02-18-2009, 11:42 AM
Trailer: 1983 13 ft Scamp
HOW TO HANDLE TRAILER SWAY
First, STAY OFF THE BRAKES! Stomping on the tow vehicle brakes when the trailer is swaying will only make matters worse. Don't try to steer out of the situation; the trailer is going to be swaying unpredictably and you can't react fast enough and may make matters worse.
You need to try and keep the tow vehicle and the trailer going in a straight line. Keep your hands firmly on the steering wheel and steer straight. Slowing down the trailer, and not your tow vehicle, is the ideal solution.
Gently engage the trailer brakes using the manual lever on your brake controller. Don't jam the lever all the way over and lock the trailer wheels, just use light pressure on the lever for a second or two to try and pull the trailer back in line.
This is a procedure you need to practice so you can quickly find the manual lever.
If your trailer doesn't have brakes, then your alternative is to slightly speed up the tow vehicle to try to get the trailer to start behaving. Be careful when doing this and it may not be the best idea if you are already going faster than you should. If the cause of the sway was your speed, this might just make matters worse.
02-18-2009, 01:20 PM
Trailer: 1974 Trillium 13 ft
Great subject. I've never had a sway episode, but this is how I've been preparing myself to react as well. Though after such an event I would emphasize the need to figure out the cause of the swaying, such as weight distribution, suspension, etc. and tend to stay away from anti-sway devices that hide such problems.
02-18-2009, 01:52 PM
[b]If your trailer doesn't have brakes, then your alternative is to slightly speed up the tow vehicle to try to get the trailer to start behaving. Be careful when doing this and it may not be the best idea if you are already going faster than you should. If the cause of the sway was your speed, this might just make matters worse.
If oscillating yaw occurs (what most people call sway) you can speed up only when the yaw is centered (read has just passed center). If you speed up while the yaw is at apogee (the farthest point from center) then it will accelerate the yaw.
Braking works just the opposite. If you brake while the yaw is at perigee (lined up straight) then yaw will be accelerated as it moves outward. Brake when yaw is at apogee.
I realize this is hard to understand and that almost no one will apply it in an emergency so I'm with Daniel... prevent sway and you'll never have to worry about it.
Ron
02-18-2009, 02:22 PM
Braking works just the opposite. If you brake while the yaw is at perigee (lined up straight) then yaw will be accelerated as it moves outward. [b]Brake when yaw is at apogee.
Ron
If you brake any time after the trailer starts moving back to center, and stop at, or before it comes to, center it will have a calming effect on the sway. If you brake right at or after it centers and is swinging out, it will have a negative effect. Depending upon how quickly the trailer is swaying back and forth, timing this braking can be tough. A constant acceleration would be somewhat better then none at all, if you have no trailer brakes. This definitely should be a last resort.
If for no other reason then helping control trailer sway, trailer brakes with a controller is a good thing to have.
Either that, or one could have a huge parachute deploy from the back of the trailer, that should work too.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
02-18-2009, 03:04 PM
Another alternative solution is to win the lottery and get yourself a Volkswagen Touareg tow vehicle (or its sister Porsche Cayenne, I think). They have extended the car's electronic stability control to include towing and it will selectively apply individual tow car brakes to cancel out any sway.
Very clever - though those that can afford these tow vehicles are very unlikely to actually use them for serious towing, at least in my country. However it's an idea that may well 'trickle down' to lesser vehicles.
Andrew
02-18-2009, 04:46 PM
If you brake any time after the trailer starts moving back to center [b](apogee), and stop at, or before it comes to, center [b](perigee) it will have a calming effect on the sway. If you brake right at or after it centers and is swinging out, it will have a negative effect. Depending upon how quickly the trailer is swaying back and forth, timing this braking can be tough. A constant acceleration would be somewhat better then none at all, if you have no trailer brakes. This definitely should be a last resort.
this company has a computer that works like anti-lock brakes. If it senses oscillating yaw it applies brakes to the trailer.
http://www.al-ko.co.uk/alko-Trailer.htm
02-18-2009, 05:07 PM
I actually went and looked at the Cayenne out of interest. It had some nice features, but not a lot of space inside for it's size. Still, a Porsche SUV, there is just something wrong with that.
