First towing impressions with the McMansion - Fiberglass RV
Old 03-08-2007, 09:26 PM   #1
Gina D.'s Avatar
West Coast USA
The big ole' 17 has been sitting in my driveway since I brought it home near a month ago. I have been waiting for some equipment and scheduling to have the safety checks done and wdh installed, propnae sussed out (Kurt, he found the leak in the front line) before I towed it anywhere, just as a precaution.
I had no choice but to tow it "down the hill", unequipped, to the flatlands where the welder is.. a 50 mile trip from 4600 feet down to the valley floor, and on 2 of the busiest freeways in So. Cal.
It actually did pretty good as is. I was concerned about the brakes, as when I towed it home, one side seemed to grab better than the other and it pulled a tiny bit to the streetside. It straightened out while going down the hill. Probably it loosened up and all the rust and mung from sitting for years broke loose.
I did fine on the freeway, the Liberty has plenty of power and hardly struggled. The squat was a bigger issue than speed or strain, and I can't wait to try the WDH to improve the handling.
On the 15, I had a slight wag, but I squelched it quickly with the panic button on the brake controller. The small stain on my drivers seat will come out with some good scrubbing.
Not a week ago, I saw a beefy truck towing a cement mixer at the very same spot, wagging and swaying almost to the point of control loss. First time I have seen this in person. I wonder if there is something with that location? A hump in the lane, crosswinds..??
Anyway, sway control was ordered the second I walked into the shop, and vallium was ordered from my GP via phone seconds after.
The welder installed the WDH and checked the axle and all it's functions. It got an "Excellent" grade, and he said the brakes looked and worked fine, no work needed on them. I forgot to ask about the bearings, I certainly hope he changed them. Even if they are "OK", I have heard they should be replaced anyway after so long. Is this true?
He did the Manometer thing, and found a leak that both Kurt and I noticed right away, up at one of the bottles. He didn't give me specifics, I will find out the details when I pick it up tomorrow.
He also looked at the door, and can remove it and reset the rivets. Looking inside he said "Dang! That isn't a sag, it was installed crooked.. the fiberglass is fine". I will have this done when I take it back for a locking battery box and a generator box.
The question of chains on the tanks. He sees that frequently and wasn't the slightest bit concerned about it. He checked for tightness and said they wouldn't chaffe if they were properly tightenend, bit I will put that on my safety checks when I do them.
The safety chains on the tongue, however.. they were about what I would tow a radio flyer with. I had him put manly ones on
All in all, I am a bit more relaxed and when I pick it up tomorrow I will be "Trained" in how to use the WDH and sway bar. He had never seen a single bat before and thought it was pretty slick. He does mostly horse trailers and large toy haulers, so something this small is cute to him.
sigh.. now if he just did toilets....
Old 03-10-2007, 02:30 PM   #2
Trailer: 2005 13 ft Trillium Outback
Thanks for the report. Glad things are progressing without major problems being found. Did you say which brand WDH and sway control you are investing in? I'm partial to my recently installed Equal-I-zer. Any brand will provide an improvement in load and sway.
Bearings are good until wear is visible. My trailer shop says bearings need repacking (greasing) every 10K miles or 3 years, which ever comes first.
What did you mean by "single bat"? Battery? Are you going to upgrade to 2 batteries while you are having the box built?
Curt
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 03-10-2007, 03:13 PM   #3
Gina,
At the rate things are progressing, I foresee a maiden voyage in the "not too distant" future.
Did you, by any chance, have the propane "pig tails" changed to the new style? That's a mod I want to make for "Nuestra Casita".
If this weather continues like this, I might have to take the time off from house remodelling to give her and the tug spring baths.
Thanks for keeping us posted on your progress,
Kurt & Ann K.
Old 03-10-2007, 07:10 PM   #4
David & Leslie's Avatar
Trailer: Scamp 16 ft Side Bath
So good to read your report that safety assurances & mods are going well - looking forward to getting a peak at your single-bar unit in July. Thanx for sharing the update - LdB
ďImagination is everything. It is the preview of life's coming attractions.Ē A. Einstein
David & Leslie is offline   Reply With Quote
Old 03-10-2007, 11:25 PM   #5
Gina D.'s Avatar
West Coast USA
Curtis.. that was a typo.. it was sposed to say.. single BAR. It has a single bar that runs at the center and under the tongue, rather than on both sides with two bars.
It's a Reese, and the sway bar will also be a Reese, but it did not arrive in time for me to pick up the trailer, so that install will happen at a different time. The next time I take it out, I will bring it down the hill again a day early and have it installed
Kurt, I am on my maiden voyage right now. You were right, the WDH has made a world of difference. It is set up nicely, and I have no trouble lifting it. It does not snap into place, it's a smooth torque. It DOES however, hang very low. I can see possible issues with speed bumps and odd driveways.
New to towing :D JonE Towing, Hitching, Axles and Running Gear 3 07-13-2009 09:05 PM
Towing Jamie Towing, Hitching, Axles and Running Gear 20 08-15-2007 05:16 AM
Towing in OD? Legacy Posts Towing, Hitching, Axles and Running Gear 18 05-18-2003 07:30 AM
Towing 101 Legacy Posts Towing, Hitching, Axles and Running Gear 22 05-08-2003 07:44 PM
TOWING WITH A S-10 Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
