Leveling issues - Page 3 - Fiberglass RV
Old 12-08-2007, 07:34 PM   #29
ddayton's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Send a message via Yahoo to ddayton
Check out the last picture for a unique location for the bubble level! I like it!
Thank you and Donna for the kind words about my pictures ... I can attest that the BAL leveler works just as easily as the pictures seem to make it.
Don
ddayton is offline   Reply With Quote
Old 12-08-2007, 11:22 PM   #30
I just ordered dual axle Bigfoot 21RB. Is it possible to use two BAL levelers on dual axle trailer or this would be just too complex. My experiences with leveling legos were always hit and miss.
George
Old 12-09-2007, 07:30 AM   #31
Don
You're welcome Don. I would have given you credit, but there wasn't any "owner" information on the site. The BAL lever works as advertised (a very satisfied user)
Old 12-09-2007, 03:32 PM   #32
Trailer: Fiber Stream
Thumbs up
Is it possible to use two BAL levelers on a dual axle trailer or this would be just too complex?
The only complexity I can think of: What is your tolerance level for alternately wrenching each leveler [b]one revolution at a time, so that they effectively lift the load together?
Old 12-09-2007, 09:54 PM   #33
Brian B-P's Avatar
I'm sure that this tandem axle issue came up in a previous discussion of the BAL Leveler; unfortunately, I don't remember the result.
I doubt that it would be necessary to bring the two wheels up in such close synchronism. As long as one isn't more than an inch or two ahead of the other, I would expect the equalizer between the springs will handle the difference, keeping the load reasonably distributed between the axles.
If they are too far out of synch, even if the load is okay, there might be an issue with the interaxle distance changing, and thus disagreeing with the leveler spacing, so I would not try to jack one wheel up a lot - like the four inches required for some camp sites - before even starting on the other.
If either keeping them in synch or the time to crank up twice are issues, then the "more power" solution would be to simultaneously use a power tool (presumably a cordless impact gun) on each leveler... one in each hand. It might be worth doing if only to see the reaction of the people in the next campsite. More seriously, I personally don't know how well these work with an impact tool, but someone must have tried it and can comment.
Old 12-09-2007, 10:02 PM   #34
I know the Bal leveler has to have some weight limit. I wonder if any trailer with a tandem axle wouldn't over load the leveler. All the weight is directly on the threads of the lead screw and block.
Old 12-09-2007, 10:23 PM   #35
ddayton's Avatar
There is a BAL wheel leveler on EBAY for a 'buy it now' price of $52.00 plus shipping at
http://tinyurl.com/2fptzk
Item runs for another day and about 14 hours.
Don
Old 12-10-2007, 05:38 AM   #36
Bruce B.'s Avatar
Trailer: Casita 2008 17 ft Spirit Deluxe
Post #18 on this thread said they contacted the company (BAL) and the leveler is rated for 1700 lbs.
Also, according to the information provided on the Camping World site, it says "Level your popup or lightweight single axle trailer from side to side in minutes."
Not sure if the BAL leveler will work for multiple axle applications, but more research certainly seems in order. I'm a newbie, so I certainly don't know.
I've been following this thread with mutual interest. Hope this helps.
Bruce B. is offline   Reply With Quote
Old 12-10-2007, 12:11 PM   #37
Brian B-P's Avatar
The possibility of overloading is the reason that reasonably even load distribution between the axles is important, as Frederick mentioned.
At 1700 lb of capacity per BAL leveler, that's 3400 lb per axle; for comparison, Bigfoot 2500-series tandem-axle trailers have 3500 lb axles, cannot reach that level without slightly exceeding GVWR, and would have to carry a ton (literally) of water and cargo to get there. I think I would be willing to give it a try with something like a Bigfoot 25B21, although of course the device would not be suitable for a four-ton box-on-wheels, and would be too awkward with a triple axle trailer... but there are no four-ton or triple-axle lightweight moulded fiberglass travel trailers.
Any trailer with only a single axle of less than 3500 lb capacity is "lightweight" by industry standards, so BAL's application note makes sense. On the Norco Industries product page for the BAL Light Trailer Tire Leveler, the description starts with
Designed for single axle trailers only,
Has anyone asked them about application to tandems, such as what problems might be encountered?
