Hunter I vs II - Fiberglass RV
Old 05-03-2016, 02:08 PM   #1
EasyTiger's Avatar
Trailer: Currently Shopping
Hunter I vs II
Hello All
I'm going to look at a Hunter Compact next week. It doesn't have a bathroom but does have the space also only has icebox no fridge or oven. The pop top canvas will need replacing soon too. It's advertised as a II, has the decals and is a 73. caulking round the windows is a bit messy as well
My question is whats the difference between a I and II and what would you think is a fair price for a 6/10?
Cheers, EasyT
EasyTiger is offline   Reply With Quote
Old 05-03-2016, 06:28 PM   #2
Denece's Avatar
Trailer: Compact II
It sure looks an awful lot like our Compact II did when we got it.
They were made with a ton of owner selected options.
This one looks like it may have/ had a heater installed?
Some have a bath most have a closet.
Some have a real fridge, most have an uninsulated icechest.
Some have an oven ( ours doesn't).
Check for a battery. Ours ran on a/c or from the tugs battery (&#128561
There is a checklist of things to look for. And someone else may know the difference between the two Hunters.
At some time during the past 40 some years lots has happened to these little beauties. Things break and get replaced. A little wiring here a little plumbing there. Nothing drastic since they're so small. But it's something to look for, since you'll find it eventually!
Denece is offline   Reply With Quote
Old 05-03-2016, 08:35 PM   #3
EasyTiger's Avatar
Thanks Denece. Hows the Compact working out for you? We're two adults and hopefully a small dog by Summer
Old 05-03-2016, 09:00 PM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
The 'messy caulking' may be a signal that a previous owner had trouble stopping a leak or leaks. They may have used silicone, which is not a good product to use with our fiberglass trailers as it does not adhere well and causes everything else you put on later to not adhere well. Read up on silicone threads here; you may have to take out windows, work hard to remove all the silicone and its residue, then re-seal with butyl tape.
How to prepare Tofu
Step 2: grill some meat
Old 05-03-2016, 09:01 PM   #5
SouthwestOregon201's Avatar
Trailer: 1979 Scamp 16 Delux
Compace I and II
I have had both the I and the II. The I has longer benches and less cabinet space. Basically, each has a sink and stove top on the driver's side of the trailer. The I cabinet stops there and the bench length starts at that spot. The II will have about one foot of closet space beyond the stove top and therefore one foot less of bench space.
On the passenger side of the I, you will have a closet and small cabinet or shelf space. The II will have a refrigerator or ice box and a two door closet for the porta potty.
Check out my photos of the builds for my '74 and my '75. Click on my 'SouthwestOregon201' user name.
'Hope this helps.
Dave Heffner
Roseburg, OR
SouthwestOregon201 is offline   Reply With Quote
Old 05-03-2016, 09:27 PM   #6
EasyTiger's Avatar
Thanks Dave
That helps a lot. Great reno by the way, real home away from home. What's the story with those slide in awnings? Can they go around corners?
Old 05-03-2016, 09:37 PM   #7
EasyTiger's Avatar
Thanks Mike
I was planning on using it as is this summer then do a reno over winter. Good to know about the silicon as thats what I would have probably used. The was a fiberglass car in the 70's called the Bond Bug, may use that for inspiration
Old 05-03-2016, 11:29 PM   #8
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Most of the trailers that were made by Hunter Structures were called either "Compact Jr" or "Compact II". A few were called "Hunters" but I have no idea how many of each were made. The photo you posted is what I would call a Compact II. The part of the roof that raises differs between them. The Jr has a raised section almost the whole length of the trailer and the II has a raised section about 1/2 the length of the trailer. Because the bench length differs, the bed size also differs. The Jr has a slightly longer bed. The II has a U shaped bench that allows seating on 3 sides of the table. I hope you find what you are searching for in a trailer.
First Sight Of 1973 Compact Jr. Photo by tomNjo | Photobucket
Old 05-04-2016, 12:15 AM   #9
EasyTiger's Avatar
Thanks Tom
I was labouring under the illusion that the only difference was the bathroom. But that seems to have been an option at the time as well as a lot of other stuff.
Old 05-04-2016, 05:49 AM   #10
Gagan, here's a thread you may find interesting:
Complete list of Compact style trailers with pictures
Old 05-04-2016, 08:57 AM   #11
EasyTiger's Avatar
Thanks
Old 05-04-2016, 10:12 AM   #12
Denece's Avatar
Trailer: Compact II
FWIW we are a couple who travel with a rather large cat.
We decided to go with a full time foam mattress ( queen with some of the length removed ) we kept the original cushions in the garage. We seldom spend a lot of time inside unless the weather is bad and then we are likely to curl up with books and coffee.
We put in a battery and solar panels since we rarely stay where there are hook ups.
We probably spend about 30-45 nights a year in it. Other issues keep us home a lot.
It is just perfect for what we like to do. Others might need more stuff.
It's all so dependent on personal preferences that you have to think about your plans; where, when and how long you plan to camp and what you need to be happy.
Best Regards
Old 05-04-2016, 01:18 PM   #13
EasyTiger's Avatar
Sounds like a great set up. I like the idea of not having to make a bed.
Good luck
Hunter Compact II Owners Legacy Posts Care and Feeding of Molded Fiberglass Trailers 41 06-14-2016 10:08 AM
1973 Compact II by Hunter Darrel Smith Modifications, Alterations and Updates 84 10-02-2015 01:25 PM
Compact and Hunter history Tom Trostel General Chat 57 10-19-2012 12:36 PM
Hunter 1 (Compact II ?) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 24 05-13-2003 09:14 PM
1975 Hunter Compact Classified Archives 0 12-31-1969 07:00 PM
