Looking to buy 1993 Bigfoot. - Fiberglass RV
Old 07-23-2017, 09:51 AM   #1
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
Tomorrow I'm looking at and probably buying a 1993 Bigfoot 17. Does anyone have any info they can share with me? What is the weight, do they tow well, are they finished well? I'll be paying a premium and driving several hundred miles for it but from what I can see it looks pretty good. Is there anything I need to know or look out for? Tell me now or forever hold your, uh, comments lol!
Old 07-23-2017, 11:05 AM   #2
Trailer: Bigfoot B-17 CB
Mine weighs 3400 pounds with a moderate load. About 400 pounds of the 3400 on the tongue. There is lots of storage so packing more weight would be possible. Mine tows well and I saw some improvements in stability when I put 15 inch wheels and 225-75-15 tires on it. The frontal area is large so fuel consumption is not the best. Best fuel mileage was 14.5 and worst was 7.5. The 7.5 event took place on an extremely windy day. My 07 Tacoma 4x4 gets 18 or 19 when not towing. The trailer is wider than the truck, so extension mirrors are necessary. The bottom of the door (not the doorframe) was bad so I replaced the wood that was sandwiched between the exterior fiberglass panel and the interior aluminum panel.
Old 07-23-2017, 11:37 AM   #3
Thanks Jack
I'll be towing with a new Colorado diesel 4x4 z71. I've been getting 30mpg on the highway without a load. I towed a big 25' stick built with tipouts from Spokane to Vegas and averaged 16-18 so I'm thinking similar or a bit better with the Bigfoot. I currently have a Scamp 19 I'm going to be selling when I come up with a new, to me, bumper pull.
Old 07-23-2017, 02:38 PM   #4
tough....
tough would be one way to describe BFs....the biggest asset to what you're contemplating buying is a thick fiberglass shell....with no rivets. Basic construction starts with gluing thin plywood backed styrofoam insulation panels (1") to all outside surfaces....cleats are screwed to the plywood at prescribed intervals and all funrniture, partitions, lockers are fastened to these cleats....IME it's a very strong/stiff end product....
there are three distinct production runs....inception (late seventies) to about 88 or 89..... then what I like to call "second generation" and labelled "1500 series" about 89 to 2004.......in 2005 the 2500 series (17.5) was introduced and that is a heavier, better insulated, fancier, more expensive unit
if I was considering a first generation unit I would be doing a very close inspection of all wall/ceiling surfaces etc as some have experienced some seperation of the styro material from the shell....
second generation units don't seem to generate those kinds of occasional complaints.....I have a 97 and the only complaint I have in that department is that a small section of the fabric headliner (not used in first gen.) has become seperated from the ceiling in one spot (not enough glue, very stiff material and it "popped out" of the concave surface it was glued to)....it's hard to notice, it's on my "list"....dunno if I'll get to it
Bigfoots used good old Magnatek power centers that have a bad reputation (deserved)....if you can ascertain that the charger is working within limits that would be good....other wise you might be looking for a replacement converter/charger as many others have done
Bigfoots are wide and square....this makes them not very good aerodynamically speaking (gas mileage)....the flip side of that is TONS of useable storage in those same high, square areas
the two possible beds in a Bigfoot 17 are only 41 inches wide....many owners devise ways to augment this with creative solutions of their owm
bottom line is....you can buy a 15-20 year old Bigfoot for what seems to be a big price....use it for 3-5-7 years, spending money on regular stuff that breaks/wears out every year like any other trailer....and you will be selling it again for what you paid for it in the first place.....they don't make 1500 series units anymore....and the 17.5 brand new sells for 45k.....
you certainly won't have trouble towing with your TV in any situation....a thing I really like about my trailer/TV combination is how short the turning radius is....I'm a fan of single axle trailers for this reason
Now I hope you're not driving to Canada and snatching another Bigfoot to take out of this country......THAT has got to stop!.......
good luck
Old 07-23-2017, 02:50 PM   #5
Not Canada, lol this one has been in the USA for quite some time. Thanks for the info.
Old 07-25-2017, 10:07 AM   #6
I bought it!
Well I bit the bullet and bought the little Big Foot. It truly is solid and very well appointed with lots of storage. The tires on it are like new but 14". I saw a post on here where someone changed the tires on their Bigfoot to 15" and it rides a lot better. Mine rides well with the 14's but I just bought a beautiful set of 15's with fancy wheels for my Scamp and they have zero miles on them. I'd like to put them on the Bigfoot but the clearance looks pretty tight. Anyone have any tips on getting more clearance? I'll post this in other forums also. Thanks!!!
