Looking at a burro... - Fiberglass RV
Old 02-17-2017, 07:46 PM   #1
Trailer: Aliner
Hi all,
I sure don't need it but I am looking at a burro this weekend (hopefully!)
I have an aliner but a scamp has always been my "dream" retirement camper. I'm not retired, but hey this looks like a great deal.
What are the differences/similarities with the two brands?
I do t know much yet. Pics look really good, perhaps some surface crackling at the top corners? Could be the photo.
There is a window ac unit in the front window. Is that a problem? I will need ac, so it has to go somewhere.
Will a burro fit in a standard garage?
Decent price for a 1980 burro? 13' I believe.
Yarnstormer is offline   Reply With Quote
Old 02-17-2017, 10:54 PM   #2
Trailer: Scamp 13 ft
Burros ?
[QUOTE=Yarnstormer;627796]Hi all,
Coming back from the Quartzsite Fiberglas Rally on Tuesday I ran across these burros in Oatman, AZ, where they run wild in the streets and in the surrounding countryside. They come in various sizes, their covering is something like the ratfur in Scamps and they will fit in a standard size garage. I'm sure some more knowlegable folks will come on with with info about other burros. David in Fresno and Sonora
DavidG is offline   Reply With Quote
Old 02-17-2017, 11:10 PM   #3
Trailer: Aliner
[QUOTE=DavidG;627805]
Originally Posted by Yarnstormer View Post
Hi all,
lol. helpful. thanks.
here I am up madly all night long researching! Where are the experts??? What about the window unit hanging in the front window?? it is supported by a metal post that appears to be bolted to the frame. And there may be some duct tape...
If I decide to restore is there a less conspicuous ac option?
Old 02-17-2017, 11:35 PM   #4
I know nothing about Burros, but there are previous discussions on Burro and on air conditioning.
I suggest you do a search ( top of this page ) and start reading.
If you enter your search words in the second Google Site Search box, you will have more success.
Old 02-18-2017, 05:32 AM   #5
Biggest difference is the Burro- that's with a capital "B," the molded fiberglass kind - is a double hull design with a vertical seam. The outer shell is molded in left and right sections, rather than top and bottom. The interior is also two large pieces, left and right, with walls and cabinets molded in. From what I've read there may or may not be a layer of insulation between the outer and inner shells. You should be able to tell by looking inside cabinets.
Some were sold as finished trailers; some as DIY kits.
The big advantage is no rivets. It also permits some nicer shaping of the fiberglass, such as the taillight housings. The disadvantage is repairs and modifications involve large pieces of fiberglass. You can't swap out individual components like a Scamp. The walls are smooth fiberglass, rather than Scamp's rat fur- that's a matter of preference.
Like Scamp, a Burro has a wood floor, which can rot if windows and other shell openings aren't maintained.
A/C is the front is ugly, to be sure, but if adequately sealed and braced, it ought to be functional. I'm not sure how else you might add A/C. The usual choices involve a small window unit mounted permanently in a cabinet (tricky to get right), mounted permanently through a window (with adequate bracing), or mounted temporarily in a window (removed for towing). I've also seen portable units that sit outside with hoses going through the shell or a window. I don't recall ever seeing any roof A/C mods on a Burro. Glenn's suggestion of a search is good.
Old 02-18-2017, 09:49 AM   #6
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
Look at the modification forum
Under Baja burrito rebuil
I think the guys name is Corey wells
He has among other posts a great write-up
Maybe a pm to him would help answer your questions ( click on his name)
Good luck
Keep us posted if you buy and post pics this forum is great resource
Old 02-18-2017, 12:23 PM   #7
Trailer: Aliner
Ok! Burro report! I looked at it this morning. Highlights are:
Soft spots at doorway and wheel wells
Diy with no vin, I don't think there is insulation
Wetness under cushions. Windows are probably leaking either due to seal around them or the fact that even when closed they are not closing all the way.
Been sitting for years, tires are trashed - would have to haul it home.
I assume it needs new axle as well.
Window with ac is just open, not removed, so thats good.
Current owner has been using as a playhouse, and ran an extension cord to run ac. I plugged in camper to power and inside elec worked, I did not test outside towing lights.
Squirrels have set up residence under one seat, could not tell where they were coming in.
One taillight broken, one sidelight broken. Lots of hairline cracks in fiberglass and large area on roof that has fibers showing from previous repair. Evidence of fiberglas repair around windows.
Door needs gaskets. Bunk bed is missing, but holes are there to indicate it existed. Original upholstery. Squirrelly tho I imagine!
Logo peeling. No evidence of frame repairs that I could see. Lots of rust. Front jack worked, did not test rear stabilizers.
The spare was very close to the body of the trailer, is that common? Also had a nest in it!
Carpet in ceiling has some mold, assume the two halves need resealing? Some rust on exterior where the trim has rusted. The vent trim is missing I assume it has leaked over the years tho it was not wet lime the back seat was.
I made a very lowball offer. They have had lots of interest of course so prob can get more due to recent glamping fad.
What's it worth? Anyone? I'm not sure this one isn't a little too much work for me esp since I don't have a covered area. Very cute tho. Seemed even smaller than the scamp.
One very cool thing. She had the original manual and the xerox copies of the original hand drawn assembly instructions. Very interesting!
Old 02-18-2017, 12:27 PM   #8
Pics might help
Old 02-18-2017, 12:37 PM   #9
Trailer: Aliner
https://flickr.com/photos/14985911@N...57676990265593
Ask and ye shall receive!
Old 02-18-2017, 12:44 PM   #10
Trailer: Aliner
I'm a newbie so we have to wait til a moderator makes sure my post is cool. The pics are in my flickr album
knitinyourpants if you want to hunt them up.
Old 02-18-2017, 01:37 PM   #11
Trailer: Aliner
ID:	103071Click image for larger version
Old 02-18-2017, 01:41 PM   #12
Trailer: Aliner
ID:	103075Click image for larger version
ID:	103076Click image for larger version
ID:	103077Click image for larger version
ID:	103078Click image for larger version
ID:	103079Click image for larger version
ID:	103080Click image for larger version
ID:	103081Click image for larger version
Old 02-18-2017, 01:43 PM   #13
Trailer: Aliner
ID:	103083Click image for larger version
Old 02-18-2017, 01:44 PM   #14
Trailer: Aliner
Vertical Cracks in front of trailer at corner top to bottom not sure if you can see in this photo
burro
Still looking: for Burro or Burro clone, wide body, 14' to 17' Penney H. & Mike E. Wanted: Molded Fiberglass Travel Trailers 0 08-29-2007 07:48 PM
FOUND: Looking, Looking, Looking 13 ft. - need right price Carolyn Eck Wanted: Molded Fiberglass Travel Trailers 2 07-21-2007 09:22 AM
Looking for a Burro, Casita, or ? heidi Wanted: Molded Fiberglass Travel Trailers 14 03-06-2007 10:57 PM
Looking for a 13 ft Burro or U-haul in Pacific NW Rusty01 Wanted: Molded Fiberglass Travel Trailers 0 01-07-2007 05:16 PM
new to this, looking @ a burro-EDIT: we bought it Kevin & Georgetta General Chat 11 10-23-2006 03:15 PM
