I received a good price from our local
U-Haul trailer place on install of 7 Pin plug. Less than $100 as I recall. More like $75 including the plug.
Turn, brake, and running
lights will typically already have a connection box at the rear of the vehicle. Those wires are probably plug-n-play.
Existing brake controller wiring is variable. Some have a plug just for the controller under the dash and all the wires are already run. Plug-n-play. Others may have plug for some of the wires but still need a power wire hooked in or pulled to the hitch. Tow package would make me think it has at least some of this. Jeep dealer is best person to take a look and tell you what you have, and what will need to be added.
Power wire for charging trailer
battery probably has to be pulled, a note on that. You want at least 10 gauge wire, not all trailer places will have it. If you can get 8 gauge that is even better. Bring that up before hand, you may have to bring your own or give them a chance to get some for your job. You can get it by the foot at big box home improvement stores.
You want this power wire hooked to an accessory circuit! Not directly to the
battery. Otherwise if you leave your camper plugged into the hitch you can draw down the tow vehicle
battery by running things in the camper. On an accessory circut when you turn off the car the power wire is off.
Long run of wire drops the voltage at the far end. Thinner the wire more voltage drops for the same distance. Voltage at trailer has to be greater than existing battery voltage in order to force a charge into the trailer battery. Our trailer place did not have anything thicker than 12 guage in stock. Suitable for charging the battery for break away emergency
brakes on a utility trailer not thick enough to charge a camper battery.
