Insulation - Fiberglass RV
Old 01-05-2019, 05:16 PM   #1
Trailer: Hunter compact jr
New Mexico
Insulation
Hello, my name is Tom and I have a 1971 Hunter Compact Jr. I was wanting to get some ideas on insulating this trailer. Since it is so curvy, I thought about using soft 3/8 or 1/2" foam or maybe spray foam. Any ideas would be appreciated.
Thanks, Tom
nm5tw is offline   Reply With Quote
Old 01-05-2019, 09:27 PM   #2
David B.'s Avatar
Any of your suggestions would work. You would have to make sure that the glue you use to adhere the foam to the walls will not melt the foam. Scamp trailers uses Reflectix (looks like aluminized bubble wrap) insulation with a marine headliner material glued over it. I believe the R-value is somewhere around 6 or 7, but we never had any problems with this in our two 13’ Scamps, and now in the sleeping area of our Lil Snoozy. Most of the heat loss is from windows and vents. Reflectix cut to friction fit over the windows and vents at night really helps insulate.
Dave & Paula
Old 01-05-2019, 09:55 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
A closed cell foam like Ensolite or Gym rubber will keep condensation down in the trailer. Easy to work with (scissors work) for complex curves if you use paper to make patterns. Decent R values, too.
https://foammart.com/product/ensolite/
Charlie Y
Old 01-06-2019, 11:08 AM   #4
New Mexico
Thanks for the info
Hi Dave and Charlie Y,
Thanks for your thoughts on insulation. I may go to the big box store today and buy some Reflectix. I think I'll cut some pieces for the windows and try to leave a 1/2" space between the window and Reflectix. Also I'll cut some foam for my vent. Both helping to ward off cold. Pic of the inside of my Jr.
Tom
Old 01-11-2019, 10:00 PM   #5
Everywhere
Use some sort of insulating foam rather than reflectix. The R-value of 6 is basically BS and only applies when it's used as a radiant barrier combined with a large enough air gap. Sandwiched between layers, the real R value is closer to 0.6. It's good for windows, but not so good for wall insulation like Scamp uses it.
Old 01-12-2019, 04:57 AM   #6
Reflectex R values are more I values, Imagined.
As stated above the oft quoted "R" values are from the manufacturer in some sort of equivalency test.
It is true that it does form a IR barrier by reflecting heat away from it's surface and not re-radiating it efficiently as the emissivity of polished aluminum is low.
However this null and void when it is in contact with another surface because the heat transfer changes from radiated IR to conductive heat flow.
Sandwiched between the shell and the rat fur the only insulation value is the air gap in the bubbles.
I used some reflectex in a bolster around the beds and it helps (mostly to provide stiffness for the fabric) keep you from being next to the more clammy cold Ensolite surface which while it stops the more obvious sweating, is not completely dry either.
Old 01-12-2019, 07:34 AM   #7
Trailer: 2013 Escape 19
In the world of molded FG trailers, the Hunter Jr is one of the least curvy models out there. If you don't mind giving up some width, then rigid foam sheets are available in a variety of widths. Windows will be a huge heat loss, temporary reflectrix covers will help a little.
Escape Insulation Package vs Bigfoot 4-Seasons Insulation Jane P. General Chat 43 04-18-2019 12:02 AM
Reflectix insulation Tom Trostel Modifications, Alterations and Updates 67 03-08-2006 03:35 PM
Interior liners / insulation Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 02-20-2003 03:03 PM
Eggs and Insulation Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 11-05-2002 10:48 PM
Blown foam insulation?? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 11-03-2002 03:50 PM
