How to check your propane levels - Fiberglass RV
Old 08-18-2015, 09:34 AM   #1
carlkeigley's Avatar
NE Oklahoma
Easy way to check your propane tank levels
with no extra tools........
[Video] A Little Trick To Know How Much Propane In Tank In Less Than 1 Minute If You Don't Have A Scale On Your Grill. - Brilliant DIY
Old 08-19-2015, 01:02 PM   #2
Samwise's Avatar
Name: Bill & Pam
Trailer: 2016 Bigfoot 17.5
I'm going to try this!
Samwise is offline   Reply With Quote
Old 08-19-2015, 01:50 PM   #3
Trailer: 13' Scamp
Propane Pressure Gauge
Much better idea. Costs $20 and always installed. I test for leaks every time I turn on the gas.
KevinScamps is offline   Reply With Quote
Old 08-19-2015, 02:31 PM   #4
The Minimalist's Avatar
Louisiana
I've been checking my propane like that for a long time. Quick, simple and $0.
Clif
Old 08-19-2015, 02:44 PM   #5
Better because it costs more, or better because it adds another potential leak point?
More accurate? Maybe.
Old 08-19-2015, 03:19 PM   #6
Propane Pressure Gauge?????
I've got one of those, anybody want it. It's really good at telling you when the tank is empty. So the burner doesn't light you look at the gauge to confirm what you already knew, your tank is empty.
I've used a $3.95 liquid crystal strip for years and a cup of hot water. Now I have a tank with built in float and gauge. So far it seems to work pretty well. Just your gas gauge on your tow vehicle you need to get a mental calibration.
Old 08-19-2015, 03:21 PM   #7
sokhapkin's Avatar
SW Florida
Propane pressure gauge shows if there is propane left in the tank or not. But unfortunately it never shows the actual propane level in the tank.
Sergey
www.callwithus.com
sokhapkin is online now   Reply With Quote
Old 08-19-2015, 04:21 PM   #8
David Tilston's Avatar
Why not just lift it up and shake it?
Manchester sells a tank with a float gauge.
I use a forklift tank, with a float gauge.
Pressure gauges will read differently on a hot day vs. a cold day.
Old 08-19-2015, 04:44 PM   #9
Because it is BOLTED to the tongue of the trailer..
Old 08-19-2015, 04:51 PM   #10
Gordon, Bolted? The tanks on the trailers I have, that don't have a forklift tank, are held on with an easily released big wing nut.
But I was really referring to the video. He was holding the tank.
Sorry to have frustrated you.
Old 08-19-2015, 05:06 PM   #11
I see!.. But I was generalizing, not specific to the video.
In fact, on my pop up, the tank was not only bolted on, but the bolts were real hard to get to. I always meant to get a quick release mount.
I've never found an easy and (very) accurate way to gauge the amount of propane left. I would carry two tanks if tongue weight was not an issue. The hot water method is not too bad for letting me know if I should carry a spare tank, maybe half full.
Old 08-19-2015, 05:20 PM   #12
You really should look into a Manchester 20 lb tank with a float gauge.
Old 08-19-2015, 06:03 PM   #13
Louisiana
I tried that David. Threw my back out. My wife had to put everything back in the cabinets. Scared the h**l out of the dog!
I knew I had propane in the tank, but I still didn't know how much.
Clif
Old 08-19-2015, 07:45 PM   #14
My buddy and I both had propane gauges that he got at Costco and both of us stopped using them when we decided that the gauge was impeding flow of propane to our Qs. I'd send you one, but it was tossed in the garbage some time ago.
I now use a luggage scale or boiling water.
propane
What have folks used to attach bubble levels? BatDude Problem Solving | Owners Helping Owners 23 05-02-2015 08:02 PM
75 SurfSide goes for propane system check Scott S. Modifications, Alterations and Updates 5 06-26-2008 07:12 AM
Fluid, Battery Levels & Solar Charge Controller? peterh Electrical | Charging, Systems, Solar and Generators 9 04-27-2007 04:45 PM
Check Your Avatar Bill Abbay General Chat 1 11-17-2005 11:47 AM
Propane Check Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 11-19-2002 08:54 PM
