Hey Web Guy Check this out ! - Fiberglass RV
Old 01-13-2008, 07:23 PM   #1
Trailer: 2001 13 ft Casita Patriot Deluxe modified 1969 25' Airstream Trade Wind
Hay Mike this is the rig for you !!
Glen & Jane G.
2001 13' Casita Patriot Deluxe (Modified)
1969 25' Airstream Trade Wind (Modified)
Glen G is offline   Reply With Quote
Old 01-13-2008, 07:34 PM   #2
Chester Taje's Avatar
Kool Rig but i saw it here once before.
Old 01-13-2008, 08:51 PM   #3
I know I did it a long time ago
Glen & Jane G.
Old 01-13-2008, 09:14 PM   #4
Mike forget the BF THIS is what you need
Now here is the rest of the story
The merger with Summit Coaches, Inc has resulted in Madison Bay Holdings acquiring the right, title, and interest to manufacture and market the revolutionary "Stiletto" 5th wheel coach.
The Stiletto features a patent-pending, 4-wheel air ride suspension, and is the only recreational vehicle that can be lowered the ground level or raised up to 20" of ground clearance. The Stiletto is the result of forward thinking and is a quantum leap in technology in the recreational vehicle industry. The quality, style and flexibility of this coach are unmatched by any company product.
From a distance or up close, the Stiletto commands attention! The body is constructed utilizing the latest advances in maritime and aerospace composite materials. The shell is built with molded fiberglass without the use of any wood products, creating a body that prohibits rust, rot, or leaking. The result of this fabrication process gives the body unsurpassed strength and durability while providing a lightweight and highly insulated coach.
Construction
The 38-foot Stiletto fifth-wheel is not only shaped radically different from any other trailer, it also employs construction techniques and engineering principles from other industries such as automotive, aerospace and marine into the RV industry. For example, instead of the typical flat-panel stick construction, we use the coach's form as the structural component.
The Stiletto has no framework. Instead, it is made from structural composite. Its various curves and arches are what create the trailer's structural integrity. The Stiletto uses a two-piece, nine-layer shell comprised of fiberglass and high-density foam with bonding agents, which is then vacuum-drawn. The pieces are joined in similar fashion to a deck and hull on a yacht. There is no plywood in this coach, it's all composite -- the flooring, the interior walls, the studs ... everything. The only wood is the solid hardwood cherry cabinetry inside. Underneath the unique body is a 2" x 8" x 5/16" tube steel frame, which is actually integrated into the body mold. Channels in the shell accommodate the chassis rails, and then the shell is bonded and bolted to the chassis. Instead of traditional axles and leaf springs, the Stiletto rides on four-wheel independent air suspension, featuring control arms made of 1.5-inch-thick steel plate. The coach can be lowered completely to the ground. The first step into the coach is four inches off the ground, then you've got another five-inch step, and you're in the coach which can be especially useful for those with knee, leg or back problems.
In addition, the 36-inch- wide door can be fitted with an ADA (American Disabilities Act) compliant door, which folds down to double as an access ramp for wheelchairs. Inside, the Stiletto features a full walk-around queen-size bed in a rear bedroom, while the front overhead bunk area is occupied by a console housing a standard 36-inch television, VCR and CD player with surround sound. Behind the console is where all of the fifth-wheel's vital systems are housed. These include a 175 psi air compressor and air tanks (for the air suspension and/or to run air tools, inflate a raft, etc.), optional central air conditioning system (when standard roof air is specified, this area can be used for added storage or a children's bed) and a heat pump. Ventilation and air intake for these systems is provided by a vent in the nose of the trailer; heat is exhausted through the roof with solar-powered fans. Every effort has been made to make all the surfaces on the coach a flush fit and all of the glass used in the coach is automotive-style frameless glass bonded to the frame -- much the way an automotive windshield is. The 38-foot Stiletto has a UVW of approximately 12,000 pounds which has already been obtained in the pre-production unit. Gross vehicle weight rating (gvwr) will be 18,500 pounds, and the fifth-wheel will hold up to 200 gallons of fresh water, up to 100 gallons each of black and gray water and 24 gallons of propane. The Stiletto comes standard with a 10-gallon water heater, a 30,000 BTU furnace, twin 13,000 BTU roof air conditioners, a 6.5 kW propane Onan AC generator, 2000 watt Trace inverter, 50 amp converter/charger and electric leveling jacks.
