Home sewer Dump - Fiberglass RV
Old 02-25-2018, 05:24 PM   #1
Trailer: Shopping
Alabama
Home sewer Dump
I have a septic tank at home... has anyone added a sewer dump to the home septic tank? How much did it cost?
dcs02d is offline   Reply With Quote
Old 02-25-2018, 06:29 PM   #2
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
Home septic tank
We have one but we put it in when we developed the property so cost was minimal. We did it ourselves.
Deb & Chuck is offline   Reply With Quote
Old 02-25-2018, 06:40 PM   #3
Trailer: Casita 16ft.
I am on a municipal sewer system. I have an RV dump next to my driveway. It is simply a 4" ABS lateral teeing from the sewer line to my house with a screw in cap. I would imagine most counties would require a backflow prevention valve somewhere in the line if the elevation of the plumbing in your house is higher than your dump. As for cost, that depends on the cost of county permits, where and how deep your sewer line is, and the cost of hiring a backhoe if you need one. The pipe and misc plumbing parts are pretty cheap.
Nor Cal Mike is offline   Reply With Quote
Old 02-25-2018, 08:44 PM   #4
Borrego Dave's Avatar
Really depends on how close or far away you need to be for easy TT access to the dump connection Don. Think my run is around 20', just abs pipe and a few fittings, maybe $50.00.
Old 02-26-2018, 04:06 AM   #5
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
I installed one a couple of years back. I had a natural slope to where my septic tank is so digging wasn't to much of a problem except where I had to tie into the sewer line on the inlet side of tank. Then with a 4" Y" I used 2 -4 inch, rubber Fernco repair couplins to tie into the sewer line then with 45 degree angle and 90's made my way off lawn area to where I got the dump line above ground. From there it was a 80 foot run to where I wanted my dump station. Cost was about $150 with all the parts. OH YEA I used only schedule 40 PVC because it was mostly above ground.
Old 02-26-2018, 05:45 AM   #6
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Septic systems are often installed with a clean-out on the inlet side between the tank and the house. The clean-out is necessary in the event that the plumbing gets clogged and Roto-Rooter type unclogging is in order. My septic tank is toward the back of the house and slightly uphill, so I was unable to extend the plumbing to create a “dump station.” My solution is to utilize campground dump stations when possible, but I did purchase a large “blue boy” made by Barker Mfg. and if I don’t dump the tanks before returning home, I dump them into the Barker (which is stored in the shed rather than the garage!) and drag it to the septic clean-out. It adds an extra step in that the Barker needs to also be rinsed out, but it does allow me the flexibility of dumping at home.
Old 02-26-2018, 05:59 AM   #7
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Sewer Solution might also be used if the trailer is some distance from the sewer line.
Old 02-26-2018, 11:02 AM   #8
Trailer: 2014 Scamp 16, 2011 RAV4 V6
I happened upon a new Sewer Solution at a local thrift shop. I can park my trailer about 30 feet from a sewer line clean-out so I bought a good 25 foot 3/4 inch hose and use that and the Sewer Solution to dump my tanks. Works great.
Doug in Sacramento is offline   Reply With Quote
Old 02-26-2018, 03:37 PM   #9
Trailer: Scamp 2017 16-ft SD / FB
I have dump station at home. Got the best price available. FREE, son-in-law is a plumber.
Henry
Houston TX
Scamp 2017 16ft FB/SD
Gattopuin64 is offline   Reply With Quote
Old 02-27-2018, 07:40 AM   #10
When we had our house construction started in 1996 I requested a sewer dump for the septic system. Came one day to check progress on the house construction and found the dump already in. Had I been here when it was installed I’d have had it in a different spot. It’s useable but could be a bit more convenient. It was easy for the pickup camper because I could back right up to it but not quite so easy for the trailer. Just a little too far for conceits the hose.
Old 02-27-2018, 08:41 AM   #11
+10 A well placed clean out can serve double duty. I happen to have a clean out along my driveway, on the driver's side. Pretty much perfect as a home dump station. I even have a water hose connection a couple of feet away.
thrifty bill is online now   Reply With Quote
Old 02-27-2018, 09:35 AM   #12
Trailer: None
Our septic tank cleanout is about 35 feet from the driveway. I modified a small 1/2 HP garbage disposal and use it to grind and push the tank contents through a 50 foot long 3/4 inch hose. When empty I feed clean water in then unscrew the hose and walk it to the cleanout.
Kenton is offline   Reply With Quote
Can/do you "Dump" at home? Timber Wolf General Chat 25 08-24-2014 09:20 AM
My dump valves work! Gina D. Plumbing | Systems and Fixtures 20 02-24-2007 04:09 PM
Relocated dump valve Mike Taylor Modifications, Alterations and Updates 3 11-14-2005 03:26 AM
How to dump into (and out of) blue tote tank? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 14 04-30-2003 03:05 PM
Public Dump Sites Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 04-03-2003 05:04 PM
