Is the Oliver Elite II a Four Season Camper? - Fiberglass RV
Old 11-17-2014, 08:59 PM   #1
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
There has been a lot of discussion on various thread about how the new Oliver performs in the cold. Since this has been the coldest weather any one of them has experienced so far, I decided to do a little testing.
First some parameters and disclosures:
I am in Tupelo, MS usually not one of the coldest spots in North America especially in mid November. However, as I am writing this, it is 28̊ outside with tonightís predicted low of 18̊. As a comparison, on this day last year we had a high of 72̊ with a low of 64̊.
Our trailer is inside a metal building. The building is unheated and completely open on one end. It does stay about 3̊ or 4̊ warmer than the ambient temperature inside probably due to the heated trailer sitting there.
Although I do ďwinterizeĒ our trailer, (I drain the water and blow out the lines, no antifreeze) I keep it heated with a small heater I got at Wal-Mart. It sits on the floor about half way down the center aisle pointing toward the rear. I like to keep the interior around 60̊. Sometimes I like to go out there and take a nap or read and I want it to be comfy.
We have two digital thermometers inside mounted more or less at either end of the trailer. One is simply the remote for the Amazon.com: Maxxair 0007000K MaxxFan Deluxe Fan with Remote and White Lid: Automotive which has an onboard digital readout, the other is a La Crosse Technology  Wireless Weather Station Alarm Clock - Walmart.com that you can easily deduce from whence it came. There was one remote transmitter supplied that we mounted under the propane cover outside and it sends the information on the exterior temps. We added another remote transmitter that is mounted inside the refrigerator to monitor the temps there.
cpaharley2008 had tweaked my curiosity about the possibility of being cold sleeping right next to my windows. Since I had purposely designed our beds to top out right at the level of the windows, I wondered if maybe Iíd not thought that through.
We have double pane windows throughout the trailer.
I used a Non-Contact Infrared Thermometer With Laser Targeting to measure the interior and exterior temps. This was all done within about a 20 minute period so there was little to no temperature fluctuation.
Measurements:
The two digital thermometers both read 61̊ for the interior temperature.
All interior walls were within 1̊ of the above interior temperature.
All exterior walls were at 31̊ (just barely warmer that the ambient outside temperature).
All interior window panes were about 59̊
All exterior window panes were about 37̊
The interior of the door was 54̊
The exterior of the door was 31̊
The interior of the door glass pane was 54̊
The exterior of the door glass pane was 44̊
The floor was about 56̊
The ceiling was about 66̊
In the basement and between the shells (where all the plumbing and tanks are) the temps varied from 45̊ to 50̊ as measured on the foil surface of the reflectix insulation glued to the inside of the exterior shell.
Deductions:
There was a 30̊ difference in the temperature of the inside and outside shells.
There was a 22̊ difference in the temperature of the inside and outside window panes.
There was about a 2̊ difference between the interior wall and the interior window pane.
The door is purchased as a standard RV model with a dual pane window and is not manufactured by Oliver. It is obviously not as well insulated as the rest of the coach, but it is at least as good as the coach windows.
There was a 23̊ difference in the temperature of the inside and outside of the door.
There was a 10̊ difference in the temperature of the inside and outside door glass panes.
There was a 10̊ difference in the temperature of the floor and ceiling (heat rises).
The reflectix insulation affords about a 15̊ temperature difference on either side of a single shell. Since each shell has its own layer of reflectix, this accounts for the 30̊ difference in the temperature of the inside and outside shells.
Does all this qualify the new Oliver Elite II as having 4 season capabilities? I couldnít tell you. But I do know that itís below freezing out there right now and not even using the furnace I could easily get the temperature up to about 80̊ inside with nothing more than that little cube heater. Thatís way hotter than I want to sleep.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 11-17-2014, 09:20 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
XLNT post Steve, thanks. Sure gives some good number differences. Wonder what the temp would go to after 15 minutes with the cube heater.
Old 11-17-2014, 09:40 PM   #3
Mississippi
The other day with the temperatures were in the fifty's I accidentally left it on too high and I found it at 91 degrees inside. The towel rack in the bath was almost too hot to touch. This is not a very expensive heater, I think I might have paid about 20 dollars for it a couple of years ago.
Old 11-18-2014, 01:40 AM   #4
cpaharley2008's Avatar
Steve,
Thanks for the report, check it again when it is about 30 outside. As far as the door being the weak point, I agree as my 2012 Escape was supposedly insulated but the door was not, upon review Escape now insulates the door and my 2014 door is insulated as is the door window. The only non insulated window is in the bath which I cover with reflectix as well as the o/h vent and it makes a difference. Yours maybe similar.
The weak spot in the Escape's winter use are the metal frames used in the window construction. One can remove the interior trim and place reflectix as a barrier and it should help. The glass panes will be cold, I have used mine down to 15 degrees and they do get cold. Closing the blinds will help with that issue, but you want air on the windows to eliminate condensation? Not sure how the Oliver's blinds will work but if I recall they are plastic trim so they may help with the transfer of cold.
Keep us posted as the temperatures drop, wait you are in Mississippi, it never gets cold there. Right now it is 29 and the wind is howling, about 20 with wind chill effect. Stay warm....
