GAS LEAK - Fiberglass RV
Old 08-31-2009, 03:03 PM   #1
Keith & Beverly's Avatar
Trailer: 2003 17 ft Casita Spirit Deluxe
Send a message via Yahoo to Keith & Beverly
Upon getting ready for this Labor Day weekend trip I noticed an odor of LP in our Casita. I began to inspect each appliance by spraying soapy water on the supply lines and fittings with no luck. So I went to our local RV store and purchased a portable gas leak detector and 4 shut off valves to isolate each appliance unit. Upon installing the last valve for the water heater I found that the supply line penetrating through the floor was seriously corroded. I replaced it and problem solved. After the repair I inspected the remaining lines and found no issues. FYI this maybe a point of inspection for my fellow FGRVer’s . Note this leak was in the floor (not above or below the floor).
Anyhow FYI and We’ll C-ya’s down the road.................
Keith & Beverly is offline   Reply With Quote
Old 08-31-2009, 04:05 PM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
That is scary, and it is not an old trailer either. The copper must have reacted to some chemical used in the makeup of the floors. Definitely something to look for on an annual check.
BTW, thanks for changing to a font my old eyes can read.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-31-2009, 06:13 PM   #3
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
Your battery is closer the propane line ???
If yess , may be an acid leak !!!
The copper tubing do not corrode at normal service
Yvon Chayer
Yvon Chayer is offline   Reply With Quote
Old 09-01-2009, 02:57 PM   #4
<span style="font-size:10pt;line-height:100%"><span style="font-family:Comic Sans MS">Yvon Chayer,
The Casita’s battery is completely seal off from the inside and only accessible from the outside. Thanks for the thought.
Keith</span></span>
propane
Leak? cyndi H Problem Solving | Owners Helping Owners 5 11-09-2009 12:07 AM
Leak! Help! BOBSMITH Problem Solving | Owners Helping Owners 7 10-02-2008 11:38 PM
Need help with leak Brenda Ferrell Problem Solving | Owners Helping Owners 7 01-01-2008 04:20 PM
A/C leak? Linda&Dale Problem Solving | Owners Helping Owners 7 03-11-2007 04:50 PM
Leak Legacy Posts Problem Solving | Owners Helping Owners 5 06-27-2003 03:14 PM
