Fiberglass Class Cs? - Fiberglass RV
Old 05-16-2016, 10:01 AM   #1
Trailer: Currently Browsing
Connecticut
My research has been almost exclusively about fiberglass (egg) travel trailers. I'm adamant with my SO that we purchased a fiberglass RV of some sort due to long term longevity of them vs. stick built RVs (Living Stingy: The RV Industry's Dirty Litle Secret: Quality).
But... we've never RVed before and we're not quite sure what we will prefer while fulltiming (truck and trailer vs. class C most likely), and to be honest, the interior space of a class C and price point is appealing.
So since I haven't come across much info on it yet, I'll ask...are there modern, fiberglass class Cs out there? Are they fiberglass all the way through (wood bad! )? Or are they just a fiberglass cap on the entire roof (that could be decent) or partial fiberglass on the overhanging cab (not as enthused)? Seems like if you prevent water intruding from the top, you ~may~ just be fine with the walls being stick built?
Bster13 is offline   Reply With Quote
Old 05-16-2016, 11:03 AM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Hi Bryce. I don't know of any MODERN all molded fiberglass class C's out there, but that is not my focus. If you think of any type of camping unit as a bubble, and as it travels down the road it undulates under all the external stressors. Since the bubble has no seams (usually the only seam such as in a belly band is glassed together) there isn't any leaks. Now think of a bubble made up of many steam such as in a partially molded fiberglass or full sticky, and as they undulate down the road the glues, screws, sealants start letting lose and water will find those areas and the damage starts. It has been experienced here by others, when you are not sure which way to go (type of camping unit), just purchase a very good used all molded fiberglass trailer so if you find that it is not a good fit, you can always sell it for what you have invested, but it will not work out for you that way if you start with a sticky and change your mind, as you rarely get your money back. Best of luck with your decision.
Dave & Paula
Old 05-16-2016, 11:08 AM   #3
Prior to the bankruptcy, Bigfoot made the Born Free class C (all molded). Still some out there on the used market. Don't know if Bigfoot will ever start up production again of this RV.
Old 05-16-2016, 11:26 AM   #4
Trailer: Bigfoot B-17 CB
Bigfoot made some pretty nice motor homes but stopped when the new owners took over. They were NOT molded 2 piece units like the trailers, campers and 5th wheels. They were made from panels over a framework (aluminum ??) and quality was considered better than average. Bigfoot also made a few trailers using the same construction of panels over a framework. They were called Columbia River models. A few years ago I saw a Craigslist ad for a Bigfoot trailer at a very low price. It was a "Columbia River" unit and the ad said "water damage repaired " , of course molded units could leak to, but it was listed on Craigslist for months before being sold.
I would like a molded fiberglass motor home too but that may never happen. I would consider a Bigfoot even though it is not molded and I've also researched Born Free, which are fiberglass and have a very good reputation, but not exactly molded construction. The motor home I find most appealing is a Lazy Daze and it's not even fiberglass. I do not want slide out's. Most likely if I do go the motor home route it will be the Lazy Daze.
Born Free is probably the closest to a molded 2 piece FGRV, but not exactly. Good luck in your search.
Old 05-16-2016, 11:37 AM   #5
I better go get Roger, he owns a Born Free....
Old 05-16-2016, 12:20 PM   #6
Connecticut
yes, slide outs are "out." Didn't even think I had to mention that, haha.
I'll research Born Free and Lazy Daze and try to find out what makes them less prone to leak vs. others. Thanks!
Old 05-16-2016, 12:29 PM   #7
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
Hi Donna! Thanks for inviting me to this thread. I'm actually on my second Born Free moho now. The only full-molded fiberglass moho I'm aware of are the Chinook B+ coaches. All the rest that use fiberglass have seamed panels.
