Lightweight & Cheap dog fence - Fiberglass RV
Click Here to Login
Old 04-05-2008, 06:46 PM   #1
Trailer: 1970 Campster
Post
Until I find the FGRV of my dreams, I'm actively searching out ways to lighten my typical camping load so my little 4 cylinder Highlander will be happier when it eventually has something neat to tow. Here's my latest inspiration. . .
Whenever I camp with my collie and two shelties I inevitably pack more gear for the dogs than I do for myself. Even my tent choice is designed around puppy comfort. But toting two 36" high xpens totalling over 30 feet in length has become a real chore as they are quite heavy. So, in searching for a light-weight alternative, I stumbled upon plastic diamond mesh fencing, which is more commonly used for snow-breaks and as temporary, reusable fencing. For $25.50 (US) you get 4' x 50' of rollable fencing that can be rolled up and reused. I invision using this around my 10' EZ-up canopy and using the canopy legs to provide support for the flexible fencing. Usually I attach the xpens to the tent poles and create a door at the attachment point. One could probably weave bamboo tomato stakes into the mesh to provide additional support between the legs of the canopy if needed. My dogs need a visual barrier more than anything as they are not jumpers. Hopefully this will work!
(And Bobbie, I was thinking of you when I posted this!)
Check it out at: http://www.tuffrhino.com/ProductDetails.as...;source=froogle
Happy trails!
Lisa H. is offline   Reply With Quote
Old 04-05-2008, 07:33 PM   #2
Bobbie Mayer's Avatar
Happy trails!
LOL... we use that at our corgi picnics and have quite a few breakouts. At the SoCal corgi picnic they back it up with two foot wire fencing to prevent the breakouts. The corgis would go under, go over, or go through. It would have worked for my Labs, though.
I'm going to try figuring out a rack for the front of the trailer for the X-pens, though, thinking that the added weight there might be helpful, and it would get the rattling out of the car.
Bobbie
Old 04-05-2008, 08:20 PM   #3
You are absolutely right. . . there are definitely breeds that would not find this kind of fencing much of a barrier to anything. It occurred to me that if you cut some PVC and added some corners and elbows you could make a frame around the bottom with a few upright supports placed in strategic locations. This might prevent the dogs from going under the fence if the PVC was woven through the fence. And the PVC is still a lot less heavy and easy to carry than a bunch of x-pens. Oh well, I'll let you know what happens with my little experiment the next time I go camping.
Old 04-05-2008, 08:24 PM   #4
Yes, keep me posted. I've thought of making a PVC fence but worried about the bulk. You can buy a plastic fence that is 26-30 inches high, but its bulkier. Same goes for the soft fences like Its A Breeze.
Bobbie
Old 04-05-2008, 09:49 PM   #5
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
...when our Shepherd was alive and when we took her camping with us we ALWAYS used 'Invisable Fence". It worked super well but the pets must FIRST be trained to the fence and its visible (small vey portable) flags on thin metal supports (VISIBLE barriers). She became so well adjusted to the fence that the last few years she was around (and camped with us) we left the controls and associated wires at home and only planted the flags around the site. This was enough for her to 'see' the visable barrier we had plotted for her for that weekend. This worked well for us but remains to be seen how it would work with a 'herd' that sometimes would tend to follow the lead dog!
Old 04-05-2008, 10:18 PM   #6
Gina D.'s Avatar
I have one of these things.. not cheap, but easily available at any box pet store. Very light as well.
I had to quit using it as one of my rottens discovered how to jump over it.
I think he was embarrassed to be seen in a baby pen
Old 04-06-2008, 02:02 AM   #7
peterh's Avatar
You could make something very much like that with some of the temporary construction fence stuff, some 36" x 48" rectangles of 1/2" PVC piping, and some zip ties to clamp the construction fence to the frame. If you made a chain of the rectangles with 1-1/2" of slack in the construction fence between each panel you could have a long, lightweight, easy to setup, fold and store fence.
--Peter
Old 04-06-2008, 08:07 AM   #8
Doesn't that fold to about 8 inches thick, though? They make them a bit taller but two at 8 inches thick would take a ton of room. Same problem with the PVC. The metal Ex-pens are about 3 inches thick folded.
Bobbie
Old 04-06-2008, 09:15 AM   #9
Gina D.'s Avatar
Yes, they are thick, but they virtually weigh nothing, so it isn't that big a deal. They go just about anywhere and toss aside easily.
The also DON'T have a really good gate mechanism.. well, they have none at all. You have to pull one section from another to open it, or lift the dogs in and out.
As you can see, neither one of them is in the featherweight category.
Old 04-06-2008, 10:38 AM   #10
Lack of a gate would be a problem.
There is a company that makes very lightweight metal ex-pens but they aren't very tall.
http://www.seabreezepetitepens.com/
Bobbie
Hybrid Highlander for lightweight towing Ben Kadas Towing, Hitching, Axles and Running Gear 8 07-23-2010 03:20 PM
SCAMP lightweight trailer Kevin K Referrals: Molded Fiberglass Trailers 1 05-18-2010 05:22 AM
How to sort out the variety of lightweight used trailers predstone Care and Feeding of Molded Fiberglass Trailers 3 03-28-2006 12:21 PM
