I was sure I was done buying Trilliums for Now - Page 2 - Fiberglass RV
Click Here to Login
Old 10-15-2013, 10:05 AM   #21
David Tilston's Avatar
Cleaned it up
I got my 19 year old to help me wash the trailer.
The more I look at it, the more I think I can save it. It now smells more like bleach, then mold. If there is any rot in the floor, my jumping by the kitchen should have caused more flexing. It feels solid.
This week, I plan to try to push the roof back up.
Old 10-15-2013, 10:28 AM   #22
D Davis's Avatar
Trailer: Casita, previously u-haul ct13
Virginia
Dave, I feel your pain...But, I bet you can save it if anyone can. I am trying to learn working with fiberglassing now and am a wimpet. Fiberglass is so strong and I think you are also. I will watch for your decision and progress attentively. Good Luck.
D Davis is offline   Reply With Quote
Old 10-15-2013, 12:59 PM   #23
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Looks much better!
Maybe you can make a silk purse out of a sows ear!
Spanke
Trilliums Rock!
Old 10-15-2013, 10:46 PM   #24
Pushed the roof back up
Originally Posted by Spanke View Post
Looks much better!
Spanke
Maybe.....just maybe.
A couple of wood supports, and it's a Trillium again!
OK, I have decided. I am going to fix it.
Trillium 1300 - Humpty Dumpty - Roof - Front 01.jpg   Trillium 1300 - Humpty Dumpty - Roof - Front Curb Side 01.jpg
Trillium 1300 - Humpty Dumpty - Roof - Front Curb Side 02.jpg   Trillium 1300 - Humpty Dumpty - Roof - Front Street Side 01.jpg
Trillium 1300 - Humpty Dumpty - Roof - Rear 01.jpg   Trillium 1300 - Humpty Dumpty - Roof - Rear Curb Side 01.jpg
Trillium 1300 - Humpty Dumpty - Roof - Rear Street Side 01.jpg   Trillium 1300 - Humpty Dumpty - Roof - Street Side 01.jpg
Trillium 1300 - Humpty Dumpty - Roof - Street Side 02.jpg   Trillium 1300 - Humpty Dumpty - Roof - Street Side 03.jpg
Old 10-15-2013, 10:50 PM   #25
A few more
The curb apeal.
Trillium 1300 - Humpty Dumpty - Street Side 02.jpg   Trillium 1300 - Humpty Dumpty - Snow is comming.jpg
Old 10-16-2013, 06:16 AM   #26
Trailer: asdf
Alabama
David,
It's so cool that you are able to do this kind of thing. The poor little thing was dead and now has a chance to live again.
jwcolby54 is offline   Reply With Quote
Old 10-16-2013, 07:00 AM   #27
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
What jolly fun! NOT!! Too bad you can't find a good upper and bad lower for your bad upper and good lower. Maybe you will? Soon you'll have them all, eh?
jack
Old 10-16-2013, 08:22 AM   #28
GOODIE!
Now we get to see you turn it into a sweet little trailer!
Old 10-16-2013, 08:30 AM   #29
Jim Bennett's Avatar
If you have the time, this will be a fun project, with great reward at the end. I do look forward to watching your progress.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-16-2013, 08:50 AM   #30
jack
Pokemon reference?
I actually really enjoy fibreglass work. The plan is to support it as best I can, then grind the cracks to a paper thin wedge from the crack point to about 2" on either side, making about a 4" wide seam. Then, add glass till it is about as thick as it was previously. I think I will grind gel coat off the sides of the trolly roof, and make them twice as thick for strength.
I am amazed that the Ensolite has not ripped anywhere. Therefore, I am going to try to save it. I will do all my grinding from the outside. Some heat should help re-shape it back to the original.
Old 10-16-2013, 09:47 AM   #31
A few inside shots
With the roof up, it looks much better. A few more bleach treatments, and I will be done with the mold.
Trillium 1300 - Humpty Dumpty - Inside 01.jpg   Trillium 1300 - Humpty Dumpty - Inside 02.jpg
Trillium 1300 - Humpty Dumpty - Inside 03.jpg   Trillium 1300 - Humpty Dumpty - Inside 04.jpg
Trillium 1300 - Humpty Dumpty - Inside 05.jpg   Trillium 1300 - Humpty Dumpty - Inside 06.jpg
Old 10-16-2013, 09:57 AM   #32
What are your plans to get it to hold is final shape? I imagine the fiberglass is weakened quite a bit where it folded.
2017 Escape 5.0 TA
Old 10-16-2013, 10:22 AM   #33
That is the point of grinding the seams. Where it is folded, it cracked. I will grind out all the cracks, to paper thin, where the crack was. Then getting thicker till, after about 2", it is full thickness. Then in that gap, lay down more glass. Ideally, the grinding would be from both the inside, and the outside of the shell. But, I think I will try to save the Ensolite by grinding only on the outside. Under the upper kitchen cupboard, the glass was folded sharply. I will have to do the described repair, first on the outside, then on the inside where the back splash meets the upper cabinet.