Top of Page »
Features & Equipment
Leather Lounge Chair and Ottoman
36" Color TV w/ Satellite;
DVD /CD Player
AM/FM Radio & UHF/VHF Antenna
74" Leather Sleeper Sofa w/Storage
Cedar Lined Wardrobe
2 Parson Chairs w/ Dining Table
Tiled Entry & Kitchen;
Berber Carpets
Porch Light & Lighted Entry
Pantry, Linens & Cooking Utensils
Moen Water Filtered Kitchen Facet
3 Burner Stainless Steel Cook top
Microwave Oven; Wall Phone
Domestic 10 cu. ft., 2-Door Refrigerator
Cherry Hardwood Cabinets
Laminated, Surfaced, Molded Countertops
Pre-Wired for 12 Volt Solar Panels
Electric Dump Valves;
Auto Leveling Jacks
Solar Protected Exterior Windows
Wheel Independent Air Glide
Suspension
Vacuum Flush Toilet System
85 gal. Water Tank & 42" Shower Stall
35 gal. Black Water Tank & Flush Kit
50 Gal. Gray Water Tank
50 Amp Power Cord
Onan Generator (6.5KW)
(4) 6 Volt Golf Cart Batteries
50 Amp Converter/Charger
2 Domestic Roof A/C 13,000 BTU
Cherry Hardwood Chair Rails Throughout
Brushed Aluminum Insets
Privacy Shades & Roof Air Vents
Cargo Liners & Lighted Assist Handle
16' Awning Girard/ Wind Sensor /Remote
30,000 BTU Furnace
24 gal. Propane Tank
10 gallon Hot Water Heater
System Monitor Panel & LPG Alarm
Top of Page »
Specifications
Height:
10 1/2 feet
Width:
8 1/2 feet
Length:
38 feet
Body Construction:
Fiberglass Composite
Suspension:
4 Wheel Independent Air Ride
Chassis:
Steel
Top of Page »
Glen & Jane G.
Old 01-13-2008, 09:43 PM   #5
Administrator
Mary F's Avatar
Not unless your name is Ron Wrighton. Previous Stiletto discussion. Note: the link to the old website is broken.
Howdy Glen!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 01-13-2008, 10:00 PM   #6
Howdy Glen!
Hi Mary,
I posted it about 2 or more years ago either here or on the Casita Club.
But todays post is directed to Web Guy. Seeing that he sold his Casita and orderd a Big Foot for full timing, I figure this would be more comfortable in the long run. The question is how much of the house sale $ would be eaten by this rig.
Besides it would look cool behind his MOPAR diesel.
Glen & Jane G.
Old 01-13-2008, 10:52 PM   #7
Gina D.'s Avatar
West Coast USA
ah, but he already HAS the Bigfoot. And a nice one it is!
Old 01-15-2008, 12:28 AM   #8
bonnie w's Avatar
Trailer: 1974 Ventura
wish the pic's could be enlarged a lot bigger I'm blind in one eye and can't see out the other.
bonnie w is offline   Reply With Quote
Old 02-20-2008, 12:03 AM   #9
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Hi Mary,
We are really enjoying our new to us Bigfoot. Went camping in the High Sierras this past weekend. We are thinking the 25 footer is a really good size. It isn't too big for Forestry Camps and it isn't too small for the RV parks with the 25 foot minimum size.
The walk around Queen bed is really nice too. It is an easy tow with our new truck.
So, we will see how it is in the long term.
Old 02-20-2008, 08:08 AM   #10
Trailer: 1989 16 ft Casita Freedom Deluxe
RV parks have a 25' limit? Does that mean when I find my Casita I won't be able to stay anywhere I like? Where do all of you fg owners stay?
SharonNDean is offline   Reply With Quote
Old 02-20-2008, 08:55 AM   #11
Sharon, some of the snootier RV parks not only have a size limit (no little ones) but also age limits for the RVs. Usually it's no RVs older than 10 years. But I can understand that one, most stickies melt by that time. My 1988 Scamp can be any age they want... since the trailer looks the same since 1982. Not much I can do about the size however. It's a trade off. Some folks say they wouldn't stay in a park that has those kinds of restrictions anyway.
My suggestion is for you to figure out as many of the places you think you'd like to stay and do an investigation to find out if the majority have restrictions... that will give you a course of action.
Old 02-20-2008, 12:24 PM   #12
When I owned my first two 17' Casitas I never ran into a RV Park that had a 25' size limit. I have been told there are some.
I have stayed at a couple pretty snooty parks and had NO problems being separated from my money.
Check out the summer rates at Crown Villa RV Resort, OUCH! Won’t do that again. Just wanted to see how the other half lives. Our Casita was lost in between two million dollar buses. It looked pretty funny. They had an age limit. We had a brand new 17' Casita Liberty. PS: We stayed at truck stops for four nights to bring our average cost down.
Old 02-20-2008, 02:06 PM   #13
Administrator
Mary F's Avatar
Adults only?
RV Life Network FAQ
Check this out Kevin K General Chat 4 06-13-2009 10:30 AM
Check this out Kevin K General Chat 5 02-02-2009 11:07 AM
What should we check for? sarah j Problem Solving | Owners Helping Owners 3 08-24-2008 02:25 PM
Check this out Ron Wrighton General Chat 33 04-13-2007 12:53 PM
