Hi - I'm Pamelia and I have a 13' Boler!!!! - Fiberglass RV
Old 04-16-2016, 12:28 PM   #1
Nova Scotia
Bought it last Oct and now I'm getting excited to get to work on it. Needs some minor stuff (door hinge, window crank) and one bigger item - replacing an axle. Fortunately, my 80 year old father is more excited about having a project than I am!! And it may just be turned into a project.
I'll be towing it around NS and NB with my Mini Cooper Clubman .... think the Boler will have to be fixed up to go with the Cooper! Wish me luck, and I'm sure I'll be asking lots of questions. I've already read almost everything posted!
Pamelia is offline   Reply With Quote
Old 04-16-2016, 03:31 PM   #2
james kent's Avatar
Trailer: Boler 1984
Hi Pamala. Congrats on the trailer. If you're pulling it with a Mini remove as much weight as you possibly can. Eliminate he battery, the propane tank, and don't tow with a tank full of water. Packed for an extended tour could over extend your tow vehicle.
Good luck
Jim
Old 04-16-2016, 04:23 PM   #3
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
I would first start with checking the owners manual for towing limits
I m kinda thinking your trailer weight and tongue weight might be an issue
I "had "a mini as well and didnt dare use it to tow a 13' scamp ( even stripped down)
Good luck... I couldn't find anyone that would evenly remotely install a hitch
Pics would be great
Old 04-17-2016, 10:22 AM   #4
Kai in Seattle's Avatar
Hi, Pamela,
We have an amerigo 1973 and even with our Dodge "Grand" Caravan, we're stripping it as far down as we can for towing. Our TV (tow vehicle) limit is 3500 max, 350 tongue. We won't do a WDH (weight distribution hitch) as it seems like robbing Peter to pay Paul, and my husband Paul doesn't care for that philosophy.
Best of luck to you, these little trailers can sure be cute and intriguing!
Semper ubi sub ubi.
Old 04-17-2016, 10:38 AM   #5
Hope that Caravan has AWD.
When you hitch up to a front wheel drive vehicle, you unweight the front axle. Some would have you add airbags to the rear, but that just makes it level.
The WDH moves weight forward to the front axle and back to the trailer axle. Nobody is getting robbed.
I got stuck half way up a gravel hill because I had my Subaru in front-wheel-drive. I had to back the tent trailer down the hill, put the Sub in 4X4 and take a run at it to make it to the top.
Old 04-17-2016, 09:26 PM   #6
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
MINI says max towing on a Clubman is 1500# with ~100# tongue weight (from the web).
If you keep from overloading with too much junk in the camper, you should be fine.
My 74 boler weights in at 950 lbs, including all our food, clothing, propane tank and such. Tongue weight is usually 50-70 lbs (I usually have to be carful to load our duffel bags of cloths on the front bench and our two coolers on the floor, at the front of the camper, to increase the tongue weight, otherwise she bounces on the hitch). Avoid just tossing everything into the back of the camper onto the bed!
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
boler
it is sunday evening and we have blown potteralice Care and Feeding of Molded Fiberglass Trailers 4 08-15-2006 11:32 PM
Which have double hull AND fiberglass floor? Leslie L. Problem Solving | Owners Helping Owners 7 05-27-2006 11:14 PM