Having had Airstreams for twenty years, and then a dozen various molded fiberglass trailers (including two Bigfoot trailers, a 17' and a 25') for a dozen years, and now motorhomes, I can tell you that the leak issue is over-stressed for seamed fiberglass units, and under-stressed for fiberglass trailers. Modern sealants (and seams) are not what we saw in the '70s and '80s. There are '70s Born Free units still coming onto the market today and other than the groovy orange, green and yellow shag carpet interiors, they're as sound as they were when they left the factory. I recently saw a classified ad for a '76 Born Free and it looked pretty amazing.
Lazy Daze is Born Free's chief competitor in class C coaches. Their quality is comparable. I like Born Free's styling much better, honestly, and Born Free's engineering has progressed by leaps and bounds since I bought my first '01 coach in '07. I now have an '06 32' rear queen model on the Chevy Kodiak chassis.
This Born Free will likely be the last RV I buy. While it's not perfect (I've never found the 'perfect' trailer/moho) it's close enough that after nearly 35 years, I don't have a need to look for anything else. The quality, fit, and finish of Born Free coaches are on-par with Class A mohos in the $750k to $1mil range. What has really sold me on them, though is the factory. They're a low-production number family-owned and operated (until this past year) business. You can call the factory and talk to the service manager Kim Olson who has, at his fingertips photos and the entire line sheet on your coach. Kim knows his Born Free customers by name. I've called him from Denver, CO while I was on the road with a service question, and he called back within 10 minutes with answers. Just try to get that kind of service from any other manufacturer!
A coach is a collection of after-market parts built on a chassis supplied by an auto/truck manufacturer. The only thing that the coach manufacturer can call their own is the box and the way the box is assembled. Born Free has never had a fatality in one of their coaches. Each coach has three roll bars built into the box, and all of the cabinetry is real wood and is built from scratch in their own cabinet shop. Everything else is sourced from top-quality suppliers, but are readily available after-market as well.
I'm well satisfied with my Born Free, and I don't know too many Born Free owners who aren't satisfied with theirs.
So, there you go!
Roger
Old 05-16-2016, 12:37 PM   #8
Learn something new every day. So... the Born Free image below is not all molded, sure looks like it.
Old 05-16-2016, 12:48 PM   #9
Coach House motorhomes are molded fiberglass. They even take it a few steps further with one piece inner and outer shells. There is no belly band. The quality is exceptional and so is the price. Most are fully painted on the outside and the finish is very attractive. If I buy another RV this is what I'll most likely get.
Beeser is offline   Reply With Quote
Old 05-16-2016, 12:49 PM   #10
Connecticut
And to contradict, this post states Born Free ~are~ fully molded (but the post is from 1998).
https://groups.google.com/d/msg/rec....g/nDGmnQXxYlUJ
Old 05-16-2016, 12:55 PM   #11
I don't see that... " One is that the Born Free is an all fiberglass outside "
which is different than all-molded.
Old 05-16-2016, 12:58 PM   #12
Connecticut
Ah, thank you for the clarification.
Old 05-16-2016, 12:58 PM   #13
Was there ever any relationship between Bigfoot and Born Free ?? I thought they were competitors ? Born Free in Iowa and Bigfoot in BC.
Old 05-16-2016, 01:32 PM   #14
Oh man see why I should never get involve in motorhome discussions. Let's talk all-molded-towables
Class? What "class" is a Casita? Susan K. General Chat 4 02-21-2010 05:52 PM
Are Fiberglass Class B/Class C's Discussed Here? Verbotten? Suzanne P. General Chat 1 05-12-2008 08:49 PM
Class 3 vs class 2 DonInChatt Care and Feeding of Molded Fiberglass Trailers 13 12-18-2006 06:36 PM
Prince Edward Island Fiberglass with Class Meet 2006 KARL PROUDE Rallies, Get-togethers, Molded Meets (Archive) 11 05-31-2006 05:14 AM
Class? What "class" is a Casita? Darlene B Classified Archives 0 12-31-1969 07:00 PM
