Istalling my FW tank - Fiberglass RV
Click Here to Login
Old 07-01-2011, 04:09 PM   #1
Russell A's Avatar
Trailer: In the market
I am leaving Monday for my trip to Harrisburg from Pittsburgh to camp at Cowan's Gap SP and I want my 16 gal FW tank installed to use. I got the fittings and will be using a sprayer for the sink. No faucets as I will have no hot water (except the 40 cup coffee tank) if that is possible. Hey it puts out water anyway. Have it almost all hooked up Tomorrow will finish it. I was going crazy trying to get fittings for the pump until I realized it had threads for inside the pump male ends. Have to run wiring for the battery to the front and return to the pump. Will put a switch for the pump at the sink like a garbage disposal off/on switch which I will turn on B4 I turn the water on.
Have to still cut a hole in the side of the trailer for fresh water inlet. Will get it working by Saturday. Going to run empty and fill up at the camp sites.
Russell A is offline   Reply With Quote
Old 07-11-2011, 07:31 PM   #2
Russell A's Avatar
Installed FW Tank
Well I got it done but this shot shows it prepped but not fully installed. Have 7 gallons of water but will hold 18. While on the trip it caused no problems. Installed the inlet and it works great.
Old 07-11-2011, 07:39 PM   #3
cpaharley2008's Avatar
I do not think Cowans has water at the campsite but located throughout the cg, you may need to have a long hose to fill your tank.
It is about 2.5 hours from me, a nice cg.
Old 07-11-2011, 08:05 PM   #4
Russell A's Avatar
Yep I was up there and had the faucet right at my site. site 161. Good spot. Free and am going for another freebee in August. Gave a talk on my hobby last Saturday. I thought it was not as good so plan on another one that is much better.
Also I recall that the faucets are not the threaded kind but smooth kitchen sink kind. Have to do bottle fill style. I think the host has full hook up to water.
Old 07-11-2011, 08:42 PM   #5
Russell,
Here is what you need.
Old 07-11-2011, 08:53 PM   #6
Russell A's Avatar
Originally Posted by Bill K View Post
Russell,
Yep! Plan on getting one. Thanks.
Old 07-11-2011, 11:18 PM   #7
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hi, Russell
Well- sounds like you've got a water tank, but...your avatar says you haven't got a trailer to put it in yet!
Seriously- what kind of rig are you towing? It kind of helps us to visualize what you're doing if we know...
Thanks!
Francesca
PROPANE TANK JIM DUNNE Problem Solving | Owners Helping Owners 5 05-17-2009 07:19 PM
Accumulator Tank Lainey Care and Feeding of Molded Fiberglass Trailers 1 08-08-2008 04:33 PM
Water tank J Martin Plumbing | Systems and Fixtures 16 05-14-2007 11:55 PM
LP Tank Clear Lyndon Laney Modifications, Alterations and Updates 4 04-05-2007 11:03 AM
Tank mountings Per Walthinsen Plumbing | Systems and Fixtures 12 03-08-2007 05:49 PM
