magee's Avatar
Trailer: Li'l Hauley
I believe it's fairly likely that a battery in decent shape could run such a fan on low for about three nights without doing any harm. If I'm figuring correctly, with a typical small battery rated at about 85 or 90 amp-hours, three nights of just the fan should take the battery charge down about halfway.
How to prepare Tofu
Step 2: grill some meat
Old 03-17-2011, 06:18 AM   #16
Joe Z's Avatar
New River AZ
My Fantastic fan on "Low" draws just under 1 amp so if i ran it for 3 nights at 8 hours each night that would be a total of 24 amps.....use the thermostat on it and you can drop that figure even lower. I really like that fan as it moves a lot of air and is very quiet.
Joe
Old 03-17-2011, 11:07 AM   #17
barryra's Avatar
Trailer: 1993 13 ft Scamp
When you charge your battery out on the road/campsites... do you use a regular AC battery type charger? Do you need to unhook everything from the battery while charging? Thanks
barryra is offline   Reply With Quote
Old 03-18-2011, 12:36 PM   #18
Trailer: Oliver Legacy Elite 2008
Originally Posted by melissab View Post
. . . can the fantastic fan run all night without draining the battery to the point of damaging it? . . . trying to figure out the best way to move air while sleeping. Any suggestions or should we just plan on hookups til we get to higher elevations?
The first summer with my trailer, I ran a test of my solar panel / fantastic fan setup. I unplugged the trailer from shore power, enabled the 100W panel, and turned the fantastic fan on low with the thermostat set cool enough to ensure it'd be running 24/7. (My batteries have 110 Amp Hours of energy storage capacity combined.)
The test continued day and night for 30 days. After a month, the batteries were working just fine. That was 3 summers ago and I still have the same batteries which are doing great. I don't imagine you'll be harming your battery using it for the fan on low at night and allowing it to recharge from you vehicle's alternator as you head to your next destination.
Pete is offline   Reply With Quote
Old 03-18-2011, 11:08 PM   #19
Gina D.'s Avatar
West Coast USA
I have been running my Endless Breeze fan (A portable version of the Fantastic fan made by the same company) all day long for over a month now. It often runs for a couple hours in the evening when I get home as well.
I am using a 100w solar set up and a group 29 battery (120aH). I have no want for battery power for lights or water pump etc each day.
Keep in mind, I am stationary and have no other way I charge my battery.
I could use a charger when I run my generator, but I just don't need to. You should be fine with an average charging system.
battery
Fantastic Fan question Sandra Lair Problem Solving | Owners Helping Owners 5 07-22-2008 10:07 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Roger Harshaw Problem Solving | Owners Helping Owners 4 03-15-2008 12:47 AM
Fantastic Fan question Sandra Lair Modifications, Alterations and Updates 17 08-08-2006 06:33 AM
Fantastic Fan new installation... MikeAg Problem Solving | Owners Helping Owners 1 04-18-2006 06:10 PM
