This had better be worth it! Jana – I’ll post a pic when some are done, then you can have a look :E and decide if they’re pretty - pretty good, or pretty bad.
I decided to forgo edging for the time being, so I moved on to construction of a couple of the smallest ones. Now I want to be doing edging again – it was WAY easier! I’m a fairly experienced sewer. This isn’t hard, just a lot of work.
Wilma – I totally lucked out with curtain fabric. The store had bolt ends of décor/drapery type fabrics – and I found one right away (mind you I wasn’t supposed to be shopping for the
windows that trip – that’s the secret – pretend you’re trying to find something else ;) ) Actually I'm thinking of doing roman shades with the cords attached to the walls at the bottom so I can control privacy a bit better.
