I was sure I was done buying Trilliums for Now - Page 4 - Fiberglass RV
Old 10-17-2013, 11:46 AM   #43
Trailer: '78 Trillium 4500
Guess we just see things differently then Carol
Dave_L is offline   Reply With Quote
Old 10-17-2013, 11:58 AM   #44
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Smile
David, I am truly impressed. You have extreme abilities...I am wishing you all the best and I know you can do it. I agree with Dave L., if it matters, $2,500 would go a long ways on the rebuild. Although I know your work has a value as well. We are all watching and glad you are reviving the little camper!
D Davis is offline   Reply With Quote
Old 10-17-2013, 12:08 PM   #45
Well that may be very true! reading Men are from Mars Women are from Venus suggests its a common problem
What I see is a badly damaged fiberglass trailer that is built with two shell parts (upper and lower) joined in the middle that can be taken apart. I see a heck of a lot of fiberglass work & time going into repairing the originally damaged upper half.
I also can see a new upper half with all the fiberglass work already done going on top of the older lower half - as its been confirmed the newer shell is using the same mould it should fit nicely. Its been done by others before for such a major repair.
What I dont see is all the fiberglass work alluded to in regards to using the new top half....Yes fiberglass work would be required at the point the two half meet but I seem to recall the OP has done that type of work before if I am not mistaken and as such may not view it as a big job. I also see the cabinets having to be fiberglassed back into the new shell but again based on the OP's experience I suspect its not enough to be a deal breaker either.
I also see a big cheque being written in order to avoid all the fiberglass work needed to repair the original top half but then its up to the OP as to what they think their time is worth
So I have to ask what is it that you suggest I see differently from others?
Old 10-17-2013, 12:52 PM   #46
Trailer: 77 Scamp 13
The work and cost to restore the damage vs the cost of replacing with known solid replacement top. Hmmm Either way major investment so I would lean toward purchasing the replacement and knowing my work and expense yielded a "good as new" trailer.
Academic for me really, if I brought that home as another project DW would probably either tell me to move into it or take the scamp on a long trip to dispose of my body where it would not be found. :-)
Old 10-17-2013, 01:05 PM   #47
Good point! Also wondered if perhaps a new upper half with all that shiny gelcoat making the trailer look years newer than it is rather than a painted job that will need to take place if the old top is repaired might result in a bit higher resale price... would think painting a nice band around the joints (much as Trillium does) would be all it needed in the way of new paint.
Lots to consider and calculate out one way or another.
Good luck David either way looking forward to seeing the end result! Keep the photos rolling in!
Old 10-17-2013, 01:48 PM   #48
Trailer: asdf
Alabama
Carol,
I've never known you to make a mute point before.
jwcolby54 is offline   Reply With Quote
Old 10-17-2013, 01:59 PM   #49
Originally Posted by jwcolby54 View Post
Carol,
come out to a rally here on the West coast John if you get a chance..... some might suggested I am famous for them!
Old 10-17-2013, 02:13 PM   #50
Roy in TO's Avatar
I see your point Carol.
I think the repairs on a Trillium are more complex than on a boler / Scamp because the cabinets are all glassed in. That makes what appears to be a simple repair, much more complex. I didn't realize that at first when Phil 4500 posted about his trailers damage.
Trailer Severely Damaged After Bolerama
Having worked on my Trillium since then, I understand the difficulty. Then there is the factor of ensolite. It is hard to remove and virtually impossible to replace (due to availability) when compared to reflectix and rat fur.
Dave, let me know if you want me to grab that piece of ensolite you posted the other day.
Old 10-17-2013, 02:20 PM   #51
Roy in TO's Avatar
Didn't somebody have a spare Trillium "A/C roof" they were not using? Randy Bishop perhaps? I remember reading it posted somewhere some time ago. That might be able to be used for repair components as well.
Old 10-17-2013, 02:29 PM   #52
Roy your right about the glassing in of the cabinets and did mention that I could "see" that but if I am not mistaken David has indicated that he needs a number of new cabinets as well (suspect the ones in it are damaged?) so it sounds like at least some of the cabinet glass work in that regard may be another push as far as additional work required.
Yup did "see" and think about the ensolite as well (just didn't mention it as it was the more glass work comment to put in a new top I was puzzled by )and totally agree that is one BIG job that I know I might be trying to avoid if at all possible... not even sure I would be happy about redoing the reflectix/rat fur - gezzz how many times have we seen folks here pull out the rat fur the first week they own a Scamp because they dont like the look - only to find they dug themselves into a big hole much deeper than they probable would had they had any idea as to where they were heading
Old 10-17-2013, 03:27 PM   #53
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
I believe you are correct, it was Randy Bishop.
Spanke
Trilliums Rock!
Old 10-17-2013, 03:37 PM   #54
David Tilston's Avatar
Wow, such a heated debate. Imagine how I feel. The factors to consider:
New top:
High price
Ensolite, (might be able to transfer, but doubt it)
Color, (new top, and cupboard would be White)
Joining to to bottom, (doable, but not easy)
Repair:
Low cost
Lots of time
Might not be as smooth of a job, (sagging and misshaped)
Color will be mostly matched, but painting will still be required
Ensolite can likely be saved
As a rough estimate, I am looking at about 20 to 30 feet of cracks to repair. Similar to what is involved in a belly band. Probably more. The temporary supports and forms will take some time.
I am still leaning towards repairing the existing roof. I don't plan to build trailers from new, and the skills I would acquire, from putting on a new top half, would be less useful to me then what I learn from the repair.
After I get a look under the Ensolite, I will have a much better idea of how I am going to proceed. I am sure it will be gross.
Old 10-17-2013, 03:38 PM   #55
Yup Randy it was but that was almost a year ago and no takers so he throw them away!!
Free A/C roof parts.
Old 10-17-2013, 03:38 PM   #56
Spanke
He tossed it.
trillium
Trilliums for sale Jim Hovind General Chat 1 08-22-2013 04:40 PM
2 trilliums Ian Harrad Classified Archives 0 03-19-2007 06:23 PM
New Trilliums Adrian W General Chat 7 12-25-2006 06:59 PM
trilliums..the newer ones theresa p General Chat 10 10-03-2006 12:21 PM
? Known issues -Trilliums Roy in TO Care and Feeding of Molded Fiberglass Trailers 13 04-17-2006 10:20 PM