Old 12-10-2007, 12:29 PM   #38
Brian B-P's Avatar
Here are some previous topics which discussed the BAL leveler (among other things), generally in chronological order (newest on top):The third one is that previous discussion of tandem axles - it had no solution to the problem of lifting two axles together: we instead discussed lifting on the frame.
Old 12-10-2007, 05:39 PM   #39
Assuming that my 21í Bigfoot trailer will weight 5,000 lb. loaded which is 2500 lb. per side and 1250 lb. per wheel. If I would use 2 BAL lifters per side this could be OK. The question is how cumbersome this would be versus using legos.
During ordering Bigfoot 21RB I was researching which style of BAL stabilizing jacks Bigfoot is putting on their 2500 on their trailers. My conclusion is that they are using T-type jacks not my preference of C-type jacks. C-type jacks are more robust and can accept BAL electric drive attachment. Bigfoot is welding vertical tabs to the frame and bolt jacks to these tabs. I am still weighting for Bigfoot response if they can attach C-type jacks which could require different tabs.
George.
Old 12-10-2007, 06:19 PM   #40
Brian B-P's Avatar
I sent this question to Customer Service at Norco Industries:
I realize that the BAL Light Trailer Tire Leveler is intended for single-axle applications, but would it be workable for a light (less than 3400 lb/axle) tandem application, if I were willing to use two of them and alternate cranking them up a few turns at a time?
and promptly received this reply:
It would only work if they could go up simultaneously. They can't. We do not recommend it.
If I had two of these things and a light tandem trailer, I'd give it a try... but wouldn't blame Norco if they jammed or wouldn't go up properly. I suspect it can work, but the obvious choice would be to go with the experts - the people who make them - and assume that the BAL Light Trailer Tire Leveler is viable only for single-axle applications. Too bad.
Old 12-10-2007, 10:32 PM   #41
Brian, thank you for contacting Norco.
I think that the answer could be different for different types of trailer suspensions. Airstreamís torsion bar dual axle suspension could have problems. Because axles are not connected, the trailer weight burden could be indeed placed on the axle being lifted quickly. On Bigfootís spring leaf suspension axlesí leaf springs are connected. The axle being lifted could travel a good few inches before taking up the full trailer load. It seems that there is a need for simple leveling of dual axle light weight trailers. Will BAL follow-up with a solution?
I did not order yet a tongue jack for my Bigfoot 21í. Is there any experience with the new Odyssey jacks?
George.
http://www.campingworld.com/browse/product...93&src=SRQB
Old 12-11-2007, 09:55 AM   #42
Brian B-P's Avatar
I agree that a pair of rubber torsion suspensions (such as in an Airstream) is a very different situation from a linked tandem pair of leaf spring axles. The rubber torsion suspensions do not share load equally, so if only one were lifted at a time, that axle's leveler could easily be overloaded. Also, the spacing will vary more as the short suspension arms swing through their arcs.
I doubt Norco (BAL) is really concerned about anything other than leaf spring suspensions (almost no one other than Airstream uses tandem rubber torsion axles), but maybe it is a factor in their recommendation.
In my note to thank the Norco customer service person for the prompt response, I did mentioned that at least a few light tandem axle travel trailer owners would be interested in product for tandems, but realistically I think it's a tiny market with little hope of being provided with a solution. I think a frame-mounted leveling jack, like that in the Oliver Legacy, is a better solution if it can be successfully integrated with the trailer's frame, suspension, and body.
Leveling the Unit georgia g Problem Solving | Owners Helping Owners 21 06-10-2011 07:08 PM
leveling the frig Bud Kennedy General Chat 12 04-08-2010 09:17 AM
Floor leveling Mac B Problem Solving | Owners Helping Owners 13 09-19-2009 02:26 AM
Leveling and stabilizing Dave M Towing, Hitching, Axles and Running Gear 20 06-25-2006 08:56 PM
Leveling a trialer Legacy Posts Problem Solving | Owners Helping Owners 9 06-12-2003 10:21 PM
