lil Snoozy plumbing ?? - Page 2 - Fiberglass RV
Old 05-11-2014, 06:18 AM   #15
cpaharley2008's Avatar
On my cassette toilet, (it was a T@da, not a Snoozy) there was access from inside the cartridge area, remove the toilet cartridge and inspect for leaks. Try the Thetford website for info for your model #.
Jim
Never in doubt, often wrong
Old 05-11-2014, 07:45 AM   #16
Trailer: Escape 21 Nov.2016
thetford cassette
I called thetford not to helpful I asked about taking toilet off the wall but the person I talked to did not know ?
They gave me a few service centers but 2 were out of business I have the installation manuel I will look in green cassette outside area and buy pex tools for fixing . Jim W said he put in a ball turn to shut off water at toilet in case it happens again
jennykatz is offline   Reply With Quote
Old 05-11-2014, 08:00 PM   #17
BAMA & Pachyderm Posse's Avatar
Arkansas
widmannfla@aol.com at May 11, 2014 at 5:11 PM
Plz let me know how you pulled cassette toilet off the wall
best not to i replaced the lite blue water hose with a heavy duty fuel hose , the blue one keeps blowing out . it has happened 4 times scene I replaced the hose it has been fine I think Therford uses to light weight of a hose it blisters with very little water pressure just poor design . the hose I now have rated at 75 lbs. very easy to install .
HERSCHEL AKA BAMA
BAMA & Pachyderm Posse is offline   Reply With Quote
Old 05-14-2014, 04:58 AM   #18
I replaced the blue hose coming off pex line into cassette toilet . Most of the work was done outside looking into cassette box.You willl need a small mirror to see the ten skrews that need to come out with 5 pieces of plastic holding swinging toilet . Once you get these out toilet just pulls out . then attach grey fuel line hose to where blue hose was and snake hose through toilet and then reattach toilet ,I hope this fuel line works better then the blue hose time will tell .
tools needed
small mirror ,philleps skrew driver ,and small skrew gun ,box cutter ,marine fuel line and lots of patience .
Jim W where did you buy shut off valve?
Old 05-17-2014, 05:52 AM   #19
I brought the snoozy home charged up battery ran all the appliances.Then put in the shut off valve so I can close off water supply to toilet if ever needed again . Also bought a new water pressure gizmo to keep water pressure at 40 lb .
Old 12-21-2014, 06:16 PM   #20
We finally put in a accumulator ($ 45) attached to our pump this makes the water pressure consistent and no more LED light show the lights would blink on and off when water pump would keep recycling ?
Old 12-22-2014, 06:41 AM   #21
plumbing
This is the accumulator attached to the pump.
Old 12-22-2014, 06:48 AM   #22
I can not believe you have a vented battery box inside your trailer? That battery box should be sealed and vented to the outside as it gives off dangerous fumes while being charged.
Jim
Old 12-22-2014, 07:17 AM   #23
plumbing
Yes the battery is vented through the floor 2 small tubes bring gases out if you look real close you can see small clear plastic tubes . When we start using the snoozy more I will put a new agm battery under the bed
lil snoozy
Lil Snoozy vs Scamp discussion (split from Classifieds) melissab General Chat 98 01-20-2013 11:03 AM
New Camper - Lil Snoozy Old Man Snoozy General Chat 7 08-08-2011 06:12 PM
Back from Lil Snoozy with Eye Candy!! melissab General Chat 222 04-22-2011 04:54 PM
plumbing plumbing plumbing..... Herb P Plumbing | Systems and Fixtures 6 06-17-2007 06:01 PM
