honda fit tow weight - Fiberglass RV
Old 07-08-2007, 09:40 AM   #1
Trailer: Trillium 13 ft
need info on pulling a trillium little contents and only me in the car a honda fit
franklin hammond is offline   Reply With Quote
Old 07-08-2007, 09:47 AM   #2
Gina D.'s Avatar
Hi,
which Honda?
With a Ridgeline, you could tow your house, garage and 3 trills.
With a Civic.. you might be able to tow a childs wagon...
Old 07-08-2007, 09:49 AM   #3
Chester Taje's Avatar
I could not find a tow rating for a Honda Fit.What does your manual say.That is a small car.
Old 07-08-2007, 09:54 AM   #4
Gina D.'s Avatar
It's a Honda "Fit"..
Imma dope..
I thought you were talking about you fitting in the Honda...
Didn't realize there was a new Honda out there!
Old 07-08-2007, 10:03 AM   #5
on the web under honda fit it said
GVWR 2745 kg.
GCVR 4574kg
curb weight 2043kg
towing capacity 2268 (5000 lb)
payload capacity 705kg (1550lb)
all greek to me
Old 07-08-2007, 10:05 AM   #6
Benita's Avatar
Trailer: Fiber Stream 16 ft 1982
Send a message via Yahoo to Benita
GVWR 2745 kg.
GCVR 4574kg
curb weight 2043kg
all greek to me
You have got to be kidding.
There are golf carts bigger than that car.
Benita is offline   Reply With Quote
Old 07-08-2007, 10:12 AM   #7
a golf TDI can pull it
Old 07-08-2007, 10:12 AM   #8
Kevin Woods's Avatar
Trailer: Former 1978 Trillium 4500 owner
Any searching I did indicated that the Honda Fit is not capable/equiped for towing.
K
Kevin Woods is offline   Reply With Quote
Old 07-08-2007, 10:17 AM   #9
Trailer: 1991 16 ft Casita Freedom Deluxe
GVWR 2745 kg.
GCVR 4574kg
curb weight 2043kg
all greek to me
Got a link for your source? I think it may be incorrect.
Lee Hillsgrove is offline   Reply With Quote
Old 07-08-2007, 10:22 AM   #10
i am not sure if you are saying my info is incorrect or what others have told me. can you tell me what my information means. i do not understand what it says.
Old 07-08-2007, 10:30 AM   #11
Benita's Avatar
The data you are reporting is very atypical for a car the size of the Fit. Usually, the greater the mass of the tow vehicle the greater the towing capacity. (Usually, but not universally. Other factors come into play.) Vehicles in the size of the Fit are rarely tow rated for more than 1,000-1,500 pounds. And even at a 1,000 pound rating, safe towing might be marginal due to the short wheel base of the vehicle. I'm surprised the vehicle has a tow rating. I doubt its capacity to pull anything over 500 pounds.
Old 07-08-2007, 10:33 AM   #12
Gina D.'s Avatar
The Fit is not designed to tow a trailer. Its total weight capacity, including occupants and cargo, is 850 pounds.
From Car reviews Here.
Old 07-08-2007, 10:53 AM   #13
thanks for the information. i guess i can only tow 850lb minus my weight 700lb.
is there a fiberglass small enough stripped at 680lb including trailer hitch.
Old 07-08-2007, 10:57 AM   #14
Benita's Avatar
Sorry.
Old 07-08-2007, 11:02 AM   #15
These are small
http://www.golittleguy.com/cms/
Old 07-08-2007, 11:03 AM   #16
Benita's Avatar
This is the only unit I can think of that might fit size wise.
Aliner Alite
Old 07-08-2007, 11:10 AM   #17
These are small
thanks for your help
Old 07-08-2007, 11:13 AM   #18
Benita's Avatar
You might consider motorcycle trailers. They usually combine a popup tent with a platform. If you want to go hardsided, I think you are looking at the Aliner Alite 400 or a teardrop.
Not recommending these as I have no personal knowledge of these products.
Lite Tent Camper
Roadman Campers
Easy Camper
Scooter Schooner
Old 07-08-2007, 08:58 PM   #19
Brian B-P's Avatar
Okay, we all realize that the Fit's not a great tug, but in case anyone's interested...
The specs look like they were for a Ridgeline, the only Honda with a tow rating as high as 5000 lb... and it has a payload of 705 kg.
For those unfamiliar with the Fit, it is basically a Civic wagon/hatch, in an economy version. Should be a great car, but not a great tug. I agree that motorcycle trailers and small teardrops would be good matches.
On the other hand, I wouldn't be so concerned by the short wheelbase (for very small trailers), as at 2450 mm (96.5") it's no worse than the Jeeps (Wrangler and similar) which some people use to tow their 13' trailers.
weighing, weight
Tow by Honda CRV? Vickie H Towing, Hitching, Axles and Running Gear 5 11-30-2008 05:45 PM
Tow weight vs vehicle weight Paula Bindrich Towing, Hitching, Axles and Running Gear 20 06-21-2007 08:16 PM
Honda Accord Wanderer Towing, Hitching, Axles and Running Gear 8 12-14-2006 07:46 AM
Honda Element (again) DonInChatt General Chat 12 09-12-2006 10:00 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 08:49 PM
