Lift kit, From E-trailer ? - Fiberglass RV
Old 11-10-2019, 10:09 AM   #1
Trailer: 2017 Scamp
Has anyone installed a 2" lift kit on their trailer we have a '13 2017 Scamp and could use a little more clearance. I can do the work myself looks like just bolt on project. Thank you for any information.
Duane M. Rykhus is offline   Reply With Quote
Old 11-10-2019, 11:41 AM   #2
AC0GV's Avatar
Wisconsin
Lift kit
Check the bolt patterns to get the correct kit. Mine (on a 16') has a center floor support that had to be cut. I still after 4,000 miles have not welded in a replacement support but will next summer. Alignment was done by measuring from my A frame jack to the brake plates on the axle and Im not seeing any tire wear. Note that while it lifts the frame, the axle is still at the same height, so no driving over stumps.
Old 11-10-2019, 11:57 AM   #3
I also have a 2017 Scamp 13. I would be interested in this kit. My scamp has the lipart Axel. I can not find the kit for this at etraler. Could you post a link or pare number to help my search? Thanks. John
John DL is offline   Reply With Quote
Old 11-10-2019, 12:15 PM   #4
I had one put on my Bigfoot two years ago great improvement on clearance.
Old 11-11-2019, 10:34 AM   #5
lift kit
I instaled a 4" lift on my Ventura .Now the rear bumper and tongue are dead level at 17".i also made the tongue 18" longer way easer to back up.
MAP 56 is offline   Reply With Quote
Old 11-11-2019, 11:17 AM   #6
Trailer: 2006 EggCamper #35
I got a Dexter 3 lift kit from Croft Trailer last week. Cheaper than etrailer and arrived in 4 days. I live next to Texas Trailer and took it there for installation. Lift kit 115 and labor 150. I took before pics and should be able to get after soon.
While working they identified a blown axle seal which sprayed grease on a brake shoe so one more day and a few hundred more dollars... But it reduces odds of damage from dragging and will allow us (I hope) to boondock in future.
The Egg-centric Argonauts are sailing soon...
SandyNorthFL is offline   Reply With Quote
Old 11-16-2019, 10:43 AM   #7
Trailer: 2017 Scamp
Lift
Thank you for replies I think ill go forward with this project, mostly looking to give waste gate (gray water tank) more clearance but will watch axle when going over rocks, trees or other stuff.
Old 11-16-2019, 11:56 AM   #8
Trailer: 2017 Scamp 13' & 2016 Highlander
Iowa
My 2017 13' Scamp was also too low and needed to be raised. I could not find one on Etrailer so I contacted them. They responded that their part LC270682 will work on Lippert diamond torsion axles up to 3500 lbs capacity.
Here is their response.
https://www.etrailer.com/question-377475.html?fb=yes
By the time they responded I had already made risers from 2"x3" tubing, but purchasing a set would have been much easier and probably saved money. The hardware is costly.
Here is what I did.
Need advice for low riding 2017 Scamp 13' Deluxe
GpaNed is offline   Reply With Quote
Old 11-16-2019, 07:00 PM   #9
rancilio's Avatar
Name: Matt in SoAZ
I tried three different versions of the perfectcasita 3in lift kit with shock mounts on my 2010 Scamp 13 and was never successful. After about a year of tele calls and email photos showing measurements, perfectcasita and I gave up trying to mount shocks. The bolt-on lift was easy enough after cutting my welded on axle.
rancilio is offline   Reply With Quote
Old 11-17-2019, 12:24 PM   #10
Trailer: 13 Boler, 1974
Nova Scotia
Hi Map 56,
I’m on the other side of the country, in NS. Who did you order your 4” lift from? I have a boler that sure could use one! Much appreciated for the info. We’re thinking about a tongue extension too, what made you decide on 18” for the the new length?
The Grimes is offline   Reply With Quote
Axle Lift Kit & Coupler Height Civilguy Problem Solving | Owners Helping Owners 12 04-21-2016 02:14 PM
Axle winterizing... To lift or not to lift??? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 22 12-12-2015 06:47 PM
