Ground clearance??? - Page 2 - Fiberglass RV
Old 05-03-2011, 10:13 AM   #15
Greg H's Avatar
Trailer: 72 Boler American
Indiana
That is kinda crazy Kip, considering the crown of the road is the street side of the trailer. The Boler American has everything except the fresh water tank on the street side.
Old 05-03-2011, 01:35 PM   #16
Trailer: in the market
So you're telling me.......
Thanks for all the info; though, it appears that I'm pretty much to my own devices on getting additional ground clearance. That is, I remove the torsion axle and add a solid axle with leaf springs or equivalent. Also, go up in tire size, if the wheel wells will support it. Ouch, by the way.
Any manufacturer's kit or aftermarket availability of such a set-up? I would certainly think there would be a little demand for such a product.
Wow, maybe I just invented a new business, eh?
Thanks.
JimBob
jime444 is offline   Reply With Quote
Old 05-04-2011, 06:21 AM   #17
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Thanks.
JimBob
Right after getting our Casita, I had the wheels and hubs off to repack the wheel bearings. It appeared to me that the spindle arms on the Dexter axles were at an angle allowing the trailer to sit a couple of inches lower than when new.
A local cargo trailer dealer carries all sorts of trailer suspension parts and also works on them. Dexter is one of their main brands. The guy broke out his parts book with pictures, and as it turns out the arms on mine match (pretty close) to one of the choices. There were other choices (angles) that would raise the trailer frame several inches. Replacing the axle, with brakes, would cost about $500 with them doing the work.
Another less expensive idea would be a thick spacer (of your desire) such as "I Beam" or square beam could be welded to the bottom of the frame and the axle attached to the bottom of that. Or a truss could be built and installed to raise it even more.
Seems to me that our FGRVs are sitting as low as possible, to push as little wind as possible, keep the center of gravity low, and still be able to drain the gray and black tanks. Raising the trailer could have both good and bad consequences.
Kip
Kip in Ga. is offline   Reply With Quote
Best location for a ground DannyH Problem Solving | Owners Helping Owners 11 11-18-2010 08:30 AM
Where is the ground hiding? Kevin A Problem Solving | Owners Helping Owners 11 04-30-2008 10:20 AM
ground question Randy Dewey Problem Solving | Owners Helping Owners 6 07-30-2007 11:46 AM
Camp Ground Books D Tharp Care and Feeding of Molded Fiberglass Trailers 32 02-14-2007 08:23 AM
Ground Clearance for Eggs Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-30-2002 10:16 PM
