Just Ordered My ParkLiner - Page 2 - Fiberglass RV
Old 10-24-2013, 07:01 PM   #21
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
Congratulations Huck!
I think Cameron must have been a little confused. The furnace will work without external electrical hook-up. The blower and ignition will work off the battery and the furnace fuel is propane. The microwave and 120v outlets will require either shore power or a generator.
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 10-24-2013, 07:10 PM   #22
deryk's Avatar
New Jersey
Welcome to the ParkLiner Family
deryk
Old 10-24-2013, 07:14 PM   #23
Robin G's Avatar
Trailer: 2007 Casita
[QUOTE=BL Chiffons;427253]
Originally Posted by Huck View Post
I know that I am not the brightest bulb in the string of lights just can't seem to comprehend the electrical current jargon.
BL, I am with you on this one, because normally I kinda understand electrical! But I think the "toilet" running without hookups threw me off!
Congrats Huck! Enjoy!
Old 10-24-2013, 07:32 PM   #24
deryk's Avatar
New Jersey
I believe the fan on the blower pulls 2.7 amps an hour and will quickly deplete batteries. I learned that my first weekend and when the voltage drops low enough the furnace will shut off. Figure with the two 55 amp batteries you have 55 useable amps... so about 20 hours of heat. If boondocking generators are your friend...or a big solar array.
deryk
Old 10-24-2013, 07:35 PM   #25
Trailer: Ready to purchase.
Delaware
Parkliner ordered
Robin G. I am trying to get educated or at least remain teachable. It sounds silly and even old-school but I have pen and paper in hand and have gone back searching numerous threads and posts regarding electrical info. I really appreciate how generous people are with sharing there knowledge. It is one thing to learn about it and another thing to actually understand it.
BL Chiffons is offline   Reply With Quote
Old 10-24-2013, 07:35 PM   #26
Originally Posted by accrete View Post
Hi, The PL's do have Propane system as an option. And the propane heater will need power from the 12 volt side to run the forced air fan and ignition. On the installed single AGM battery you would deplete the battery overnight, so being plugged into shore power would be a good idea if no solar or larger battery bank is not part of the design/options.
I must be prudent with furnace use as I have gotten away with 3 days or more running it off a group 27 battery and only as needed- set the temp very low during the night or turn it right off and only use to heat the trailer up just before bedtime and again in the morning to take the chill off the trailer.
Old 10-24-2013, 07:45 PM   #27
Robin G's Avatar
It truly isn't that complex when it comes to our glass trailers. Just know you can't run a small city off 30 amps and you will be ok! That is most rv'ers problem! You will be fine! Don't worry.......
Old 10-24-2013, 07:48 PM   #28
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
I must be prudent with furnace use...
Yup your stated use would fall under "prudent" : )
Of course Cari & I are rebels and don't use heat at all during the evenings,
makes snuggling sort of a-non-optional option ; )
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 10-24-2013, 07:52 PM   #29
Well if Cari ever gives you the cold shoulder hot water bottles are great foot warmers as well.
Old 10-24-2013, 09:03 PM   #30
Trailer: asdf
Alabama
That is why I went with the golf cart batteries, 110 ah. Of course they are not AGM so you have to put them outside.
jwcolby54 is offline   Reply With Quote
Old 10-24-2013, 09:36 PM   #31
deryk's Avatar
New Jersey
Even the AGM's need to be vented to the outside, or be outside. This is one of the issues all of the ParkLiner owners till I guess this month are experiencing.
deryk
Old 11-01-2013, 07:48 PM   #32
Trailer: Parkliner
Hello everyone this is Aaron from Parkliner and I would like to clarify on the shore power hook up. The furnace will work with without shore power it is a gas appliance. The A/C , Microwave, and 110v outlets will NOT work with out shore power. The fridge and water heater does not require shore power either. Sorry for any confusion.
AmcGee is offline   Reply With Quote
Old 11-01-2013, 07:54 PM   #33
Trailer: Parkliner
Not all ParkLiner owners are haveing this Battery issue.But the batteries have been moved outside. If the blue top batteries are run all the way dead and charged to fast they will over heat. I know because I did it to one sitting outside hooked up to a charger
Old 11-01-2013, 08:09 PM   #34
deryk's Avatar
New Jersey
Aaron any word on the new tongue weight with 2 Optima d34m's on the tongue?
deryk
Old 11-01-2013, 08:25 PM   #35
Trailer: Parkliner
Working on it but we have stopped installing Optima batteries because of all the charging issues with them. But I will post with weight change as soon as it is set in stone.
Old 11-01-2013, 08:31 PM   #36
deryk's Avatar
New Jersey
Thanks Aaron....I might have to pull mine out and sit them up front just to check it. It probably is a better plan with them up front on the tongue...I might need to add more weight out back to balance it. My Rav4 has a max tongue weight of 350lbs. Don't want to overload it lol
deryk
Old 11-01-2013, 08:34 PM   #37
Trailer: Parkliner
I understand we want everyone to be safe
Old 11-01-2013, 09:09 PM   #38
accrete's Avatar
Astoria Oregon
I'm luving the addition on the optima 1200 digital charger in our PL#35. It made all the differance in proper maintaining of the optima blue tops!
Old 11-04-2013, 02:00 PM   #39
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Aaron, if ParkLiner is not installing Optima batteries anymore, what are you using now?
Thanks!
Frank
2012 ParkLiner #006
parkliner
Just ordered this mattress... courtney Modifications, Alterations and Updates 13 07-03-2013 08:57 AM
ordered our new scamp Ben and Janie Hi, I am.... 15 11-27-2012 03:36 PM
Just Ordered a 13 Scamp Duane Fowler General Chat 4 04-20-2007 08:12 PM