After this, I will give thought to grinding off all the gel coat on the roof and adding a couple of layers of mat, (cloth?) to hold the shape. As you can see in the inside shots, the roof, above the closet is separating from the roof. I guess I will have to weigh it down, maybe with a cinder block. I plan to try to heat the glass to about 120°C to help with the reshaping.
It is getting it back to the proper shape that I will have the most trouble with. I am thinking 6 or 8 jacks, and a bunch of wood forms on the inside, screwed through the glass, where the Ensolite seams are. The forms will be made using the other 1300's I have as a pattern. Of course all the forms come off when the glassing is done.
I may consider kitchen supports, like Bolers have.
Old 10-16-2013, 10:12 PM   #34
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
I'm looking forward to seeing your progress! Be sure to keep taking those photos!
Sue and Henry is offline   Reply With Quote
Old 10-17-2013, 02:37 AM   #35
Trailer: 1980Trillium 1300
But, when the guy offers me a Trillium for $100, I guess I have a week spot.
Notice that it has an intact manufacture date sticker.
13-120811 March 1973
I have named it Humpty Dumpty.
My big problem is that I intended to just use this trailer as a source of parts. Now I think I can save it, (hero complex, got it bad). The previous owner tells me that the roof collapsed five years ago, and there were several rotten old sleeping bags piled on the floor all that time. The deeper I dug, the wetter they were. I suspect that the plywood under the floor is likely rotten. If so, that seals the fate of this trailer as a part trailer.
If it is a parts trailer, I will carefully document the dissection.
On the way back, I ran into a member of this site. He recognised my name, and had seen the ad for the trailer.
Date Listed 20-Sep-13
Price $300.00
Address Stony Plain, AB T7Z 1H6, Canada
View map
For Sale By Owner
Year 1969
Colour White
For Sale: late sixties/early seventies Trillium (roof caved in). Stove, heater and fridge work great. Have young family and no time to fix. Sitting at Lake Isle and waiting to be picked up by a loving owner with time and love to fix. Please pick me up and enjoy what I have to offer
I wish I could have that Trillium with 100bucks. And if I have it, here is what I would do:...Cutting off the whole roof like an open box. Reinforce the wall with posts (fiberglass U shape or even wood). Buy an used fiberglass, full size pickup truck top then from here, modify with aluminum brackets to attach new roof, glue, bond, body work, sanding.....,Hopefully at the end I would have a...one kind of customized Trillium with higher rooftop + windows and last....for a long time. Just my thought...
Old 10-17-2013, 07:31 AM   #36
Roy in TO's Avatar
Liquid TSP helps, followed by Concrobium at the end. Both available at Home Depot.
If I recall, you are not far from Outback. Does Joe have a 13' mold? If so you might be able to get him to lay out sections or an entire roof for you to onlay over the original. Much like the roof section for A/C. If not you might be able to use one of your other trailers by having the roof wrapped like a boat for storage and lay out your fiberglass sections from that.
I'm very interested in seeing what you come up with for the kitchen supports.
Old 10-17-2013, 09:20 AM   #37
I had not thought of giving Joe a call. He does owe me a solid.
Old 10-17-2013, 09:35 AM   #38
Trailer: Bigfoot 17 ft (15B17G)
Any concerns of mold behind the ensolite?
Dave_L is offline   Reply With Quote
Old 10-17-2013, 09:53 AM   #39
What a great idea Roy... wonder though if it might even be cheaper at the end of the day (labour wise) just to buy a new top half from him assuming the two pieces will fit.
Old 10-17-2013, 09:55 AM   #40
Where the Ensolite is still glued, no concerns about mold. Where it has pulled away from the fibreglass, I will expose it and spray with bleach. I think I will be opening up the Ensolite anyway, so I can get at the inside of the cracks. That way I can glass both sides of the crack.
I just got a price for the top half of the fibreglass from Out Back. About $2500. Not bad, I will have to think about it. Since Joe is using an older 1300 mould. I have to think a top from him should fit the bottom of my 1300. I guess I should ask about the upper kitchen cupboard and back splash as well. At least I wont have to pay for shipping. I am still leaning towards doing the work myself.
The next step is to open up the Ensolite and see what is there.
trillium
Trilliums for sale Jim Hovind General Chat 1 08-22-2013 04:40 PM
2 trilliums Ian Harrad Classified Archives 0 03-19-2007 06:23 PM
New Trilliums Adrian W General Chat 7 12-25-2006 07:59 PM
trilliums..the newer ones theresa p General Chat 10 10-03-2006 12:21 PM
? Known issues -Trilliums Roy in TO Care and Feeding of Molded Fiberglass Trailers 13 04-17-2006 10:20 PM
