Gas mpg - Page 2 - Fiberglass RV
Old 09-22-2018, 07:42 AM   #15
Trailer: 2015 Escape
When I hear towing fuel mileage claims most of the time I don’t believe it. I have towing experience going all the way back to 1962 and have towed just about every kind of rv trailer so have a pretty solid idea of what mpg is reasonable.
Old 09-22-2018, 10:12 AM   #16
Originally Posted by gordon2 View Post
All my Toyotas have had a speedometer that read high, and that is very common.
How do you know this?
Old 09-22-2018, 10:12 AM   #17
Trailer: 13' Perris Pacer
Only one way to find out the computer's accuracy: FIND OUT! Fill the tank, record the odometer reading, drive, refill the tank, and calculate the MPG. My 1989 Lincoln Continental was always spot-on. My current 2004 Mercury Sable is always 2-3 MPG optimistic. I guess the technology was better back in the 80's.
mchalewj is offline   Reply With Quote
Old 09-22-2018, 10:44 AM   #18
Life...
Life's too short to spend time worrying about MPGs.... while towing my hotel suite on wheels (with kitchen!) from place to place...whatever it costs...it costs.
I could always "go back in time" and travel by motorcycle with a pup tent strapped on the back of it... stellar MPG numbers there.....but that ain't happening!
Old 09-22-2018, 11:00 AM   #19
minke's Avatar
Trailer: looking
When I was a kid we’d calibrate the odometer using mileposts and assume that the speedometer error correlated. GPSs ended that.
The lie-o-meter on my ‘11 F-250 (anecdotally, I never recorded the numbers) was from .3 to .7 MPG optimistic.
My F-250 died a terrible death (with me in it) in a hailstorm. The lie-o-meter on my ‘17 F-350 that replaced it, based on only three fuel refills, is about .2 to .3 MPG optimistic. On both trucks I assumed that the odometer is correct since the speedometers seemed to have only minor errors.
minke is offline   Reply With Quote
Old 09-22-2018, 11:08 AM   #20
I use my onboard computer to occasionally check my MPG’s more out of curiosity than anything else. I never expected great fuel mileage when towing and have never been disappointed
When we are going on a trip , I am more concerned about getting there safely and comfortably then fuel mileage
If fuel mileage was my major concern then I would probably sell my trailer and stay home .
My vehicle speedometer matches my GPS speedometer exactly . Since I drive the speed limit and seldom faster than 62 MPH , that’s close enough for me
steve dunham is online now   Reply With Quote
Old 09-22-2018, 11:28 AM   #21
Raspy's Avatar
Trailer: 2015 Oliver 23, Ram Cummins
Smith Valley, Nevada
Well, maybe. But what if you are trying to decide whether to by a Ram Hemi or a Ram Ecodiesel. A Honda Ridgeline or a Chevy 1500, with the 5.3.
Knowing the general mileage difference would certainly factor in for me as the price of gas slowly rises to an unpredictable number.
What if you are planning a trip across the country and have no idea of the mileage your truck gets. How do you budget for the trip?
What if your friendly Ford salesman tells you a new truck will get 30 MPG while towing and you are wondering if that's true?
If someone has absolutely no concern for mileage, they should get the biggest gas V8 they can find, preferably a 460 cubic inch model from the 1970s, and tow a 30' square front sticky. Then hook on a jet drive ski boat behind the trailer and cruise at 75 MPH on the highway.
It will be the difference between 2 MPG and 16 MPG with a Casita behind a Modern TV, in other words eight times as much fuel. To me, that is a big difference worth considering when assembling your rig and planning trips.
Once you make the overall rig decision, then it's time to just get on with life and quit fretting about it. But you will at least know where you stand and how to budget.
Raspy is online now   Reply With Quote
Old 09-22-2018, 11:41 AM   #22
Raspy's Avatar
GPS is your friend. Once you work out an error factor, you can adjust the odometer numbers as needed. But you have to make sure not to make the mistake of thinking the speedometer error equates to any possible odometer error.
Automotive speedometers generally error on the side of being a bit fast.
Another common mistake is, after tuning a diesel engine, the mileage appears to go up. Part of that indicated increase is caused by a tuning induced error in the mileage computer. Larger tires are another problem. They roll farther each revolution, but it's harder to make them roll.
