Lil Snoozy Wheelbase - Page 4 - Fiberglass RV
Old 11-21-2014, 05:25 PM   #43
honda03842's Avatar
Name: Norm and Ginny
Tire Pressure Sensors
Originally Posted by David B. View Post
Tim, one of the reasons that I like to see the tires is to see if one is getting low on air pressure. I may one day do like Norm did, and purchase a tire pressure monitoring system.
Dave & Paula
I really can't see my tires but I do use the heating elements embedded in the rear window as a gauge to see if the trailers leaning to one side (flat or flattening tire). I compare these to the window latches on the front of the Scamp.
We do have trailer tire pressure sensors displays pressure and reports temperature as Dave referenced.
We have the Tire Pressure Display mounted near Ginny. Every now and then she presses the button to display temperature looking for a rise in temperature and a difference from side to side. The sunny side is always a higher temperature unless something is wrong with the brake or bearing.
A brake locking up or a bearing failure would show up as a temperature increase. We used this same sensors for the Honda CRV's rear tires and once had a brake lock up and did see it on the display. The time we detected increasing pressure and high temperature due to a brake locking. We stopped, dumped a bottle of water on the rotor, put the Honda in reverse and stepped on the brake. It freed the caliper and everything was all right. I eventually replaced that caliper.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-21-2014, 08:04 PM   #44
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
I can see all four of our tires all the time. I guess I'm confused why some can't. I do look at them often, I'm not really sure why though. Maybe just to make sure they're still there.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 11-21-2014, 08:24 PM   #45
Trailer: Scamp Deluxe 16
Originally Posted by Missouri Mark View Post
dang, Timber Wolf, now you have me rethinking my Lil Snoozy preference. I admittedly am not the best driver in the world. I am now starting to wonder about keeping it on my side of the road in tight spots as I do intend on taking it off the beaten path.
Missouri Mark: You won't be any worse a driver than 70% of the semi trucks I encounter on the highway, attempting to stay in their lane (and doing a VERY poor job of it!
I too have thought the Snoozy is a good option for the next camper we own.
Sheryl M is offline   Reply With Quote
Old 11-22-2014, 11:04 PM   #46
Alabama
I've actually thought having the wide axle with no interior wheel well to deal with was a distinct advantage of the Snoozy. My wife and I love our EggCamper, but when both of us sit at the side dinette, one of us has to figure out where to put our feet because the wheel well takes up half of the foot room under the dinette table. The wheel well on the other side, under the galley, restricts options for upgrading to some styles of larger capacity refrigerators. I feel that another advantage of the Snoozy not having interior wheel wells is, if you opt for no side love seat, you get a lot of unobstructed floor space for customizing or adding other features (like indoor bicycle storage or room to maneuver a wheelchair inside, which the rear door entry also makes both possible). Bottom line, it is what it is, and to each their own. Personally, I think the wide track of the Snoozy has as many advantages as perceived disadvantages, but that's just me. If someone doesn't like it, there are plenty of other great campers out there to choose from. Keep calm & camp on....
Old 11-23-2014, 09:36 PM   #47
Alabama
Originally Posted by Paul O. View Post
...The storage space that the wheel wells take up does not look very significant. ....
The actual cubic inches of potential storage space taken up by an interior wheel well may not look like that much, but when you try to fit squarish storage containers in a space occupied by a hump-shaped, round-edged wheel well, you lose a lot more usable space than you'd think. So you just start throwing bags of small lose stuff, towels and other shapeless things like that in around the wheel well, and first thing you know, your whole storage organization system goes right out the window...
Old 11-24-2014, 08:45 AM   #48
In my Scamp the hot water tank sits over the wheel well on one side, living only a small amount of flat surface space between the tank and the cabinet door - just enough room for narrow trash bin and dish soap etc. On the other side the furnace is located at the wheel well which leaves no space for storage in front of it as its fully enclosed. Its a good use by the manufacture of otherwise less than functional storage space due to the hump.
Old 11-24-2014, 09:01 AM   #49
Trailer: currently shopping
Back to the width of the Lil Snoozy, I was noticing this weekend following a rather wide flatbed trailer on a state road that the trailer appeared to be 8 foot wide. That's the same as the Lil Snoozy. The state road was likely 10 foot wide. That leaves a foot on each side IF you can always maintain the trailer in the exact middle. I know interstates are 12' wide. I can see one having to be on constant alert driving the 8' wide LS on back roads.
Missouri Mark is offline   Reply With Quote
Old 11-24-2014, 09:43 AM   #50
Alabama
Narrower roads and slower speeds go hand-in-hand. But some people in our neck of the woods think they can drive interstate speeds on those narrow back roads (posted 45 or 50 mph), and those narrower country roads are much less forgiving at 70 mph.
Old 11-24-2014, 12:10 PM   #51
IllAnnoy
You'd really have to pile it on before the junk even reaches the window!
Old 11-24-2014, 01:29 PM   #52
charlsara's Avatar
Trailer: 2014 Lil Snoozy
So what you are saying is pay close attention when you are driving, hmmm.
Old 11-24-2014, 04:59 PM   #53
carlkeigley's Avatar
NE Oklahoma
I like your photoshop picture of the Snoozy.
I would probably still opt for the outside wheels.
I commented how well mine tracked at a truckstop and
a group of men responded, "Well, yeah! Boat trailers track good."
I hadn't even thought of that as I don't pull a boat trailer.
Being an old truck driver before Interstates were finished, I had
no trouble keeping a semi between the lines. But I admit, I see
all too many trucks today going from side to side. I think it's more
the skill of the driver than the truck.................lol.
lil snoozy
Jeep Wrangler, Short Wheelbase, for Towing John Hussey Towing, Hitching, Axles and Running Gear 26 01-02-2018 04:35 PM
Reversing wheelbase towing rule of thumb? Cory Lewis Towing, Hitching, Axles and Running Gear 27 05-19-2012 12:00 AM
New Camper - Lil Snoozy Old Man Snoozy General Chat 7 08-08-2011 06:12 PM
Tow vehicle / wheelbase Glenn Baglo Towing, Hitching, Axles and Running Gear 11 09-03-2008 05:29 PM