Jim
Never in doubt, often wrong
Old 11-18-2014, 05:24 AM   #5
Steve, thanks for a great post and taking all the time to make all those temp measurements in downright frosty weather for your part of the country!. 28 degrees in Mississippi, with the humidity, probably felt really cold... but then it was supposed to freeze last nights in parts of Florida, as well. What a winter cold front we've got going on!
I understand even the bathroom window in the new Oliver is dual pane, correct?
Sherry
Old 11-18-2014, 06:40 AM   #6
trumpetguy's Avatar
Trailer: Airstream International CCD 28
Steve. Thanks for all that work. We will have our cube heater with us Dec. first when we take delivery. With the Oliver insulation package I hope it will suffice in the cold up there. I am a bit concerned about the tanks and plumbing as we will be camping and not winterized. Maybe Robert will let us camp out inside the factory LOL?
I wonder if there is a good 12v heater out there? For dry camping. I bought the four Trojan T105 battery package and have my solar system ready to install. Long haul truckers seem to have just about all the comforts of home so I will start researching some trucker supply sites.
BTW. 30 degrees with a chill of 21 here in Gulf Breeze Florida this morning.
2007 Airstream International CCD 28
2016 Dodge Ram Sport 5.7 Hemi 4WD
trumpetguy is offline   Reply With Quote
Old 11-18-2014, 06:42 AM   #7
What's wrong with the on board propane heater, with 4 trojans you should be good for awhile.
Jim
Old 11-18-2014, 06:49 AM   #8
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
Thanks for all the good info Steve. It's reassuring actually.
One thing not considered - if the trailer is outside, you have wind to deal with, but also you have warming from sunlight potentially. It would be interesting to know the effects.
I suppose if you were to be caught in some brutal weather, you could rig up an insulated curtain for that exterior door, as well as some insulating pads to put over the windows (between the window and the shade).
Or you can just run the heater higher - sounds like that cube heater could work to some pretty low temps if you didn't want to burn propane in the furnace.
Follow my blog - http://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 11-18-2014, 07:22 AM   #9
trumpetguy's Avatar
Nothing at all wrong with the propane furnace. In my neck of the woods it is more chilly than cold so we like to use the smaller cube heater. The thought of using my solar panels to produce "free" energy just makes me feel good hence my query about a 12v heater. Redundancy is a good thing when camping. Boy Scout motto..."Be prepared". My motto..."Be over prepared"
"Make your plan, Execute your plan, Plan for the unexpected". Paul "Bear" Bryant
Old 11-18-2014, 07:33 AM   #10
Don't' even hope to get warm with a 12 VDC heater. A typical "cube" heater pulls about 10 amps on 120 VAC. That same amount of heat would require over 100 amps on DC. If you want to use battery power, the LP furnace is your very best friend.
If you haven't noticed, one of the ways truckers stay warm in their sleepers is to leave that built in, million BTU heater, called the engine, running while sleeping
Old 11-18-2014, 08:27 AM   #11
Mississippi
IF you're referring to the wind chill factor, remember this: The only effect wind chill has on inanimate objects, such as water pipes, is to shorten the amount of time for the object to cool. The inanimate object will not cool below the actual air temperature.
Since there has been such an interest in the thermal capabilities of all of our fiberglass eggs, Iím wondering just how many people actually plan to camp in sub-zero temps. Iíve never done it, but thatís mostly a location issue with me, if it gets that cold in North Mississippi, Iím probably gonna stay home, throw another log on the fire, pop some popcorn, curl up with the dogs under a blanket and read a good book. Now, having said that, (except for the "log on the fire" part) that all sounds pretty good in the trailer too!!!
Old 11-18-2014, 08:45 AM   #12
Rob Outlaw's Avatar
Trailer: Oliver Legacy Elite II, #70
Montana
To that I feel the need to add, (being that I live in an area of extreme climate especially with winter conditions), make no mistake if it is cold and you have howling winds like we often do here in the northern hinterlands that wind will suck the life and heat right out of a house, automobile and no doubt a camper, I don't care how well its insulate or airtight its just the laws of physics. The difference with winter wind is palpable.
Rob Outlaw is offline   Reply With Quote
Old 11-18-2014, 08:46 AM   #13
Rob Outlaw's Avatar
Montana
PS, great job though Steve with all of your research and number crunching analysis.
Old 11-18-2014, 08:57 AM   #14
South Carolina
Last night here in Pennsylvannia, the wind was howling all night and the temp dropped to 11 degrees. The "wind chill" was taking it down below zero. While I'd agree that wind chill doesn't effect the temp of the trailer, the wind action does create drafts, force air in some openings/vents, seals, etc as well as draw heat out of any openings by creating vacuums.
With my furnace roaring, the best I could do was 64 degrees inside. I hate this fifth wheel and CAN'T WAIT for my new Oliver to be delivered. I'll be doing my own testing and reporting in February!
oliver
BC | SOLD 1994 B21 Bigfoot Trailer (Four Season Model) Simon A Classified Archives 3 05-04-2015 11:23 PM
four season, how to tell? krusty Problem Solving | Owners Helping Owners 9 02-17-2015 03:39 AM
Small Four Season Fiberglass Camper? Reggie Jones General Chat 14 02-22-2013 09:15 AM
Four season Scamp Raz General Chat 0 02-05-2013 06:15 AM
New Four Season Luxury Camper Rick Jokes, Stories & Tall Tales 3 07-09-2006 02:28 PM
