Originally Posted by Perry J
I jacked my trailer up today to adjust the brakes.
I never looked under it when I picked it up.
The original axle was a leading axle.
The wheel arms pointed forward.
Bud took it on himself to really modify the frame.
Now The axle is mounted farther forward than the old axle but is now a trailing axle.
I got a better deal than I expected.
John
I had exactly the opposite happen to me. I could see the frame of the
Trillium 1300 I was looking at was odd. It was made of C channel, or so it seemed. The mosquitos were vicious! I looked at the inside of the trailer carefully, but not so close to the outside. On the way home I stopped for gas and got my first look at the under side of trailer.
Leading axle.
I have no idea what trailer this frame came from. It is not Buba engineered. The front still comes up to a higher level at the
propane tank shelf. Those "bends" are accomplished by pieces of bent 1/8" steel plate that is formed into a C channel, but not square. They are a taller C at one end then the other. The pieces fit too well at the welds for it to be a one off. I have actually seen an ad for another
Trillium 1300 which clearly had a C channel bumper, so maybe there was a line of leading axle
Trillium 1300's,
This is why I am looking for a replacement square tube steel Trillium 1300 frame.
