Fiberglass Construction Techniques - Fiberglass RV
Click Here to Login
Old 02-27-2009, 12:13 PM   #1
Trailer: Bigfoot 21 ft Rear Bed
I've noticed that a few molded fiberglass RV manufacturers recess the areas around access doors, etc. instead of simply cutting out the fiberglass to receive a surface mounted fixture. How difficult is to form the recess from a manufacturing standpoint? Does it add a significant cost?
Steve Dunkel is offline   Reply With Quote
Old 02-27-2009, 02:57 PM   #2
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
good question
Phil & Denise Underwood
1973 13ft Lovebug
1998 17ftCasita FD
Phil Underwood is offline   Reply With Quote
Old 02-27-2009, 04:06 PM   #3
Trailer:
It appears to take no effort, because the mould provides the shape, but that's not quite true. There are two 'costs':
- the edges of the recess will require just a little more work when rollering-out (consolidating) the 'wet' fiberglass than a flat area;
- just occasionally a defect may occur on the edge of the recess, requiring a small repair before the trailer is finished, that wouldn't happen if there was no recess.
Actually coming up with numbers for those 'costs' would be very difficult, but I would guess they are at the 'some tens of cents' size. But in return, the recess defines where the fixture must go, which otherwise might require the use of a measuring tape, with the risk of an expensive mistake every 100 trailers (or whatever) of putting the fixture in the wrong place.
Andrew
Old 02-28-2009, 09:33 PM   #4
Trailer: Escape Manufacturer
The recessed areas are not difficult to add when building a mold and some fiberglass trailers do incorporate them. The down side is it doesn't leave a lot of options for customizing to the customers' needs.
I once considered recessing the tailights into the body similar to a motorhome with a fiberglass end cap. After looking over the catalogue for the light design I wanted, I phoned for a sample and found it had been discontinued. You could imagine having to redo a trailer mold because the tailights had to be changed.
When they quit making the Bargman L-400 latch, we had to make a new door mold to accept a newer style latch.
Things always change just when you don't want them to.
Reace
Reace is offline   Reply With Quote
Old 02-28-2009, 11:05 PM   #5
Alf S.'s Avatar
Hi: All... Isn't fitting the windows into a flattened area of the fiberglass better than fitting them into a curved area??? Don't the creases give the shell some extra rigidity???
Just my two questions worth!!!
Escape construction question Ken C General Chat 36 03-02-2010 12:29 AM
construction question from a newby. Heathc General Chat 29 08-12-2009 07:53 PM
Storage Techniques Parker Buckley Care and Feeding of Molded Fiberglass Trailers 6 09-07-2008 10:36 AM
Interesting fiberglass over foam construction site Ken Dale General Chat 2 05-08-2008 09:18 PM
Scamp Construction Thane K Modifications, Alterations and Updates 2 05-04-2008 12:33 AM