I never realized they had that kinda trailer braking technology though.
That AL-KO system looks very interesting.
2017 Escape 5.0 TA
02-18-2009, 05:10 PM
The Al-Ko device looks pretty nifty -- I expect we will see similar devices here in the US/CA shortly -- I wonder how much it costs.
02-19-2009, 02:31 AM
Trailer: BIOD (1979 and 1990)
[b]First, STAY OFF THE BRAKES!
In Europe most people know eventually never to speed up in case of sway.
Slowing down is the only way to straighten the rig, if still possible.
But maybe NA-rigs behave in different way then? / as? EU-rigs.
02-19-2009, 10:45 AM
That reminds me of a conversation I had with someone (I forgot who) about trailering (caravaning) in Great Britain. We talked about numerous things but one part was about antisway bars. We agreed in the end that since no one uses an anti sway bar in his caravaning club that physics was different here than there since it was almost impossible to find anyone towing in the USA without one. I assign this all to some kind of cultural science aberration since we *do* grow apples here but Newton was English so...
02-19-2009, 10:56 AM
Which way does the water spin in your toilets? Therein may lie the answer.
2017 Escape 5.0 TA
02-19-2009, 12:59 PM
Trailer: 2008 19 ft Scamp Custom Deluxe 5th Wheel
RonSmith -
what ** I ** was wondering to account for the difference... could it be the axle placement? I am ABSOLUTELY no expert, but I seem to recall from some pix that have been here and on other forums that tue Euro manufacturers tend to put the axel a bit further back. might it be a "center of gravity" thing?
dunno, keemosabe.
02-19-2009, 01:01 PM
Ok, I was tracking until the toilet thing....
Do all toilets water spin the same way? Residential, RV, Porta-Potti.
If my trailer sways I have to start thinking about toilet water spinning?
02-19-2009, 01:06 PM
He's just yanking your chain... every one KNOWS that the real factor it the airspeed of an unladen european swallow
02-19-2009, 01:21 PM
An African swallow maybe, but not a European swallow. The African Swallow can bear more weight in coconuts.
2017 Escape 5.0 TA
02-19-2009, 01:27 PM
By GEORGE! You are RIGHT. I mean, just THINK MAN! The SHAPE of the coconut is a close approximation for the shape of the eggs. Ye GODS!! I bow to the master... you have well and truly solved the sway problem.
02-19-2009, 01:37 PM
WOW, I did it without even realizing the correlation between the shape of a coconut and that of an egg. But to be fair, it was your initial line of thinking that brought me to this conclusion.
I sure hope there are other Monty Python fans out there who understand, or they might think of banning us to the loony bin.
2017 Escape 5.0 TA
02-19-2009, 01:58 PM
The toilet thing had lost me, but this I understand.
02-19-2009, 03:58 PM
***The toilet thing had lost me***
Ahhhh..... that's just 'cause you guys don't have any water down there in #48
02-19-2009, 05:24 PM
Hmmm. I wonder if a partially filled water tank would add to the problem because of the weight of the water sloshing about.
Wi nøt trei a høliday in Sweden this yer?
See the løveli lakes
The wonderful telephøne system
And mani interesting furry animals
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Bigfoot GW T-Handle came off
Wally G |
6 |
09-11-2007 02:30 PM |
Floppy door handle
Christi V. |
9 |
04-05-2007 08:40 AM |
door handle PlayPac
vic |
7 |
02-20-2007 01:55 PM |
T-handle replacement
Legacy Posts |
3 |
06-15-2003 06:32 PM |
door handle
Legacy Posts |
6 |
12-17-2002 02:17 PM |