Old 07-25-2017, 10:22 AM   #7
A 1993 Bigfoot probably came with a 4"drop axle. My 94 did, so I changed to a straight axle and 225-75-15 tires fit fine. From the photo you posted, it looks like your trailer is sitting higher and might have already had some axle modification. If you post a picture of the inside of one of wheels and axle I can tell you more.
Old 07-25-2017, 10:49 AM   #8
Someone else must have posted a picture. I haven't posted any yet. Just ran out and looked and It looks like you are correct as far as the drop axle. How about just putting the axle under the leaf springs. Is that a recommended procedure?
Old 07-25-2017, 10:39 PM   #9
40bpm's Avatar
Trailer: '02 Bigfoot 17'
I had the axle on my 2002 Bigfoot changed from a drop axle to a straight axle and gained good clearance. New brakes, bearings, drums etc. were included in the axle swap.
I still have the 14" wheels/tires but someday I might get 15's which requires 3 new wheels and 3 new tires. Maybe later if I feel the need.
40bpm is offline   Reply With Quote
Old 07-25-2017, 10:57 PM   #10
pictures....
of a 97 with original springs....and "axel flipped" (I think) by a previous owner
second picture is of new, beefier springs (six leafs instead of five)...
third picture where/how it sits now....still on 14" tires....
Old 07-25-2017, 11:33 PM   #11
Trailer: Casita Spirit Deluxe
Nevada
Question Advice on a Bigfoot 25 ft motorhome - 2003
Hi there. I hope I can ask about a motorhome and not just an egg. I have a 17 ft. Casita, but my husband really cannot use it with me. I am looking at a 2003, 25 foot Bigfoot motorhome with 22,000 miles (like for the all season capability), V10. I would be the 3rd owner. It would allow my husband to join me camping. Are there some words of advice - I love my egg but....Thank you all. I have gotten many a great word of advice from the members of this list. Karen
All papers are with it. I have not seen the roof - if there is any drying out of seals. It has not been covered. I know my mileage will be poor. Can one pull a smaller vehicle behind it?
artsykaren is offline   Reply With Quote
Old 07-26-2017, 01:29 AM   #12
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Hi Karen, small TTs don't workout for everyone. I've had many folks that after the "tour", comment about my SD being so small. My standard answer is "yup and I have to outside to change my mind". Anyway, to the RV. The V10 will tow a car/truck easily and the mileage is very low. To me the 25-29' range is very good. If it has been based/stored in an area that's dry with little rain you most likely won't have water damage. On the past stick RVs I've had, I would check all the seams once a year for condition. The roof seam I resealed around the 3 year mark. They were all aluminum or one piece FG roofs. Really, your check list would be the same as looking at an egg, just add an engine, tranny and maybe a slide. BTW, the V10 is a nice motor and good luck to you.
Old 07-26-2017, 04:31 AM   #13
If you mount the 4' drop axle under the springs, you will raise the frame, and body of the trailer about the same amount as you would if you changed to a straight axle mounted above the springs. This would give you room for the larger tires and wheels but your ground clearance (the distance from the axle tube to the ground) would remain the same. If you are never going to leave improved (smooth) roads, this will work fine, but if you are going to explore BLM and Forest Service roads, that extra ground clearance is a real plus on rough terrain. When I did mine a few years ago, the cost of the straight axle was just under $100 and the new U bolts and other hardware was about $50. I felt the little extra cost was well worth it, I bought the parts from Six Roblees, a very large Dexter distributor and they have lots of inventory.
Old 07-26-2017, 09:25 AM   #14
Jack do you happen to recall the size of the axle (in length) that you purchased. I'm in Spokane and there are several axle distributors around here. You are correct that at that price I may as well go with a new axle if going through the hassle of changing it to begin with. From your post I'm assuming you did the work yourself, was it a tough job or fairly easy? Thanks
bigfoot
Looking to buy either Scamp, Casita or Bigfoot ZachO Hi, I am.... 41 02-11-2016 01:11 PM
To buy or not to buy? Beachcomber B15, Newby QUESTIONS wfamily Hi, I am.... 9 05-27-2015 02:34 PM
Looking to buy Bigfoot 25' - rear queen model Angelic Wanted: Molded Fiberglass Travel Trailers 1 08-23-2014 06:48 PM
if you were gonna buy a new tow veichle, what would you buy? Robin G General Chat 43 01-21-2009 07:04 PM
SOLD - 1993 17' Bigfoot For Sale Tim Wood Classified Archives 15 09-29-2006 09:24 AM
