Leaking window seals - Fiberglass RV
Click Here to Login
Old 07-06-2015, 12:16 PM   #1
BruceandMaryJane's Avatar
Trailer: Scamp 16 Deluxe
Illinois
I own a 2008 16 foot Scamp deluxe trailer with Hehr windows. On a recent trip we encountered a very heavy rain storm. The Hehr windows leaked at bottom miter joint of the rubber seals. I am including a couple of photos (inside and out) to show the miter joint. Notice that several photos have algae shown at and under the rubber seal, so this has been a problem for awhile. Any suggestions for cleaning, sealing, and fixing the leak.
BruceandMaryJane is offline   Reply With Quote
Old 07-15-2015, 09:37 AM   #2
Trailer: 1976 Trillium 1300
New Brunswick
Hi
Your windows must have had a sealant placed at the corners when new. It looks like the strips have shrunk away from the joint at the corners pulling the sealant too. Any glass shop should be able to fix; or supply you with the right tube of sealer if you want to try and do the repair yourself. Can't tell from the photos how the strip can be removed to gain access. Maybe someone has done this and will respond to this thread as well. If you can get a little pool algae treatment to clean the mess that would help too. Good Luck !
getaway1 is offline   Reply With Quote
Old 07-16-2015, 04:21 PM   #3
Cheryl C's Avatar
Trailer: 2004 Scamp 13 ft
I also have a 2008 16' Scamp deluxe with Hehr windows. Mine leaked at the bottom corner of the rear window. I took it to the local RV dealer last month and had them remove the window and reseal with Butyl tape. So far it's remained leak free. I don't know if the cause of the window leak I had is the same problem as yours or not.
Now, if I could just figure out why I'm getting a leak from the ceiling a/c I'd be in good shape.
Cheryl C is offline   Reply With Quote
Window seals & hardware for 76 Scamp tilt out windows Jenny W. Modifications, Alterations and Updates 47 04-21-2021 10:45 PM
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
Window Seals Pamela McBroome Care and Feeding of Molded Fiberglass Trailers 6 05-07-2010 10:48 PM
Replacement window seals and gaskets Mila Care and Feeding of Molded Fiberglass Trailers 1 05-05-2008 09:56 AM
Window seals & hardware for 76 Scamp tilt out windows Steve Thomas Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
