Looked at my first 13 Scamp today - Page 2 - Fiberglass RV
Click Here to Login
Old 04-10-2007, 09:30 AM   #21
Roger H's Avatar
Thanks. Anyone know approximately when they switched to the new blade style?
Actually, the seven pole "Bargman" style connectors became the defacto standard sometime during the mid-'90s. The seven-pole connector with all round pins is a truck connector commonly used on 18 wheel semis and is still available through truck supply houses and at most truck stops.
The round six-pin connector is still in common use.
Scamp, being a custom manufacturer, will supply pretty much whatever connector you specify on a new trailer, so while most of them are now (and have been for the past several years) shipped with the "Bargman" style connector, there's no guarantee that any specific trailer you look at will be so equipped.
Roger
Old 04-10-2007, 05:40 PM   #22
Brian B-P's Avatar
... or worst case, I cut the connector I got off, and attach a round pin one.
If by some chance the Scamp comes with a connector with seven round pins, I suggest replacing it (the trailer connector) with a "Bargman" or "RV" or "flat pin / blade" style connector. The "trailer hitch guy" is right - this is the common setup, and the only one appropriate for use with electric trailer brakes. It would be far more useful for the tow vehicle to be set up with the RV connector than a mis-application of the round-pin commercial connector, and far more likely that an alternate tow vehicle could readily pull the Scamp if it has the RV connector.
We took the leap and ordered our new Scamp today Sandy Christie General Chat 14 07-25-2015 06:41 PM
1988 13 ft Scamp $1200 - moving must sell today! Will Wi Classified Archives 7 08-05-2008 09:02 AM
Ordered my new 13' Scamp today Paul Kaplan Problem Solving | Owners Helping Owners 15 07-11-2008 03:00 PM
Took our Scamp to the scales today paulw Care and Feeding of Molded Fiberglass Trailers 16 05-09-2008 12:58 PM
Met my first Scamp Today Bonnie General Chat 0 05-05-2007 01:12 PM
