How much RV anti-freeze to put in G/B tanks while using? - Fiberglass RV
Click Here to Login
Old 10-24-2016, 09:46 PM   #1
Trailer: C
Iowa
Is the RV/Marine anti-freeze supposed to mixed with water, or replace the water, in the valves and pipes?
I am not "winterizing" the RV, I will still be using the RV.
whoot is offline   Reply With Quote
Old 10-25-2016, 06:36 AM   #2
Standard " Pink" RV antifreeze is pre diluted and is designed to be used full strength and to displace /replace the water .
The - 50 below rating for RV antifreeze is not its freeze point.
The antifreeze turns to a,slush but does not expand and burst water / plumbing lines / valves.
From the chart I saw , diluted RV antifreeze -- 1:4 ratio (water / antifreeze) has a freeze point just slightly below plain water.
We have used our trailer during the November deer hunting season and have used -35 below F washer fluid in the black tank .It's cheaper and does give better freeze protection. If nighttime lows are only slightly below freezing and go above freezing during the the day ,I would not be overly concerned about your plumbing freezing up.
NOTE ** Windshield washer fluid is toxic, so you need to dispose of it properly and only use it in your black and gray tanks.
Need help with anti-freeze flush for Scamp Azer Plumbing | Systems and Fixtures 30 06-14-2015 11:30 AM
Using anti seize compound on wheel lugs cpaharley2008 Towing, Hitching, Axles and Running Gear 47 11-25-2014 12:05 PM
flushing out anti freeze this spring yyyyyguy Care and Feeding of Molded Fiberglass Trailers 8 04-24-2013 11:12 AM
"The Pink Stuff" anti-freeze Roger C H Problem Solving | Owners Helping Owners 9 10-22-2010 09:11 AM
RV Anti-Freeze lloyd cicetti Problem Solving | Owners Helping Owners 20 11-20-2008 03:57 PM
