Lg white trim for doors - Fiberglass RV
Old 12-29-2008, 11:00 AM   #1
Does anyone know the exact length ya need to replace this white trim around the door? it says Lienear ft? Is that longer or shorter than a reg foot measurment....
Old 12-29-2008, 11:13 AM   #2
That IS a regular foot measurement. It's "linear" feet, meaning "in a line" (as opposed to square feet or cubic feet).
So, just measure in a line (in feet), and use decimals for the inches. 3" is 1/4 of a foot, or .25 feet....
hope this helps.
David Mooney is offline   Reply With Quote
Old 12-29-2008, 11:50 AM   #3
Lizbeth's Avatar
Be sure to get more than you think you will need. I've found what I measure and what really fits are not the same.
Old 12-29-2008, 01:53 PM   #4
I just called them and asked how many feet.. I couldnt measure good enough with the curve of the door... kent said that they 5er uses 13.5 ft so I ordered a foot more.. plus will replace the door hinge.. brass ball, spring and nuts..... also.....
Old 12-29-2008, 04:49 PM   #5
...plus will replace the door hinge.. brass ball, spring and nuts..... also.....
Christi, the bolt and nut on the Scamp hinge is plain-ole steel. It's recommended to replace with stainless, so you don't get rust running down the door at a later date. And use stainless to mount the hinge to both door and trailer.
Old 12-29-2008, 06:08 PM   #6
Lizbeth's Avatar
I just noticed mine were all rusty, one more thing to put on the "to do" list for the weekend.
Old 12-29-2008, 06:30 PM   #7
oh oh.. ok Donna... this is what i got... i didnt get the "hinge'....
Old 12-29-2008, 06:35 PM   #8
That's right. That bolt and nut are steel. Take them to your local hardware store and have someone help match them up to stainless. That's what you want to use.
Old 12-29-2008, 06:38 PM   #9
Lizbeth's Avatar
The spring is plain steels too. It's taken a couple years for mine to start rusting, but it's not as wet here.
Old 12-29-2008, 06:43 PM   #10
ok thanks....
I will try Home Depot.. they have more of a selection
Sign-ups for AZ White Mtn Rally - Aug 15-17, 2008 Nancy A. Rallies, Get-togethers, Molded Meets (Archive) 4 03-06-2011 08:19 AM
Our first trip with the Little White House Anne3358 General Chat 5 07-21-2009 11:01 AM
Black or White Tongue Box? Lisa H. Care and Feeding of Molded Fiberglass Trailers 19 06-01-2009 10:34 AM
