Fresh water tank - Fiberglass RV
Old 05-16-2015, 08:34 PM   #1
Trailer: 2014 Parkliner
Fresh water tank
Hi,
I have just purchased Rhonda's PL. [previoslly Gretchen's]. We drove from Durham, NC to Clarksville Tn. Heading back to NC tomorrow.
My Q relates to the 15 gal fresh water tank. Normally most owners hook up to the "city" camping site supply. Got that.
However,when I disconnect from the water supply, I can't get the water pump to supply water. My thought was that perhaps the 15gal tank has no water so the pump won't pump. But, I tried to fill the water tank at this camp, assuming that if there was water in the tank, the pump would actuate.
But no. With in a few minutes of trying to fill from the FRESH water connection, water started coming out from a small "weep" hose below the quarter panel closest to the connections.
My thoughts are that perhaps there is a separate valve that re-directs the campsite "city water" intake to the "fresh water" side, allowing the tank to fill and the water pump to pump when not hooked up to power.
Guidance?
George
I wish there was a PDF owners manual available from Parkliner
GeorgeH is offline   Reply With Quote
Old 05-16-2015, 08:55 PM   #2
Cathi's Avatar
POBox 1267, Denison, Texas
I am assuming you have your water pump turned on. Are you getting a droning noise? IF so, it is trying to clear the air out, may take some minutes.
Old 05-16-2015, 08:57 PM   #3
Johnny M's Avatar
Deep South
I believe most systems (including mine) have a separate fill for the tank water than the city water connection. Some systems could have plumping from the city water to a fixture and also from a pump/tank to the same fixture using a one way check valve. Most modern pumps have a pressure cut off switch that shuts the pump off when it reaches a certain psi with no water flowing. Also most tanks have a drain, locate it and make sure it is closed. Also check that a previous owner has not disconnected any lines going from the tank...
Old 05-16-2015, 08:59 PM   #4
Johnny M's Avatar
Deep South
Yes, as Cathi said, depending on how much air is in the line or the length of the line from the pump to tank, it may take a minute for the pump to prime the air out before water starts to flow. Also any loose fittings that could introduce air into the line could delay or even prevent priming.
Old 05-16-2015, 09:14 PM   #5
If the trailer was winterized - they may have put a cut off valve between the tank and the pump.
Old 05-16-2015, 11:22 PM   #6
If your pump works like mine, it operates just like a gas pump and shuts off the flow as soon as it detects back pressure.
If there is debris in the faucet aerator, it can cause that back pressure and shut down water flow.
Try removing the aerator and clearing it of debris.
Old 05-17-2015, 05:54 AM   #7
Carl Pa's Avatar
To get water in the fresh water tank you must fill by hand or hose at the fill fixture on the outside of camper. That is how my Scamp works. Unless i don`t get the question. Carl
Carl Pa is offline   Reply With Quote
Old 05-17-2015, 07:16 AM   #8
Trailer: Casita 17 ft DLX SD
There is a filter/screen on the onboard 12V pump. This spring I could get water to the fixtures if I hooked up to city water but not from the onboard tank. I pulled the screen on the pump and it was plugged . Cleaned the screen and everything was fine . We use a Camco water filter to filter the incoming water but our pump screen and kitchen faucet areator were still plugged up!
Old 05-17-2015, 09:44 AM   #9
Well, we figured it out. It was very complicated. After being on my knees looking for the pump switch, my astute wife saw a switch on the wall next to the sink labeled "pump switch". Guess what...it was!
Go ahead and laugh. We did.
Thanks everyone.
Old 05-17-2015, 02:55 PM   #10
Borrego Dave's Avatar
Trailer: Casita SD17 2006
OK George, I did chuckle, only because we ALL have done something like that too
Old 05-18-2015, 08:32 AM   #11
frank_a's Avatar
Trailer: 2012 ParkLiner #006
And here I was just about to chime in with specifics. Glad you figured it out, and got a chuckle out of it as a bonus!
Enjoy that Parkliner!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
frank_a is online now   Reply With Quote
Old 05-18-2015, 09:07 AM   #12
Alabama
Dang! I hate it when people solve their problem before I get my chance to theorize, pontificate and babble on about irrelevant conjectures like I have a tendency to do. That's half the fun of participating in a forum like this! I'm guess I'm going to have to check posts more frequently so this doesn't happen to me again...
parkliner
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
13CT Uhaul Fresh Water Tank Keith K Modifications, Alterations and Updates 2 03-26-2009 06:10 AM
can anyone out there tell me how you access the fresh water tank on a verna crowell Problem Solving | Owners Helping Owners 8 09-27-2008 06:03 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
Larger Fresh water Tank Ideas Steve Rosenberg Plumbing | Systems and Fixtures 8 12-15-2007 06:36 AM
» Trailer Showcase
Yello
pjlatimer
NO YOKE
Ron F