Old 09-22-2018, 01:48 PM   #23
Originally Posted by Raspy View Post
If someone has absolutely no concern for mileage, they should get the biggest gas V8 they can find, preferably a 460 cubic inch model from the 1970s, and tow a 30' square front sticky. Then hook on a jet drive ski boat behind the trailer and cruise at 75 MPH on the highway. .
The logic of your statement evades me
Fuel mileage is far down my list of criteria for choosing a tow vehicle yet that does not equate to me buying a one ton dually or a buying a 40 ft 5th wheeler or driving at 75 MPH
If the choice is an inadequate tow vehicle with good mileage or an adequate tow vehicle that gets a few less miles per gallon then I choose the later
Taking an argument to some extreme to prove a point doesn’t make sense either .
There is a lot of middle ground between a Mini Cooper and a semi tractor
Old 09-22-2018, 02:38 PM   #24
Raspy's Avatar
Steve,
Good point.
A lot of times when someone discovered I had a sailboat, They'd ask me if I was some kind of an environmentalist. "Is that why you didn't get a power boat?" "no, I like to sail".
As you pointed out, not everyone wants a one ton dually and a fifth wheel, for reasons other than fuel usage. The better example would be deciding between a Ram Ecodiesel and a Hemi. But at some point, don't we all care about mileage? For example, I know when I venture into Death Valley, it can easily be 180 more miles before I can get fuel again. When droning across the Country, I'd rather put 80 bux in the tank once a day, than twice a day. And you're right, a much better truck that uses a little more fuel is a good choice.
Old 09-24-2018, 11:17 PM   #25
Trailer: Casita 2018 Independence Dlx
Wink MPG
We just never worry about it...We're towing our Casita Indy 17' w the V6 Frontier 2wd CrewCab long-bed truck.. When she gets to 1/4 tank we begin looking for a station with "turning space" for the rig. Of course that 5 gal tank [for the generator] in he truck bed allows us some cheating room. ;-)
BTW we occasionally get asked why we only have a small FG TT. I usually reply that there are only 2 of us, we are good friends AWA married and we HAVE a house already ;-)
Fred762 is offline   Reply With Quote
Old 09-25-2018, 12:06 AM   #26
I just got 10.3 MPG in my 98 4x4 suburban for a 10 day trip in colorado towing the 17 ft bigfoot camper. Normally I get 14-16mpg. Not the best carbon footprint, but I offset it by getting 30mpg in my 96 subby wagon the rest of the time. I like older vehicles I can understand and work on and are cheap to buy and maintain.
mcmars is offline   Reply With Quote
Old 09-25-2018, 11:42 AM   #27
When I was towing my heavy 16' Scamp with my VW 2.0 TDI we got 25 mpg towing and around 40 driving
I calculated at the time that with the higher cost of Diesel at the time a gas mileage of 16 mpg would be the same cost (Diesel was 1/3 higher at the time. ) and the cost to operate the diesel was higher (VW maintenance is expensive and I calculated the $/M and found that any savings was mostly imaginary)
The 2016 Town & Country get 16 - 17 MPG towing and 23- 28 mpg driving.
The cost of operation is lower than the VW Diesel and is easier to get done.
There is no 140K mile required timing belt change at $$ and no 40K transmission service $$ either.
What matters is safety, comfort, and operating cost per mile towing and driving around town etc.
I think the Minivan is a better tow vehicle as it is heavier and most importantly has a hitch that will accommodate a WDH. The VW had no way to install a heavy duty receiver hitch, although it was rated 1800 KG.
MPG makes no difference as long as you have the required range.
What matters is the total cost of ownership with the added cost of towing.
For Sale: '72 Avocado Gas Stove and Gas/Elec Referidgerator havasu Parts: Buy | Sell | Trade 4 05-24-2012 10:19 PM
Just gas or gas/electric water heater? Feedback wanted. Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 09-15-2010 09:11 AM
MPG Adrian W Towing, Hitching, Axles and Running Gear 17 08-28-2009 09:06 AM
MPG: Egg vs Conventional hard sided TT and Hi-Lo types Kip K. General Chat 16 08-27-2007 06:20 PM
MPG Adrian W General Chat 0 01-01-1970 12:00 AM
