I did it all by Myself..... - Fiberglass RV
Old 03-13-2009, 07:15 PM   #1
I had ordered another Bargman Uro double light and decided to install it myself this time.
I had a little trouble stipping the end of the wire. ( really tough) but finally got it.. and got them in the wire clamps ( what ever they are called) then 'let there be light' LOL
Old 03-13-2009, 07:20 PM   #2
Roy in TO's Avatar
Way to go sparky!
Old 03-13-2009, 07:33 PM   #3
See, see you can do it! Now, just think how much $$ you saved in labor costs... spend that money to go camping
Old 03-13-2009, 09:21 PM   #4
Lizbeth's Avatar
Feels good to DIY huh? Good job!
Old 03-13-2009, 11:18 PM   #5
David & Leslie's Avatar
Trailer: Scamp 16 ft Side Bath
Hi Christi - 3 cheers! Don'tcha just love it "when a plan comes together". Great job - you're much braver than I would be about working with electrometicity! L 'n D
“Imagination is everything. It is the preview of life's coming attractions.” A. Einstein
David & Leslie is offline   Reply With Quote
Old 03-14-2009, 07:35 AM   #6
Christi,
Now you've done it!! You'll be able to see the directions for the next project
See what you started?
And the next mod is...??
Kurt & Ann K.
Old 03-14-2009, 08:29 AM   #7
i have one question on this ... i did put wood screws in to hold up the light... should i replace them with the other kind of screws with lock washer and bolt.. i don't have a rivet gun or even know how to use it.....
Old 03-14-2009, 09:03 AM   #8
If you screwed the light into wood, wood screws will work as designed... as long as you didn't strip out the wood by over tightening.
Old 03-14-2009, 11:34 AM   #9
Trailer: 2008 Casita 17 SD
Hi Chisty,
I have only one thing to add regarding your installation, as regards the type of screws you used during your light installation. I would suggest that whatever fasteners you use, that they be stainless steel. If you use common ferrous wood screws, you'll find that they will leave rust streaks later on down the road as they start to rust and corrode. It's easy to check them with a magnet...if they are attracted to the magnet, they aren't stainless steel and will eventually rust.
Old 03-14-2009, 06:49 PM   #10
james kent's Avatar
Trailer: Boler 1984
